NK-980IOT 启动输出信息
620|0
dirtwillfly|  楼主 | 2022-3-8 18:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
NUC980 IBR 20180813
Boot from SPI-NAND
DDR-OK
finish SPI dow�ad
SPL load main U-Boot from SPI NAND Flash! (Feb 20 2019 09:12:29)
U-Boot 2016.11-g8127c47 (Feb 20 2019 - 09:12:26 +0800)
CPU: NUC980
Board: NUC980
DRAM:  64 MiB
SF: Detected W25N01GV with page size 2 KiB, erase size 128 KiB, total 128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot:  0
device 0 offset 0x200000, size 0x800000
SF: 8388608 bytes [url=home.php?mod=space&uid=72445]@[/url] 0x200000 Read: OK
## Booting kernel from Legacy Image at 00007fc0 ...
   Image Name:   Linux-4.4.115+
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    6491248 Bytes = 6.2 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
Starting kernel ...
SF: DeviceBooting Linux on physical CPU 0x0
Linux version 4.4.115+ (andy@YA-T470P) (gcc version 4.8.4 (GCC) ) #215 PREEMPT Wed Mar 6 09:43:03 CST 2019
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
CPU: VIVT data cache, VIVT instruction cache
Machine: NUC980
Memory policy: Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: root=/dev/ram0 console=ttyS0,115200n8 rdinit=/sbin/init mem=64M
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 55828K/65536K available (3306K kernel code, 269K rwdata, 1068K rodata, 4200K init, 209K bss, 9708K reserved, 0K cma-reserved)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
    lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc044df4c   (4376 kB)
      .init : 0xc044e000 - 0xc0868000   (4200 kB)
      .data : 0xc0868000 - 0xc08ab6c0   ( 270 kB)
       .bss : 0xc08ab6c0 - 0xc08dfe84   ( 210 kB)
SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
        Build-time adjustment of leaf fanout to 32.
NR_IRQS:545
clocksource: nuc980-timer5: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 62215505635 ns
sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 21474836475000000ns
Console: colour dummy device 80x30
console [ttyS0] enabled
Calibrating delay loop... 148.88 BogoMIPS (lpj=744448)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0x8400 - 0x843c
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 256 (order: -1, 3072 bytes)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource nuc980-timer5
NET: Registered protocol family 2
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
NetWinder Floating Point Emulator V0.97 (double precision)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered (default)
nuc980_gpio_probe - pdev = nuc980-gpio
nuc980_dma_probe - pdev = nuc980-dma
nuc980-dma nuc980-dma: NUC980 DMA ready
nuc980-uart.0: ttyS0 at I/O 0x0 (irq = 36, base_baud = 750000) is a NUC980
nuc980-uart.1: ttyS1 at I/O 0x0 (irq = 37, base_baud = 9375000) is a NUC980
brd: module loaded
RX nuc980_qspi0_probe: dma0chan0 module removed
TX nuc980_qspi0_probe: dma0chan1 module removed
RX nuc980_spi0_probe: dma0chan2 module removed
TX nuc980_spi0_probe: dma0chan3 module removed
m25p80 spi1.0: unrecognized JEDEC id bytes: ff, ff, ff
m25p80: probe of spi1.0 failed with error -2
libphy: nuc980_rmii0: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
nuc980-ehci nuc980-ehci: Nuvoton NUC980 EHCI Host Controller
nuc980-ehci nuc980-ehci: new USB bus registered, assigned bus number 1
nuc980-ehci nuc980-ehci: irq 23, io mem 0xb0015000
nuc980-ehci nuc980-ehci: USB 2.0 started, EHCI 0.95
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
usb_hcd_nuc980_probe, id = 0, name: nuc980-ohci.0
nuc980-ohci nuc980-ohci.0: Nuvoton NUC980 OHCI Host Controller
nuc980-ohci nuc980-ohci.0: new USB bus registered, assigned bus number 2
nuc980-ohci nuc980-ohci.0: irq 24, io mem 0xb0017000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 8 ports detected
usb_hcd_nuc980_probe, id = 1, name: nuc980-ohci.1
usb_hcd_nuc980_probe, id = 2, name: nuc980-ohci.2
usb_hcd_nuc980_probe, id = 3, name: nuc980-ohci.3
usb_hcd_nuc980_probe, id = 4, name: nuc980-ohci.4
usb_hcd_nuc980_probe, id = 5, name: nuc980-ohci.5
usb_hcd_nuc980_probe, id = 6, name: nuc980-ohci.6
usbcore: registered new interface driver usb-storage
nuc980-i2c0 nuc980-i2c0: i2c-0: nuc980 I2C adapter
nuc980-i2c2 nuc980-i2c2: i2c-2: nuc980 I2C adapter
nuc980_sd_probe - pdev = nuc980-sdh
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
nand: device found, Manufacturer ID: 0xef, Chip ID: 0xaa
nand: Winbond W25N01GV 1G 3.3V
nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
nand: WARNING: spi0.0: the ECC used on your system is too weak compared to the one required by the NAND chip
Scanning device for bad blocks
random: nonblocking pool is initialized
Creating 3 MTD partitions on "spi0.0":
0x000000000000-0x000000200000 : "u-boot"
0x000000200000-0x000001600000 : "Kernel"
0x000001600000-0x000008000000 : "user"
nuc980-nadc: nuc980 Normal ADC adapter
nuc980-audio nuc980-audio: nau8822-hifi <-> nuc980-audio-i2s mapping ok
NET: Registered protocol family 17
ALSA device list:
  #0: nuc980_IIS
Freeing unused kernel memory: 4200K
BusyBox v1.22.1 (2016-02-03 14:11:04 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
