[技术求助]
使用ADC141S626, 有一些疑问
274|10
午夜粪车|  楼主 | 2019-9-22 16:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
zhaoxqi| | 2019-9-22 16:22 | 只看该作者
时钟频率不能小于0.9MHZ吗
lizye| | 2019-9-22 16:27 | 只看该作者
小了是什么后果???
lizye| | 2019-9-22 16:31 | 只看该作者
关于 SCK  的频率, 手册上有这么一段话.
3.2 SCLK Input
The SCLK (serial clock) is used as the conversion clock to shift out the conversion result. SCLK is TTL and CMOS compatible. Internal settling time requirements limit the maximum clock frequency while internal capacitor leakage limits the minimum clock frequency. The ADC141S626 offers guaranteed performance with the clock rates indicated in the electrical table.
The ADC141S626 enters acquisition mode on the 16th falling edge of SCLK during a conversion frame. Assuming that the LSB is clocked into a controller on the 16th rising edge of SCLK, there is a minimum acquisition time period that must be met before a new conversion frame can begin. Other than the 16th rising edge of SCLK that was used to latch the LSB into a controller, there is no requirement for the SCLK to transition during acquisition mode. Therefore, it is acceptable to idle SCLK after the LSB has been latched into the controller.
lizye| | 2019-9-22 16:34 | 只看该作者
总的说来,  是由器件内部的一些参数导致的限制. 为了它工作得可靠, 还是遵守它的规定吧.
午夜粪车|  楼主 | 2019-9-22 16:38 | 只看该作者
我还是希望得到点实际经验,时钟降低,到底是什么现象?????
午夜粪车|  楼主 | 2019-9-22 16:42 | 只看该作者
          如果,时钟的高低脉冲时间不对称,又会是什么现象
zhanghqi| | 2019-9-22 16:49 | 只看该作者
楼主比较较真哪, 只是从手册上看:
频率过低, 可能输出不稳定.
如果,时钟的高低脉冲时间不对称, 我认为允许的频率范围可能会更窄
zhanghqi| | 2019-9-22 16:54 | 只看该作者
实际经验我没有, 也没有这个条件去试验.
楼主可以自己做个测试, 事实上, 这类数据一般都比较保守的. 可能要偏出很多才会真的出现异常.
午夜粪车|  楼主 | 2019-9-22 16:57 | 只看该作者
其实还是不大明白,我再琢磨琢磨吧,多谢了哈,结贴了先
sensitivity| | 2019-9-24 14:42 | 只看该作者
时钟频率的取值范围
