新版本f_mount的用法
326|0
无幻|  楼主 | 2019-11-23 18:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
FRESULT f_mount (
                               FATFS* fs,                         /* Pointer to the file system object (NULL:unmount)*/
                               const TCHAR* path,          /* Logical drive number to be mounted/unmounted */
                               BYTE opt                           /* 0o not mount (delayed mount), 1:Mount immediately */
请问调用时怎么写 path?
                             如果在diskio.c这样定义的:
        /* Definitions of physical drive number for each drive */
        #define    ATA      0                 /* Example: Map ATA harddisk to physical drive 0 */
        #define    MMC     1                /* Example: Map MMC/SD card to physical drive 1 */
        #define    USB      2                /* Example: Map USB MSD to physical drive 2 */
那么调用时就应该是f_mount(&fs,"1", 0),  ''1''表示MMC/SD卡,请问我这样理解对吗?
另外 opt   应该写0还是写1呢?
