[资料分享]
SimpleLink™ ULP 传感器 BoosterPack™ BOOSTXL-ULPSENSE
359|10
dirtwillfly|  楼主 | 2019-10-25 21:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
To get started visit dev.ti.com/BOOSTXL-ULPSENSE
The ULP Sense BoosterPack is a kit designed to make it easy to demonstrate the ultra-low power features of the sensor controller included in the CC13x2/CC26x2 RF SoCs.
Examples of applications that will greatly benefit from this are measurement on mechanical flow meters (either based on a reed switch or an inductive principle), Capacitive touch buttons and ultra-low power handling of accelerometers (for example fall detection).
The board also contains an analog light sensor and a potentiometer that is useful for ADC test cases. Many of the software examples in the ULP Sense Studio will be using the ULP Sense BoosterPack as a hardware platform.
特性
  • 40-pin BoosterPack standard leveraging the LaunchPad ecosystem
  • Inductive flow meter measurements - LC circuits and logical gates
  • Ultra-Low Power accelerometer
  • Two Cap touch buttons
  • Analog Light Sensor
  • Reed Switch
  • Potentiometer (0 to 200 kOhm range)
包含项目
  • BoosterPack Board
  • Plexi Glass
  • Quick Start Guide
dirtwillfly|  楼主 | 2019-10-25 21:08 | 只看该作者
Getting Started With the CC13xx and CC26xx Sensor Controller.pdf (671.5 KB)
dirtwillfly|  楼主 | 2019-10-25 21:09 | 只看该作者
Software SAR ADC using the CC2642R1 sensor controller.pdf (190.01 KB)
dirtwillfly|  楼主 | 2019-10-25 21:10 | 只看该作者
Meet the SimpleLink™ Sensor Controller.pdf (87.97 KB)
CC1312R, CC1352R Flow Metering Applications With the CC13x2R Wireless MCUs.pdf (88.07 KB)
dirtwillfly|  楼主 | 2019-10-25 21:11 | 只看该作者
Measuring CC2642R1 Sensor Controller Power Consumption.pdf (671.5 KB)
dirtwillfly|  楼主 | 2019-10-25 21:12 | 只看该作者
Sensor sequencing using the CC2642R1 sensor controller.pdf (252.64 KB)
dirtwillfly|  楼主 | 2019-10-25 21:13 | 只看该作者
BOOSTXL-ULPSENSE Quick start guide.pdf (922.02 KB)
dirtwillfly|  楼主 | 2019-10-25 21:17 | 只看该作者
BOOSTXL-ULPSENSE Design Files.zip (2.59 MB)
aoyi| | 2019-11-13 10:21 | 只看该作者
非常感谢分享
functions| | 2019-11-25 16:13 | 只看该作者
感谢分享!很好的资料
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
