[活动专区]
【杰发科技AC7840x测评】+ SPI方式读U盘数据
545|0
tlled|  楼主 | 2023-12-16 11:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
测试开发板的SPI,使用SPI方式连接CH376模块读取U盘数据。
一、SPI硬件
连接CH376模块
二、程序部分
2.1、spi.c
#include "ac7840x.h"
#include "gpio_drv.h"
#include "osif.h"
#include "spi/spi.h"
#include "spi_hw.h"
#include "spi_master_drv.h"
#include "spi_slave_drv.h"
#include "port_hw.h"
#include "gpio_hw.h"
spi_master_config_t spiMasteConfig =
    .bitsPerSec = 2000000UL,                    /*! ÉèÖÃSPI²¨ÌØÂÊ*/
    .whichPcs = SPI_PCS2,                       /*! ÉèÖÃSPIƬѡÒý½Å*/
    .pcsPolarity = SPI_ACTIVE_LOW,              /*! ÉèÖÃSPIƬѡµÍÓÐЧ*/
    .isPcsContinuous = true,                    /*! ÉèÖÃƬѡÁ¬Ðøģʽ*/
    .bitcount = 8UL,                            /*! SPI Ö¡³¤¶È,Ö§³Ö 4~32 bits*/
    .spiSrcClk = 60000000UL,                    /*! SPIʱÖÓԴƵÂÊ*/
    .clkPhase = SPI_CLOCK_PHASE_1ST_EDGE,       /*! ÉèÖÃÊý¾Ý²ÉÑùÏàλ,µÚ1¸ö±ßÑزÉÑùÊý¾Ý*/
    .clkPolarity = SPI_SCK_ACTIVE_HIGH,         /*! ÉèÖÃSCK¹¤×÷ʱ¼«ÐÔ,¹¤×÷ʱSCKΪ¸ß*/
    .msbFirst = true,                           /*! Ñ¡Ôñ´Ó×î¸ßλ¿ªÊ¼ÊÕ·¢*/
    .transferType = SPI_USING_INTERRUPTS,       /*! Ñ¡ÔñͨÐÅÀàÐÍΪÖжϷ½Ê½*/
    .rxDMAChannel = 1UL,                        /*! ÉèÖÃSPI DMA½ÓÊÕͨµÀ£¬ÈôδʹÓÃDMA·½Ê½´«Ê䣬Ôò¸ÃÅäÖÿɺöÂÔ*/
    .txDMAChannel = 0UL,                        /*! ÉèÖÃSPI DMA·¢ËÍͨµÀ£¬ÈôδʹÓÃDMA·½Ê½´«Ê䣬Ôò¸ÃÅäÖÿɺöÂÔ*/
    .callback = NULL,                           /*! ×¢²á»Øµ÷º¯Êý */
    .callbackParam = NULL,                      /*! »Øµ÷º¯Êý²ÎÊý */
static spi_state_t s_spiMasterState;
uint8_t g_spiTxBuff1[DATA_SIZE] = {1, 1, 3, 4, 5, 6, 7, 8};
uint8_t g_spiRxBuff1[DATA_SIZE] = {0};
static void SPI_Init_Gpio(void)
    GPIO_DRV_SetMuxModeSel(PORT_SPI_SCK, PIN_SPI_SCK, PORT_MUX_ALT3);        /*! SCK */
    GPIO_DRV_SetMuxModeSel(PORT_SPI_SOUT, PIN_SPI_SOUT, PORT_MUX_ALT3);      /*! SOUT */
    GPIO_DRV_SetMuxModeSel(PORT_SPI_SIN, PIN_SPI_SIN, PORT_MUX_ALT3);        /*! SIN */
    GPIO_DRV_SetMuxModeSel(PORT_SPI_CS, PIN_SPI_CS, PORT_MUX_ALT2);          /*! CS */
void SPI_Master_Init(void)
    SPI_Init_Gpio();                                                        /*! ³õʼ»¯¶ÔÓ¦Òý½ÅΪSPI¹¦ÄÜ */
    SPI_DRV_MasterInit(SPI_INSTANCE, &s_spiMasterState, &spiMasteConfig);   /*! SPIÖ÷»úģʽ³õʼ»¯ */
    NVIC_SetPriority(SPI_IRQ, 2);                                           /*! ÉèÖÃSPIÖжÏÓÅÏȼ¶ */
void init_spi(void)
        SPI_Master_Init();
uint8_t spi_readwrite(uint8_t dat)
        uint8_t ret;
        uint8_t rxdat=0;
        uint8_t g_spiTxBuff1[10];
        uint8_t g_spiRxBuff1[10];
        g_spiTxBuff1[0]=dat;
        ret=SPI_DRV_MasterTransferBlocking(SPI_INSTANCE, g_spiTxBuff1, g_spiRxBuff1, 1, SPI_TIMEOUT);
        if (ret != 0)
                        printf("transfer error, ret %d\n", ret);
        rxdat=g_spiRxBuff1[0];
        return rxdat;
2.2、ch376s.c
#include "ch376s.h"
uint8_t spi1_read_write_byte(uint8_t txdata)
    uint8_t rxdata;
    //HAL_SPI_TransmitReceive(&hspi1, &txdata, &rxdata, 1, 1000);
                rxdata=spi_readwrite(txdata);
    return rxdata; /* ·µ»ØÊÕµ½µÄÊý¾Ý */
uint8_t CH376_ReadWrite(uint8_t txdata)
        uint8_t rtdat;
        rtdat=spi1_read_write_byte(txdata);
        return rtdat;
uint8_t mInitCH376Host( void )
        uint8_t res;
        xWriteCH376Cmd( CMD11_CHECK_EXIST );                          /* ²âÊÔµ¥Æ¬»úÓëCH376Ö®¼äµÄͨѶ½Ó¿Ú */
        xWriteCH376Data( 0x65 );
        res = xReadCH376Data( );
        xEndCH376Cmd( );        // ½áÊøͨÐŲâÊÔ
        if ( res != 0x9A )
                printf("USBͨÐÅ´íÎó\r\n");
                return( ERR_USB_UNKNOWN );                                  /* ͨѶ½Ó¿Ú²»Õý³£,¿ÉÄÜÔ­ÒòÓÐ:½Ó¿ÚÁ¬½ÓÒì³£,ÆäËüÉ豸ӰÏì(Ƭѡ²»Î¨Ò»),´®¿Ú²¨ÌØÂÊ,Ò»Ö±ÔÚ¸´Î»,¾§Õñ²»¹¤×÷ */
        xWriteCH376Cmd( CMD11_SET_USB_MODE );                  /* É豸USB¹¤×÷ģʽ */
        xWriteCH376Data( 0x06 );                                                // ģʽ´úÂëΪ0x06,±íʾÇл»µ½ÒÑÆôÓõÄUSBÖ÷»ú·½Ê½£¬×Ô¶¯²úÉúSOF°ü
        mDelayuS( 200 );
        res = xReadCH376Data( );                                                // ·µ»Ø²Ù×÷״̬
        xEndCH376Cmd( );                                                            // ¹¤×÷ģʽÉèÖýáÊø
        if ( res == CMD_RET_SUCCESS )
        return( USB_INT_SUCCESS );
        else
                return( ERR_USB_UNKNOWN );                                  /* ÉèÖÃģʽ´íÎó */
uint8_t mWaitInterrupt( void )
{        /* µÈ´ýCH376Öжϲ¢»ñȡ״̬,Ö÷»ú¶ËµÈ´ý²Ù×÷Íê³É,·µ»Ø²Ù×÷״̬ */
while ( Query376Interrupt( ) == FALSE );                  /* Ò»Ö±µÈÖÐ¶Ï */
xWriteCH376Cmd( CMD_GET_STATUS );                          /* ²úÉú²Ù×÷Íê³ÉÖжÏ,»ñÈ¡ÖжÏ״̬ */
return( xReadCH376Data( ) );
void        xWriteCH376Cmd( uint8_t mCmd )  /* ÏòCH376дÃüÁî */
        CH376S_CS_HIGH();
        mDelay0_5uS( );
        CH376S_CS_LOW();
        CH376_ReadWrite( mCmd );  /* ·¢³öÃüÁîÂë */
void        xWriteCH376Data( uint8_t mData )  /* ÏòCH376дÊý¾Ý */
        CH376_ReadWrite( mData );
//        mDelay0_5uS( );  /* È·±£¶ÁдÖÜÆÚ´óÓÚ0.6uS */
uint8_t        xReadCH376Data( void )  /* ´ÓCH376¶ÁÊý¾Ý */
        return( CH376_ReadWrite( 0xff) );
uint8_t        Query376Interrupt( void )
        return( (GPIO_DRV_ReadPins(CH376S_INT_GPIO)& (1<<CH376S_INT_PIN))? FALSE : TRUE);
void mDelayuS(uint8_t us)
while(us--);
void mDelaymS(uint8_t ms)
unsigned int i;
for(;ms>0;ms--)
     for(i=0;i<940;i++);
void        mDelay0_5uS( void )  /* ÖÁÉÙÑÓʱ0.5uS,¸ù¾Ýµ¥Æ¬»úÖ÷Ƶµ÷Õû */
uint8_t i;
i=20;
while(i--);
void init_ch376s(void)
        uint8_t sta=0;
        init_spi();
        GPIO_DRV_SetMuxModeSel(CH376S_CS_PORT, CH376S_CS_PIN, PORT_MUX_AS_GPIO);
        GPIO_DRV_SetPinDirection(CH376S_CS_GPIO, CH376S_CS_PIN, 1);
        GPIO_DRV_SetMuxModeSel(CH376S_INT_PORT, CH376S_INT_PIN, PORT_MUX_AS_GPIO);
        GPIO_DRV_SetPinDirection(CH376S_INT_GPIO, CH376S_INT_PIN, 0); /*ÉèÖð´¼üÒý½ÅΪÊäÈë*/
        GPIO_DRV_SetPullSel(CH376S_INT_PORT, CH376S_INT_PIN, PORT_INTERNAL_PULL_UP_ENABLED);
        OSIF_TimeDelay(200);
        sta=mInitCH376Host();
        printf("mInitCH376Host()=%x\r\n",sta);
uint8_t buf[250];
uint16_t        RealCount;
void ch376s_test(void)
        uint8_t i=0;
        uint8_t sta=0;
        if(CH376DiskConnect()==USB_INT_SUCCESS)
                printf("check usb\r\n");
                OSIF_TimeDelay( 200 );
                printf("CH376DiskMount()=%x\r\n",CH376DiskMount());
                if(CH376DiskMount()==USB_INT_SUCCESS)
                        strcpy(buf, "ATC.TXT" );
                        if(CH376FileOpen(buf)==USB_INT_SUCCESS)
                                for(i=0;i<20;i++)
                                        buf[i]=0;
                                CH376ByteRead( buf, 20, &RealCount );
                                printf("buf=%s\r\n",buf);
        else
                printf("no check usb\r\n");
2.3、main.c
#include "clock_config.h"
#include "debugout_ac7840x.h"
#include "osif.h"
#include "led/led.h"
#include "key/key.h"
#include "adc/adc.h"
#include "ch376s.h"
void SystemClock_Config(void)
    CKGEN_SYS_Init(g_clockManConfigsArr, CLOCK_MANAGER_CONFIG_CNT,
                   g_clockManCallbacksArr, CLOCK_MANAGER_CALLBACK_CNT);
    CKGEN_DRV_UpdateConfiguration(0, CLOCK_MANAGER_POLICY_AGREEMENT);
int main(void)
        SystemClock_Config();
        init_led();
        init_key();
        init_adc();
        InitDebug();
        init_ch376s();
        ch376s_test();
        while (1)
                led3_on();
                OSIF_TimeDelay(100);
                led3_off();
                //ADC_TriggerTest();
三、运行结果
3.1、在U盘中创建ATX.TXT文件
3.2、串口打印读取U盘内容的数据
