[活动专区]
【AC7811开发板试用活动】+AT24C04模拟时序
567|3
Cjy_JDxy|  楼主 | 2019-10-23 21:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
今晚搞了一下AT24C04模拟时序,参考大神的例子。
代码:
#include "ac78xx_gpio.h"
#include "ac78xx_debugout.h"
#include "ac78xx.h"
#define uchar unsigned char
#define uint unsigned int
/* makesure n < 16 */
#define PAout(n)   BIT_ADDR(GPIOA_ODR_ADDR, n)
#define PAin(n)    BIT_ADDR(GPIOA_IDR_ADDR, n)
#define PBout(n)   BIT_ADDR(GPIOB_ODR_ADDR, n)
#define PBin(n)    BIT_ADDR(GPIOB_IDR_ADDR, n)
#define PCout(n)   BIT_ADDR(GPIOC_ODR_ADDR, n)
#define PCin(n)    BIT_ADDR(GPIOC_IDR_ADDR, n)
#define PDout(n)   BIT_ADDR(GPIOD_ODR_ADDR, n)
#define PDin(n)    BIT_ADDR(GPIOD_IDR_ADDR, n)
#define PEout(n)   BIT_ADDR(GPIOE_ODR_ADDR, n)
#define PEin(n)    BIT_ADDR(GPIOE_IDR_ADDR, n)
/* gpio bit-band control */
#define LED PAout(0)
#define FALSE 0
#define TRUE  1
#define WriteDeviceAddress 0xA0
#define ReadDviceAddress   0xA1
#define EEPROM_SCL                  GPIO_PA2
#define EEPROM_SDA                  GPIO_PA0
//  E2PROM??
#define SET_SDA                GPIO_SetPinBits(EEPROM_SDA)            //SDA = 1
#define CLR_SDA                GPIO_ResetPinBits(EEPROM_SDA)          //SDA = 0
#define SDA_IN                                   GPIO_GetPinValue(EEPROM_SDA)           //Read SDA
#define SET_SCL                GPIO_SetPinBits(EEPROM_SCL)            //SCL = 1
#define CLR_SCL                GPIO_ResetPinBits(EEPROM_SCL)          //SCL = 0
void I2C_Delay(uint16_t number)
        uint16_t j;
        for(j=0;j<number;j++);
void DIR_In(void)
    GPIO_SetDir(EEPROM_SDA, 0);//??SDA?????
    GPIO_SetPullupEnable(EEPROM_SDA, ENABLE); //????
void DIR_Out(void)
    GPIO_SetDir(EEPROM_SDA, 1);//??SDA?????
void Start_I2c(void)
    DIR_Out();
                SET_SDA;
                I2C_Delay(400);
                SET_SCL;
                I2C_Delay(400);
                CLR_SDA;
                I2C_Delay(400);
                CLR_SCL;
                I2C_Delay(400);
void Stop_I2c(void)
    DIR_Out();
                CLR_SDA;
                I2C_Delay(400);
                SET_SCL;
                I2C_Delay(400);
                SET_SDA;
                I2C_Delay(400);
                CLR_SCL;
                I2C_Delay(400);
void WriteAByte(uint16_t data)
    uint16_t i;
                DIR_Out();
                for(i=0;i<8;i++)
                        CLR_SCL;
                        I2C_Delay(400);
                        if ((data>>7)&0x0001)
                                        SET_SDA;
                                        else
                                        CLR_SDA;
                        I2C_Delay(400);
                        SET_SCL;
                        data <<= 1;
                        I2C_Delay(400);
                 CLR_SCL;
                I2C_Delay(400);
uint16_t ReadAByte(void)
                uint16_t i,bit=0,data=0;
                DIR_In();
                CLR_SCL;
                I2C_Delay(400);
                for (i=0; i<8; i++)
                        SET_SCL;
                        I2C_Delay(400);
                        if(SDA_IN)
                                        bit=1;
                                        else
                                        bit=0;
                        data = (data << 1) | bit;
                        CLR_SCL;
                        I2C_Delay(400);
                return (data);
uint16_t ReceiveI2CAck(void)
                uint16_t i=5000;
                SET_SDA;
                DIR_In();
                SET_SCL;
                I2C_Delay(400);
                while (SDA_IN)
                        if(!(--i))
                        CLR_SCL;
                        return(FALSE);
                CLR_SCL;
                I2C_Delay(400);
                return(TRUE);
void SendI2CAck(void)
                CLR_SCL;
                I2C_Delay(400);
                DIR_Out();
                CLR_SDA;
                SET_SCL;
                I2C_Delay(400);
                CLR_SCL;
                I2C_Delay(400);
void SendI2CNAck(void)
                CLR_SCL;
                I2C_Delay(400);
                DIR_Out();
                SET_SDA;
                SET_SCL;
                I2C_Delay(400);
                CLR_SCL;
                I2C_Delay(400);
*  EEPROM_Config
* @param[in] void
* @return void
* @brief config eeprom pinmux and gpio
void EEPROM_Config(void)
                GPIO_SetDir(EEPROM_SCL, 1);//??SCL?????
*  EEPROM_Read
* @param[in] address range 0-511(24c08)
* @return the value from address.
* @brief read eeprom
uint8_t EEPROM_Read(uint8_t address)
                uint8_t AX;
                AX = address << 1;
                Start_I2c();
                WriteAByte(WriteDeviceAddress);
                if (!ReceiveI2CAck())
                                return( FALSE );
                WriteAByte( AX );
                                return( FALSE );
                Start_I2c();
                WriteAByte(ReadDviceAddress);
                                return( FALSE );
                AX = ReadAByte();
                SendI2CAck();
                AX += (ReadAByte()) << 8;
                SendI2CNAck();
                Stop_I2c();
                return( AX );              // ???,??????,?????
*  EEPROM_Write
* @param[in] address: 0-511(24c08), data: a 16bit value
* @return void
* @brief write eeprom
void EEPROM_Write(uint8_t address, uint8_t data)
        uint8_t AX;
         AX = address <<1;
         Start_I2c();
         ReceiveI2CAck();
         WriteAByte( AX );
         ReceiveI2CAck();
         WriteAByte(data);
         ReceiveI2CAck();
         WriteAByte((data)>>8);
         ReceiveI2CAck();
         Stop_I2c();
        I2C_Delay(5000);
        I2C_Delay(5000);
        I2C_Delay(5000);
        I2C_Delay(5000);
        I2C_Delay(5000);
        I2C_Delay(5000);
        I2C_Delay(5000);
        I2C_Delay(5000);
* main
* @param[in]  none
* @return none
* @brief  entry
int main(void)
                uint8_t buffer[3];
    InitDebug();    //´òÓ¡³õʼ»¯
    InitDelay();    //ÑÓʱº¯Êý³õʼ»¯
                GPIO_SetDir(GPIO_PA2, 1);
                GPIO_SetDir(GPIO_PA4, 1);
                EEPROM_Write(0,0x5a);
                EEPROM_Write(1,0xa5);
                EEPROM_Write(2,0x69);
                buffer[0]=EEPROM_Read(1);
                buffer[1]=EEPROM_Read(2);
                buffer[2]=EEPROM_Read(0);
    while (1)
                                //printf("T1: %f\r\n",Temp1);
                                //printf("T2: %f\r\n",Temp2);
        LED = !LED;
        mdelay(500);
效果图:
Cjy_JDxy|  楼主 | 2019-10-23 21:27 | 只看该作者
再来一张。
TechHolder| | 2019-10-24 09:08 | 只看该作者
强。
AutochipsMCU| | 2019-10-24 10:17 | 只看该作者
厉害厉害
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
