[射频芯片]
三伍微SOI开关:GSR1303S 频段2.4G 兼容替代RTC6603
1879|0
pennyyao|  楼主 | 2024-2-2 10:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
GSR1303S: CMOS SOI SPDT Switch
0.1 – 3.0 GHz
Applications
l WLAN 802.11a/b/g/n/ac/ax networks
l ISM band radios
l Low power T/R systems
Features
lP0.1dB  +32dBm typical @ +3.3V
l Low insertion loss (0.4dB @ 2.5GHz)
l High isolation (24dB @ 2.5GHz)
l Low DC power consumption
l SC-70 6 lead Package (MSL1, 260°C per JEDEC-J-STD-020)
l ESD: 1.5 kV HBM on all pins
Description
The GSR1303S is a CMOS SOI single pole dual throw (SPDT) high power switch in a low cost miniature SC-70 6 lead package. The GSR1303S is ideally suited for applications where high power, low insertion loss, and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 3 GHz requiring high power at low control voltage.
