[活动专区]
【AC7811开发板试用活动】+MAX7219
663|8
Cjy_JDxy|  楼主 | 2019-10-14 19:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
收到板子了,首先搞一个MAX7219的驱动程序。
代码:
#include "ac78xx_gpio.h"
#include "ac78xx_debugout.h"
#include "ac78xx.h"
#define uchar unsigned char
#define uint unsigned int
/* makesure n < 16 */
#define PAout(n)   BIT_ADDR(GPIOA_ODR_ADDR, n)
#define PAin(n)    BIT_ADDR(GPIOA_IDR_ADDR, n)
#define PBout(n)   BIT_ADDR(GPIOB_ODR_ADDR, n)
#define PBin(n)    BIT_ADDR(GPIOB_IDR_ADDR, n)
#define PCout(n)   BIT_ADDR(GPIOC_ODR_ADDR, n)
#define PCin(n)    BIT_ADDR(GPIOC_IDR_ADDR, n)
#define PDout(n)   BIT_ADDR(GPIOD_ODR_ADDR, n)
#define PDin(n)    BIT_ADDR(GPIOD_IDR_ADDR, n)
#define PEout(n)   BIT_ADDR(GPIOE_ODR_ADDR, n)
#define PEin(n)    BIT_ADDR(GPIOE_IDR_ADDR, n)
/* gpio bit-band control */
#define LED PAout(0)
#define CLK_0           PAout(4)=0
#define CLK_1           PAout(4)=1
#define LOAD_0          PAout(2)=0
#define LOAD_1          PAout(2)=1
#define DIN_0           PAout(0)=0
#define DIN_1           PAout(0)=1
#define NoOp   0x00           //??????
#define Digit0 0x01           // ???1???
#define Digit1 0x02           // ???2???
#define Digit2 0x03           // ???3???
#define Digit3 0x04           // ???4???
#define Digit4 0x05           // ???5???
#define Digit5 0x06           // ???6???
#define Digit6 0x07           // ???7???
#define Digit7 0x08           // ???8???
#define DecodeMode 0x09       // ???????
#define Intensity 0x0a        // ?????
#define ScanLimit 0x0b        // ???????
#define ShutDown 0x0c         // ????????
#define DisplayTest 0x0f      // ???????
#define ShutdownMode 0x00     // ?????
#define NormalOperation 0x01  // ??????
#define ScanDigit 0x07        // ??????,??8????
#define DecodeDigit 0xff      // ????,8???BCD?
#define IntensityGrade 0x0a   // ??????
#define TestMode 0x01         // ??????
#define TextEnd 0x00          // ??????,????????
* Function implementation - global ('extern') and local ('static')
uchar DisBuffer[8]={0,0,0,0,0,0,0,0};    // ?????
//******************??t??**************************************
void delay(uint t)
       uint i;
       while(t--)
              /* ??12M??,???1ms */
              for (i=0;i<125;i++)
//*************?MAX7219????(8?)********************
void SendChar (uchar ch)
    uchar i,temp;
    delay(1);
    for (i=0;i<8;i++)
         temp=ch&0x80;
         ch=ch<<1;
         if(temp)
            DIN_1;
            CLK_0;
            CLK_1;
         else
            DIN_0;
            CLK_0;
            CLK_1;
//**************?MAX7219???(16?)*****************************
void WriteWord (uchar addr,uchar num)
    LOAD_0;
    delay(1);
    SendChar(addr);
    delay(1);
    SendChar(num);
    delay(1);
    LOAD_1;                            // ????????
//*********************** MAX7219??? ******************
void InitDisplay (void)
    WriteWord (ScanLimit,ScanDigit);         // ??????
    WriteWord (DecodeMode,DecodeDigit);      // ??????
    WriteWord (Intensity,IntensityGrade);    // ????
    WriteWord (ShutDown,NormalOperation);    // ?????????
* main
* @param[in]  none
* @return none
* @brief  entry
int main(void)
    InitDebug();    //´òÓ¡³õʼ»¯
    InitDelay();    //ÑÓʱº¯Êý³õʼ»¯
    GPIO_SetDir(GPIO_PA0, 1);
                GPIO_SetDir(GPIO_PA2, 1);
                GPIO_SetDir(GPIO_PA4, 1);
                InitDisplay (); // MAX7219???
    WriteWord(DisplayTest,TestMode);  // ??????,????LED
    delay(1500);                      // ???1.5s
    WriteWord (DisplayTest,TextEnd);  // ????????
    WriteWord (Digit0,0);
    WriteWord (Digit1,1);
    WriteWord (Digit2,2);
    WriteWord (Digit3,3);
    while (1)
//        LED = !LED;
//        mdelay(500);
效果图:
AutochipsMCU| | 2019-10-15 09:41 | 只看该作者
赞赞赞
marginer| | 2019-10-15 09:46 | 只看该作者
你那4个8上面显示的是啥
AutochipsMCU| | 2019-10-15 09:49 | 只看该作者
marginer 发表于 2019-10-15 09:46
你那4个8上面显示的是啥
看代码应该是0123
TechHolder| | 2019-10-15 09:50 | 只看该作者
你那4个8上面显示的是啥
MAX7219可以驱动点阵
marginer| | 2019-10-15 09:51 | 只看该作者
要求显示7811
Cjy_JDxy|  楼主 | 2019-10-15 10:33 | 只看该作者
你那4个8上面显示的是啥
0123,拍的不清楚
gaoyang9992006| | 2020-2-24 17:33 | 只看该作者
不赖不赖,这个芯片可以驱动8个数码管的,效果杠杠的。
maximQ820270087| | 2020-3-6 12:08 | 只看该作者
你有用过吗
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
