[PCB]
QCA9880 802.11ac-Mini-PCIe-WiFi-Module-Dual-Band-2-4GHz-5GHz.wallys
713|0
QCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024/QCA9531
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
FCC,CE and IC Certification
    Specifications
    Symbol
    Parameter
    Chipset
    QCA9880
    Host Interface
    Mini PCI Express 1.1 Standard
    Antenna Connector
    3 x UF.L
    Frequency Range
    2.4GHz: 2.412GHz to 2.472GHz
    5GHz: 4.920GHz to 5.825GHz
    Operating Voltage
    3.3V DC
    Power Consumption
    5W(Max)
    Modulation Techniques
    OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
    Environmental Temperature
    Operating: -40°C to 70°C, Storage: -40°C to 90°C
    Environmental Humidity, non-condensing
    Operating: 5% to 95%, Storage: Max. 90%
    ROHS Compliance
    YES
    Dimensions (W×H×D)
    30.0mm × 50.9mm × 3.2mm
    RF Performance Table
    Operating Mode
    Data Rate
    TX Power
    Tolerance
    1 Chain
    3 Chains
    2.4 GHz
    802.11b
    1Mbps
    20dBm
    25dBm
    ±2dB
    2Mbps
    20dBm
    25dBm
    ±2dB
    5.5Mbps
    20dBm
    25dBm
    ±2dB
    11Mbps
    20dBm
    25dBm
    ±2dB
    2.4 GHz
    802.11g
    6Mbps
    21dBm
    26dBm
    ±2dB
    9Mbps
    21dBm
    26dBm
    ±2dB
    12Mbps
    21dBm
    26dBm
    ±2dB
    18Mbps
    21dBm
    26dBm
    ±2dB
    24Mbps
    21dBm
    26dBm
    ±2dB
    36Mbps
    20dBm
    25dBm
    ±2dB
    48Mbps
    19dBm
    24dBm
    ±2dB
    54Mbps
    19dBm
    24dBm
    ±2dB
    2.4 GHz
    802.11n HT20
    MCS0
    21dBm
    26dBm
    ±2dB
    MCS1
    21dBm
    26dBm
    ±2dB
    MCS2
    21dBm
    26dBm
    ±2dB
    MCS3
    20dBm
    25dBm
    ±2dB
    MCS4
    20dBm
    25dBm
    ±2dB
    MCS5
    20dBm
    25dBm
    ±2dB
    MCS6
    19dBm
    24dBm
    ±2dB
    MCS7
    18dBm
    23dBm
    ±2dB
    2.4 GHz
    802.11n HT40
    MCS0
    21dBm
    26dBm
    ±2dB
    MCS1
    21dBm
    26dBm
    ±2dB
    MCS2
    21dBm
    26dBm
    ±2dB
    MCS3
    20dBm
    25dBm
    ±2dB
    MCS4
    20dBm
    25dBm
    ±2dB
    MCS5
    20dBm
    25dBm
    ±2dB
    MCS6
    19dBm
    24dBm
    ±2dB
    MCS7
    18dBm
    23dBm
    ±2dB
    Operating Mode
    Data Rate
    RX Sensitivity
    Tolerance
    2.4 GHz
    802.11b
    1Mbps
    -95dBm
    ±2dB
    2Mbps
    -94dBm
    ±2dB
    5.5Mbps
    -92dBm
    ±2dB
    11Mbps
    -90dBm
    ±2dB
    2.4 GHz
    802.11g
    6Mbps
    -94dBm
    ±2dB
    9Mbps
    -93dBm
    ±2dB
    12Mbps
    -92dBm
    ±2dB
    18Mbps
    -90dBm
    ±2dB
    24Mbps
    -88dBm
    ±2dB
    36Mbps
    -85dBm
    ±2dB
    48Mbps
    -81dBm
    ±2dB
    54Mbps
    -80dBm
    ±2dB
    2.4 GHz
    802.11n HT20
    MCS0
    -93dBm
    ±2dB
    MCS1
    -91dBm
    ±2dB
    MCS2
    -89dBm
    ±2dB
    MCS3
    -84dBm
    ±2dB
    MCS4
    -83dBm
    ±2dB
    MCS5
    -78dBm
    ±2dB
    MCS6
    -78dBm
    ±2dB
    MCS7
    -76dBm
    ±2dB
    2.4 GHz
    802.11n HT40
    MCS0
    -92dBm
    ±2dB
    MCS1
    -88dBm
    ±2dB
    MCS2
    -85dBm
    ±2dB
    MCS3
    -82dBm
    ±2dB
    MCS4
    -79dBm
    ±2dB
    MCS5
    -75dBm
    ±2dB
    MCS6
    -75dBm
    ±2dB
    MCS7
    -73dBm
    ±2dB
    Operating Mode
    Data Rate
    TX Power
    Tolerance
    1 Chain
    3 Chains
    5 GHz
       802.11a
    6Mbps
    20dBm
    25dBm
    ±2dB
    9Mbps
    20dBm
    25dBm
    ±2dB
    12Mbps
    20dBm
    25dBm
    ±2dB
    18Mbps
    20dBm
    25dBm
    ±2dB
    24Mbps
    20dBm
    25dBm
    ±2dB
    36Mbps
    18dBm
    23dBm
    ±2dB
    48Mbps
    16dBm
    21dBm
    ±2dB
    54Mbps
    15dBm
    20dBm
    ±2dB
    5 GHz
       802.11n/ac HT20
    MCS0
    19dBm
    24dBm
    ±2dB
    MCS1
    19dBm
    24dBm
    ±2dB
    MCS2
    19dBm
    24dBm
    ±2dB
    MCS3
    18dBm
    23dBm
    ±2dB
    MCS4
    18dBm
    23dBm
    ±2dB
    MCS5
    17dBm
    22dBm
    ±2dB
    MCS6
    16dBm
    21dBm
    ±2dB
    MCS7
    16dBm
    21dBm
    ±2dB
    MCS8
    15dBm
    20dBm
    ±2dB
    5 GHz
       802.11n/ac HT40
    MCS0
    18dBm
    23dBm
    ±2dB
    MCS1
    18dBm
    23dBm
    ±2dB
    MCS2
    18dBm
    23dBm
    ±2dB
    MCS3
    17dBm
    22dBm
    ±2dB
    MCS4
    17dBm
    22dBm
    ±2dB
    MCS5
    16dBm
    21dBm
    ±2dB
    MCS6
    16dBm
    21dBm
    ±2dB
    MCS7
    16dBm
    21dBm
    ±2dB
    MCS8
    15dBm
    20dBm
    ±2dB
    MCS9
    15dBm
    20dBm
    ±2dB
    5 GHz
       802.11n/ac HT80
    MCS0
    18dBm
    23dBm
    ±2dB
    MCS1
    18dBm
    23dBm
    ±2dB
    MCS2
    18dBm
    23dBm
    ±2dB
    MCS3
    17dBm
    22dBm
    ±2dB
    MCS4
    17dBm
    22dBm
    ±2dB
    MCS5
    16dBm
    21dBm
    ±2dB
    MCS6
    16dBm
    21dBm
    ±2dB
    MCS7
    15dBm
    20dBm
    ±2dB
    MCS8
    15dBm
    20dBm
    ±2dB
    MCS9
    15dBm
    20dBm
    ±2dB
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
