源码公开
862|5
Vansm|  楼主 | 2018-8-3 13:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
<div class="blockcode"><blockquote>/*
**      SVN Information
**      Checked In          : 2017-12-27
**      Author              : Fan
**      Revision            : V1.1
**      Release Information : Loop queue (.c)
#include "Loop_queue.h"
** Loop queue initialzation
void LoopQueueInit(LoopQueue *queue)
    unsigned int i = 0;
    queue->getIndex = 0;
    queue->putIndex = 0;
    queue->dataNumber = 0;
    for(i = 0; i<QUEUE_MAX_LENGTH; i++)
        queue->queueFIFO[i] = 0;   // Clear all fifo
** Loop queue clear
void LoopQueueClear(LoopQueue *queue)
    unsigned int clearIndex;
    for(clearIndex = 0; clearIndex < QUEUE_MAX_LENGTH ; clearIndex ++)
        queue->queueFIFO[clearIndex] = 0;
** Loop queue write data by pointer
LoopQueueStateType LoopQueueWrite(LoopQueue *queue, unsigned char *data, unsigned int length)
    unsigned int i = 0;
    if(length > (QUEUE_MAX_LENGTH - queue->dataNumber))
        return UNDONE;
    for(i = 0; i<length ; i++)
        if((QUEUE_MAX_LENGTH - queue->dataNumber) == 0)
            return FULL;
        queue->queueFIFO[queue->putIndex] = *(data++);
        queue->dataNumber ++;
        if(queue->putIndex == QUEUE_MAX_LENGTH-1)
        else
           queue->putIndex ++;
    return DONE;
** Loop queue read data from queue and put its into somewhere with pointer
LoopQueueStateType LoopQueueRead(LoopQueue *queue, unsigned char *addr ,unsigned int length)
    unsigned int i = 0;
    if(queue->dataNumber == 0)
        return EMPTY;
    for(i = 0; i<length; i++)
            return UNDONE;
        *addr++ = queue->queueFIFO[queue->getIndex];
        queue->dataNumber --;
        if(queue->getIndex == QUEUE_MAX_LENGTH-1)
        else
           queue->getIndex ++;
    return DONE;
** Loop queue write one data
LoopQueueStateType LoopQueueWriteOne(LoopQueue *queue, unsigned char data)
        return FULL;
    queue->queueFIFO[queue->putIndex] = data;
    else
         queue->putIndex ++;
    return DONE;
** Loop queue read one data
LoopQueueStateType LoopQueueReadOne(LoopQueue *queue, unsigned char *addr)
        return EMPTY;
    *addr = queue->queueFIFO[queue->getIndex];
    else
         queue->getIndex ++;
    return DONE;
** Loop queue get data length
unsigned int LoopQueueGetLength(LoopQueue *queue)
    return queue->dataNumber;
Vansm|  楼主 | 2018-8-3 13:52 | 只看该作者
**      SVN Information
**      Author              : Fan
**      Revision            : V1.1
**      Release Information : Loop queue head file(.h)
#ifndef _RING_QUEUE_H_
#define _RING_QUEUE_H_
#define QUEUE_MAX_LENGTH  256                   // The max length of queue
//---------------- Loop queue states
typedef enum _LoopQueueStateType
    EMPTY = 0x50000000,                         // Queue is empty
    FULL,                                       // Queue is full
    DONE,                                       // Queue operating is done
    UNDONE,                                     // Queue operating is not done
}LoopQueueStateType;
//---------------- Loop queue struct
typedef struct _LoopQueue
    unsigned char putIndex;                     // Put data index
    unsigned char getIndex;                     // Get data index
    unsigned int dataNumber;                    // Current data number
    unsigned char queueFIFO[QUEUE_MAX_LENGTH];  // Loop queue FIFO
}LoopQueue;
//---------------- Loop queue initialization
extern void LoopQueueInit(LoopQueue *queue);
//---------------- Loop queue clear
extern void LoopQueueClear(LoopQueue *queue);
//---------------- Loop queue write data by pointer and length of data
extern LoopQueueStateType LoopQueueWrite(LoopQueue *queue, unsigned char *data, unsigned int length);
//---------------- Loop queue read data and put data by it's pointer
extern LoopQueueStateType LoopQueueRead(LoopQueue *queue, unsigned char *addr ,unsigned int length);
//---------------- Loop queue write one data
extern LoopQueueStateType LoopQueueWriteOne(LoopQueue *queue, unsigned char data);
//---------------- Loop read once
extern LoopQueueStateType LoopQueueReadOne(LoopQueue *queue, unsigned char *addr);
//---------------- Get the data length with queue pointer
extern unsigned int LoopQueueGetLength(LoopQueue *queue);
#endif
new21jackie| | 2018-8-3 22:09 | 只看该作者
  直接 i < dataNumber 不就完了吗? 自己练练手就可以了,开源社区里的这种轮子已经很多了。
            return UNDONE;
Vansm|  楼主 | 2018-8-3 22:12 | 只看该作者
  for(i = 0; ...
哎 其实是想发来让大家帮找找bug
caijie001| | 2018-8-3 22:46 | 只看该作者
谢谢分享,下载看看
