[数据转换器-信号链]
求推荐一颗能替代TLC0831的ADC芯片
800|1
武当奇人|  楼主 | 2019-7-12 16:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求推荐一颗能替代TLC0831芯片的ADC,管脚能够兼容更好。
要求:串行SPI总线,5V供电,8位/10位,容易采购
附:
TLC0831CP
1-Channel Single ADC SAR
31ksps 8-bit Serial 8-Pin PDIP
Architecture:         SAR
Number of ADCs:         1
Resolution:         8bit
Sampling Rate:         31ksps
Integral Nonlinearity Error:         ±0.4LSB
Sample and Hold:         No
Digital Interface Type:         Serial
Number of Input Channels:         1
Single-Ended Input:         Yes
Differential Input:         Yes
Polarity of Input Voltage:         Unipolar
Input Voltage:         5V
Packaging:         Tube
Minimum Operating Temperature:         0
Input Type:         Voltage
No Missing Codes:         8
Voltage Reference:         External
Differential Nonlinearity:         ±0.4LSB
Voltage Supply Source:         Single
Minimum Positive Supply Voltage:         4.5
Maximum Positive Supply Voltage:         5.5
Converter Type:         General Purpose
Special Features:         External Reference
Input Signal Type:         Differential|Single-Ended
Maximum Operating Temperature:         70
Minimum Single Supply Voltage:         4.5
Typical Single Supply Voltage:         5
Maximum Single Supply Voltage:         5.5
airwill| | 2019-7-13 09:30 | 只看该作者
你最好提一下所关心的参数,          而不是所有的参数都写上来
