[CPLD]
CPLD驱动PCF8591ADC采样老是零
733|0
比神乐|  楼主 | 2023-4-29 13:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我买了一个PCF8591模块,用单片机是正常的。
我写了一个CPLD读PCF8591的ADC值的程序,可是读出来老是零。
代码如下:
module i2c(clk,rst,scl,sda,lcd_en ,
                lcd_rw ,  //��Ϊִֻ��д������������ԶΪ0.
                lcd_rs ,
                lcd_data,led1,led2,led3,led4,adc_data);
input clk,rst;
output scl;
inout  sda;
output led1,led2,led3,led4;
output adc_data;
output       lcd_en ;
output       lcd_rw ;
output       lcd_rs ;
output [7:0] lcd_data;
reg scl;
reg adc_data;
reg ledn1,ledn2,ledn3,ledn4;
reg[23:0] cnt_scan;
reg sda_buf;
reg link;
reg phase0,phase1,phase2,phase3;
reg[7:0] clk_div;
reg[1:0] main_state;
reg[3:0] i2c_state;
reg[3:0] inner_state;
reg[19:0] cnt_delay;
reg start_delaycnt;
reg[7:0] readData_reg;
reg[7:0] addr;
                //按键检测
reg[19:0] cnt_20ms;        //20ms计数寄存器
always [url=home.php?mod=space&uid=72445]@[/url] (posedge clk or negedge rst)
        if(!rst) cnt_20ms <= 20'd0;
        else cnt_20ms <= cnt_20ms+1'b1;        //不断计数
parameter div_parameter=100;
parameter  start=4'b0000,
                          first=4'b0001,
                          second=4'b0010,
                          third=4'b0011,
                          fourth=4'b0100,
                          fifth=4'b0101,
                          sixth=4'b0110,
                          seventh=4'b0111,
                          eighth=4'b1000,
                          ack=4'b1001,
                          stop=4'b1010;
parameter ini=4'b0000,
                  sendaddr=4'b0001,
                  //write_data=3'b010,
                  read_data=4'b0010,
                  read_ini=4'b0011,
                  read_s1=4'b0100,
                  read_s2=4'b0101,
                  read_s3=4'b0110,
                  read_s4=4'b0111,
                  read_s5=4'b1000,
                  read_s6=4'b1001,
                  read_s7=4'b1010,
                  read_s8=4'b1011,
                  read_s9=4'b1100,
                  read_s10=4'b1101,
                  read_s11=4'b1110,
                  read_s12=4'b1111;
wire         lcd_en ;
wire         lcd_rw;
reg  [7:0]   lcd_data;
reg          lcd_rs  ;
reg [5:0]    c_state ;
reg [5:0]    n_state ;
wire  [127:0]  row_1;
wire  [127:0]  row_2;
//reg[7:0] dis_data=0;
assign row_1 [127:120]=8'h30+adc_data/100;
assign row_1 [119:112]=8'h30+adc_data%100/10;
assign row_1 [111:104]=8'h30+adc_data%10;
assign row_1 [103:96]=8'h20;
assign row_1 [95:88]=8'h20;
assign row_1 [87:80]=8'h20;
assign row_1 [79:72]=8'h20;
assign row_1 [71:64]=8'h20;
assign row_1 [63:56]=8'h20;
assign row_1 [55:48]=8'h20;
assign row_1 [47:40]=8'h41;
assign row_1 [39:32]=8'h42;
assign row_1 [31:24]=8'h43;
assign row_1 [23:16]=8'h44;
assign row_1 [15:8]=8'h45;
assign row_1 [7:0]=8'h46;
//assign row_1 ="                " ;  //��һ����ʾ������
assign row_2 ="happy everyday !";  //�ڶ�����ʾ������
//initialize
//first step is waitng more than 20 ms. �����ֲ�Ҫ���ģ�Ŀ���ǵȴ�ϵͳ�ϵ��ȶ���
parameter TIME_20MS = 1000_000 ; //20000000/20=1000_000
parameter TIME_200MS = 1000_0000_0 ; //20000000/20=1000_000
//parameter TIME_15MS = 9'h100 ; //just for test
parameter TIME_500HZ= 100_000  ; //
//parameter TIME_500HZ= 4'hf;  //just for test
//use gray code
parameter         IDLE=    8'h00  ;  //��Ϊ��״̬��һ����40��״̬�������������˸����룬һ��ֻ��1λ�����ı䡣00 01 03 02
parameter SET_FUNCTION=    8'h01  ;
parameter     DISP_OFF=    8'h03  ;
parameter   DISP_CLEAR=    8'h02  ;
parameter   ENTRY_MODE=    8'h06  ;
parameter   DISP_ON   =    8'h07  ;
parameter    ROW1_ADDR=    8'h05  ;
parameter       ROW1_0=    8'h04  ;
parameter       ROW1_1=    8'h0C  ;
parameter       ROW1_2=    8'h0D  ;
parameter       ROW1_3=    8'h0F  ;
parameter       ROW1_4=    8'h0E  ;
parameter       ROW1_5=    8'h0A  ;
parameter       ROW1_6=    8'h0B  ;
parameter       ROW1_7=    8'h09  ;
parameter       ROW1_8=  8'h08  ;
parameter       ROW1_9=    8'h18  ;
parameter       ROW1_A=    8'h19  ;
parameter       ROW1_B=    8'h1B  ;
parameter       ROW1_C=    8'h1A  ;
parameter       ROW1_D=    8'h1E  ;
parameter       ROW1_E=    8'h1F  ;
parameter       ROW1_F=    8'h1D  ;
parameter    ROW2_ADDR=    8'h1C  ;
parameter       ROW2_0=    8'h14  ;
parameter       ROW2_1=    8'h15  ;
parameter       ROW2_2=    8'h17  ;
parameter       ROW2_3=    8'h16  ;
parameter       ROW2_4=    8'h12  ;
parameter       ROW2_5=    8'h13  ;
parameter       ROW2_6=    8'h11  ;
parameter       ROW2_7=    8'h10  ;
parameter       ROW2_8=    8'h30  ;
parameter       ROW2_9=    8'h31  ;
parameter       ROW2_A=    8'h33  ;
parameter       ROW2_B=    8'h32  ;
parameter       ROW2_C=    8'h36  ;
parameter       ROW2_D=    8'h37  ;
parameter       ROW2_E=    8'h35  ;
parameter       ROW2_F=    8'h34  ;
//20ms�ļ��������ʼ����һ��
reg [19:0] cnt_20ms1 ;
always  @(posedge clk or negedge rst)begin
    if(rst==1'b0)begin
        cnt_20ms1<=0;
    end
    else if(cnt_20ms1 == TIME_20MS -1)begin
        cnt_20ms1<=cnt_20ms1;
    end
    else
        cnt_20ms1<=cnt_20ms1 + 1 ;
end
wire delay_done = (cnt_20ms1==TIME_20MS-1)? 1'b1 : 1'b0 ;
//500ns  �����Ƿ�Ƶ����ΪLCD1602�Ĺ���Ƶ����500HZ,��FPGA��50Mhz,����Ҫ��Ƶ
reg [19:0] cnt_500hz;
    if(rst==1'b0)begin
        cnt_500hz <= 0;
    end
    else if(delay_done==1)begin
        if(cnt_500hz== TIME_500HZ - 1)
            cnt_500hz<=0;
        else
            cnt_500hz<=cnt_500hz + 1 ;
    end
    else
        cnt_500hz<=0;
end
reg [28:0] cnt_200ms ;
    if(rst==1'b0)begin
        cnt_200ms<=0;
    end
    else if(cnt_200ms == TIME_200MS -1)begin
        cnt_200ms<=0;
    end
    else
        cnt_200ms<=cnt_200ms + 1 ;
end
assign lcd_en = (cnt_500hz>(TIME_500HZ-1)/2)? 1'b0 : 1'b1;  //�½���
assign write_flag = (cnt_500hz==TIME_500HZ - 1) ? 1'b1 : 1'b0 ;
//set_function ,display off ��display clear ,entry mode set
    if(rst==1'b0)begin
        c_state <= IDLE    ;
    end
    else if(write_flag==1) begin
        c_state<= n_state  ;
    end
    else
        c_state<=c_state   ;
end
always  @(*)begin
    case (c_state)
        IDLE: n_state = SET_FUNCTION ;
SET_FUNCTION: n_state = DISP_OFF     ;
    DISP_OFF: n_state = DISP_CLEAR   ;
  DISP_CLEAR: n_state = ENTRY_MODE   ;
  ENTRY_MODE: n_state = DISP_ON      ;
  DISP_ON   : n_state = ROW1_ADDR    ;
   ROW1_ADDR: n_state = ROW1_0       ;
      ROW1_0: n_state = ROW1_1       ;
      ROW1_1: n_state = ROW1_2       ;
      ROW1_2: n_state = ROW1_3       ;
      ROW1_3: n_state = ROW1_4       ;
      ROW1_4: n_state = ROW1_5       ;
      ROW1_5: n_state = ROW1_6       ;
      ROW1_6: n_state = ROW1_7       ;
      ROW1_7: n_state = ROW1_8       ;
      ROW1_8: n_state = ROW1_9       ;
      ROW1_9: n_state = ROW1_A       ;
      ROW1_A: n_state = ROW1_B       ;
      ROW1_B: n_state = ROW1_C       ;
      ROW1_C: n_state = ROW1_D       ;
      ROW1_D: n_state = ROW1_E       ;
      ROW1_E: n_state = ROW1_F       ;
      ROW1_F: n_state = ROW2_ADDR    ;
   ROW2_ADDR: n_state = ROW2_0       ;
      ROW2_0: n_state = ROW2_1       ;
      ROW2_1: n_state = ROW2_2       ;
      ROW2_2: n_state = ROW2_3       ;
      ROW2_3: n_state = ROW2_4       ;
      ROW2_4: n_state = ROW2_5       ;
      ROW2_5: n_state = ROW2_6       ;
      ROW2_6: n_state = ROW2_7       ;
      ROW2_7: n_state = ROW2_8       ;
      ROW2_8: n_state = ROW2_9       ;
      ROW2_9: n_state = ROW2_A       ;
      ROW2_A: n_state = ROW2_B       ;
      ROW2_B: n_state = ROW2_C       ;
      ROW2_C: n_state = ROW2_D       ;
      ROW2_D: n_state = ROW2_E       ;
      ROW2_E: n_state = ROW2_F       ;
      ROW2_F: n_state = ROW1_ADDR    ;
     default: n_state = n_state      ;
   endcase
   end
   assign lcd_rw = 0;
       if(rst==1'b0)begin
           lcd_rs <= 0 ;   //order or data  0: order 1:data
       end
       else if(write_flag == 1)begin
           if((n_state==SET_FUNCTION)||(n_state==DISP_OFF)||
              (n_state==DISP_CLEAR)||(n_state==ENTRY_MODE)||
              (n_state==DISP_ON ) ||(n_state==ROW1_ADDR)||
              (n_state==ROW2_ADDR))begin
           lcd_rs<=0 ;
           end
           else  begin
           lcd_rs<= 1;
           end
       end
       else begin
           lcd_rs<=lcd_rs;
       end
   end
       if(rst==1'b0)begin
           lcd_data<=0 ;
       end
       else  if(write_flag)begin
           case(n_state)
                 IDLE: lcd_data <= 8'hxx;
         SET_FUNCTION: lcd_data <= 8'h38; //2*16 5*8 8λ����
             DISP_OFF: lcd_data <= 8'h08;
           DISP_CLEAR: lcd_data <= 8'h01;
           ENTRY_MODE: lcd_data <= 8'h06;
           DISP_ON   : lcd_data <= 8'h0c;  //��ʾ���ܿ���û�й��꣬�Ҳ���˸��
            ROW1_ADDR: lcd_data <= 8'h80; //00+80
               ROW1_0: lcd_data <= row_1 [127:120];
               ROW1_1: lcd_data <= row_1 [119:112];
               ROW1_2: lcd_data <= row_1 [111:104];
               ROW1_3: lcd_data <= row_1 [103: 96];
               ROW1_4: lcd_data <= row_1 [ 95: 88];
               ROW1_5: lcd_data <= row_1 [ 87: 80];
               ROW1_6: lcd_data <= row_1 [ 79: 72];
               ROW1_7: lcd_data <= row_1 [ 71: 64];
               ROW1_8: lcd_data <= row_1 [ 63: 56];
               ROW1_9: lcd_data <= row_1 [ 55: 48];
               ROW1_A: lcd_data <= row_1 [ 47: 40];
               ROW1_B: lcd_data <= row_1 [ 39: 32];
               ROW1_C: lcd_data <= row_1 [ 31: 24];
               ROW1_D: lcd_data <= row_1 [ 23: 16];
               ROW1_E: lcd_data <= row_1 [ 15:  8];
               ROW1_F: lcd_data <= row_1 [  7:  0];
            ROW2_ADDR: lcd_data <= 8'hc0;      //40+80
               ROW2_0: lcd_data <= row_2 [127:120];
               ROW2_1: lcd_data <= row_2 [119:112];
               ROW2_2: lcd_data <= row_2 [111:104];
               ROW2_3: lcd_data <= row_2 [103: 96];
               ROW2_4: lcd_data <= row_2 [ 95: 88];
               ROW2_5: lcd_data <= row_2 [ 87: 80];
               ROW2_6: lcd_data <= row_2 [ 79: 72];
               ROW2_7: lcd_data <= row_2 [ 71: 64];
               ROW2_8: lcd_data <= row_2 [ 63: 56];
               ROW2_9: lcd_data <= row_2 [ 55: 48];
               ROW2_A: lcd_data <= row_2 [ 47: 40];
               ROW2_B: lcd_data <= row_2 [ 39: 32];
               ROW2_C: lcd_data <= row_2 [ 31: 24];
               ROW2_D: lcd_data <= row_2 [ 23: 16];
               ROW2_E: lcd_data <= row_2 [ 15:  8];
               ROW2_F: lcd_data <= row_2 [  7:  0];
           endcase
       end
       else
              lcd_data<=lcd_data ;
   end
assign sda=(link)? sda_buf:1'bz;
reg [19:0] tics;
begin
        if(!rst)
                tics<=0;
        else if(tics==20'hfffff)
                        tics<=0;
        else
                tics<=tics+1;
end
always@(posedge clk or negedge rst)
begin
        if(!rst)
                cnt_delay<=0;
        else begin
                if(start_delaycnt) begin
                        if(cnt_delay!=20'd80)
                                cnt_delay<=cnt_delay+1;
                        else
                                cnt_delay<=0;
                 end
         end
end
begin
        if(!rst) begin
                clk_div<=0;
                phase0<=0;
                phase1<=0;
                phase2<=0;
                phase3<=0;
         end
        else begin
                if(clk_div!=div_parameter-1)
                        clk_div<=clk_div+1;
                else
                        clk_div<=0;
                if(phase0)
                        phase0<=0;
                else if(clk_div==99)
                        phase0<=1;
                if(phase1)
                        phase1<=0;
                else if(clk_div==24)
                        phase1<=1;
                if(phase2)
                        phase2<=0;
                else if(clk_div==49)
                        phase2<=1;
                if(phase3)
                        phase3<=0;
                else if(clk_div==74)
                        phase3<=1;
         end
end
///////////////////////////EEPROM/////////////
begin
        if(!rst) begin
                start_delaycnt<=0;
                main_state<=2'b00;
                i2c_state<=ini;
                inner_state<=start;
                scl<=1;
                sda_buf<=1;
                link<=0;
                ledn1<=1;
                ledn2<=1;
                ledn3<=1;
                ledn4<=1;
                readData_reg<=0;
                addr<=8'h40;
         end
        else begin
                case(main_state)
                        2'b00: begin
                                scl<=1;
                                sda_buf<=1;
                                link<=0;
                                inner_state<=start;
                                i2c_state<=ini;
                                if(cnt_delay==0)
                                                start_delaycnt<=1;
                                else if(cnt_delay==20'd80) begin
                                                start_delaycnt<=0;
                                                        main_state<=2'b10;
                                 end
                         end
                        2'b10: begin
                                if(phase0)
                                        scl<=1;
                                else if(phase2)
                                        scl<=0;
                                case(i2c_state)
                                ini: begin
                                        case(inner_state)
                                                start: begin
                                                        if(phase1) begin
        link<=1;
        sda_buf<=0;
                                                         end
                                                        if(phase3&&link) begin
        inner_state<=first;
        sda_buf<=1;
        link<=1;
                                                         end
                                                 end
                                                first:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
        inner_state<=second;
                                                         end
                                                second:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
        inner_state<=third;
                                                         end
                                                third:
                                                        if(phase3) begin
        sda_buf<=1;
        link<=1;
        inner_state<=fourth;
                                                         end
                                                fourth:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
        inner_state<=fifth;
                                                         end
                                                fifth:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
        inner_state<=sixth;
                                                         end
                                                sixth:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
        inner_state<=seventh;
                                                         end
                                                seventh:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
        inner_state<=eighth;
                                                         end
                                                eighth:
                                                        if(phase3) begin
        link<=0;
        inner_state<=ack;
                                                         end
                                                ack: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
        if(sda_buf==1)
        //begin
        main_state<=2'b00;
        //main_state<=2'b11;
                                                         end
                                                        if(phase3) begin
        link<=1;
        sda_buf<=addr[7];
        inner_state<=first;
        i2c_state<=sendaddr;
                                                        end
                                                 end
                                        endcase
                                end
                                sendaddr: begin
                                        case(inner_state)
                                                first:
                                                        if(phase3) begin
        link<=1;
        sda_buf<=addr[6];
                                                         end
                                                second:
                                                        if(phase3) begin
        link<=1;
        sda_buf<=addr[5];
        inner_state<=third;
                                                         end
                                                third:
                                                        if(phase3) begin
        link<=1;
        sda_buf<=addr[4];
                                                         end
                                                fourth:
                                                        if(phase3) begin
        link<=1;
        sda_buf<=addr[3];
        inner_state<=fifth;
                                                         end
                                                fifth:
                                                        if(phase3) begin
        link<=1;
        sda_buf<=addr[2];
        inner_state<=sixth;
                                                         end
                                                sixth:
                                                        if(phase3) begin
        link<=1;
        sda_buf<=addr[1];
                                                         end
                                                seventh:
                                                        if(phase3) begin
        link<=1;
        sda_buf<=addr[0];
                                                         end
                                                eighth:
                                                        if(phase3) begin
        link<=0;
        inner_state<=ack;
                                                         end
                                                ack: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
        if(sda_buf==1)
        main_state<=2'b00;
                                                         end
                                                        if(phase3) begin
        link<=1;
        sda_buf<=1;
        inner_state<=start;
        i2c_state<=read_ini;
                                                         end
                                                 end
                                         endcase
                                 end
                                read_ini: begin
                                case(inner_state)
                                                start: begin
                                                        if(phase1) begin
        link<=1;
        sda_buf<=0;
                                                         end
        inner_state<=first;
        sda_buf<=1;
        link<=1;
                                                         end
                                                 end
                                                first:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
                                                         end
                                                second:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
        inner_state<=third;
                                                         end
                                                third:
                                                        if(phase3) begin
        sda_buf<=1;
        link<=1;
                                                         end
                                                fourth:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
        inner_state<=fifth;
                                                         end
                                                fifth:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
        inner_state<=sixth;
                                                         end
                                                sixth:
                                                        if(phase3) begin
        sda_buf<=0;
        link<=1;
                                                        end
                                                seventh:
                                                        if(phase3) begin
        sda_buf<=1;
        link<=1;
                                                         end
                                                eighth:
                                                        if(phase3) begin
        link<=0;
        inner_state<=ack;
                                                         end
                                                ack: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
        if(sda_buf==1)
        main_state<=2'b00;
                                                         end
                                                        if(phase3) begin
        link<=0;
        inner_state<=first;
        i2c_state<=read_data;
                                                         end
                                                 end
                                        endcase
                                end
                                read_data: begin
                                        case(inner_state)
                                                first: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
        readData_reg[7:1]<=readData_reg[6:0];
        readData_reg[0]<=sda;
                                                         end
                                                        if(phase3)
                                                 end
                                                second: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
                                                         end
                                                        if(phase3)
        inner_state<=third;
                                                 end
                                                third: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
                                                         end
                                                        if(phase3)
                                                 end
                                                fourth: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
                                                         end
                                                        if(phase3)
        inner_state<=fifth;
                                                 end
                                                fifth: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
                                                         end
                                                        if(phase3)
        inner_state<=sixth;
                                                 end
                                                sixth: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
                                                         end
                                                        if(phase3)
                                                 end
                                                seventh: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
                                                         end
                                                        if(phase3)
                                                 end
                                                eighth: begin
                                                        if(phase0)
        sda_buf<=sda;
                                                        if(phase1) begin
                                                         end
                                                        if(phase3)
        inner_state<=ack;
                                                 end
                                                ack: begin
                                                        if(phase3) begin
        link<=1;
        sda_buf<=0;
        inner_state<=stop;
                                                         end
                                                 end
                                                stop: begin
                                                        /*if(phase1)
        sda_buf<=1;
        ledn1<=0;
                                                        if(phase3) begin
        link<=0;
        inner_state<=first;
        i2c_state<=read_s1;
        ledn2<=0;
                                                         end*/
                                                         ledn3<=1;
                                                         if(phase1)
        sda_buf<=1;
                                                        if(phase3)
        i2c_state<=read_s1;
                                                 end
                                                 default:
                                         endcase
                                 end
                         read_s1:
                                i2c_state<=read_s2;
                         read_s2:
                                i2c_state<=read_s3;
                         read_s3:
                                i2c_state<=read_s4;
                         read_s4:
                                i2c_state<=read_s5;
                         read_s5:
                                i2c_state<=read_s6;
                         read_s6:
                                i2c_state<=read_s7;
                         read_s7:
                                i2c_state<=read_s8;
                         read_s8:
                                i2c_state<=read_s9;
                         read_s9:
                                i2c_state<=read_s10;
                         read_s10:
                                i2c_state<=read_s11;
                         read_s11:
                                i2c_state<=read_s12;
                         read_s12:
                                begin
                                        if(tics[19])
                                                begin
                                                        adc_data<=readData_reg;
                                                        main_state<=2'b00;
                                                        i2c_state<=ini;
                                                        inner_state<=start;
                                                        ledn3<=0;
                                                end
                                        else
                                end
                         default:
                         endcase
                end
         endcase
end
end
assign led1=ledn1;
assign led2=ledn2;
assign led3=ledn3;
assign led4=ledn4;
endmodule
请高手指教,哪里有错?谢谢!我是参考例程AR24C04的程序改的。
