[放大器-信号链]
PGA280 ADS1259
2637|4
jhbang|  楼主 | 2012-4-12 17:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
jeff-wang| | 2012-4-13 18:31 | 只看该作者
你是PLC的应用吗?很好的方案,标准的SPI接口,程序网上可以找到。
PGA280 + ADS1259 has been designed to work together to create one easy solution for high resolution/high voltage industrial applications.
2 Channel, fast, MUX PGA front end for multi channel control with Single Cycle settling ADC for enhanced throughput in MUX
Fully differential +/-15V PGA signal swing for seamless ADS input
ADS1259 clock output to synchronize the PGA280 input chopping to preserve the low noise performance.
Low 1/f noise of PGA for 24 bit high resolution and sensitivity of ADC
High PGA CMRR + ADC Digital filter for 16, 50, 60, or 400Hz rejection
jeff-wang| | 2012-4-13 18:40 | 只看该作者
这有个下载的链接,GPIO模拟SPI,
http://wenku.baidu.com/view/3aec66d349649b6648d74768.html
评分
参与人数 1威望 +1 收起 理由
jhbang + 1
jhbang|  楼主 | 2012-4-16 16:56 | 只看该作者
谢谢,找到原因了,在连续操作PGA280时,不能一直将CS引脚置低电平。
jhbang|  楼主 | 2012-4-20 09:09 | 只看该作者
如何操作ADS1259,求例程
