[全新]
ZCC66099 低功耗升压芯片替代SGM66099
193|0
SWdianzi|  楼主 | 2024-3-29 17:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
GENRAL DESCRIPTION
The ZCC66099 is a synchronous step-up converter with 0.65μA ultra low quiescent current. It is designed for products powered by alkaline battery, NiMH rechargeable battery, Li-Mn battery or rechargeable Li- lon battery, for which high efficiency under light load condition is critical to achieve long battery life operation. The ZCC66099 step-up converter only consumes
0.65μA quiescent current under light load condition and can achieve up to 75% efficiency at 10μA load with fixed output voltage version. It can also support up to300mA output current from 3.3V to 5V conversion, and achieve up to 93% at 200mAload.
The ZCC66099 also offers both down mode and pass- through operation for different applications. In down mode, the output voltage can still be regulated at target value even when input voltage is higher than output voltage. In pass-through mode, the output voltage follows input voltage. The ZCC66099 exits down mode and enters into pass-through mode when VIN> Vout+
0.3V.
The ZCC66099 supports true shutdown function when it is disabled, which disconnects the load from the input supply to reduce the current consumption.
The ZCC66099 offers both adjustable output voltage version and fixed output voltage versions. It is available in Green WLCSP-1.22x0.83-6B and TDFN-2x2-6AL packages.
FEATURES
●Operating Input Voltage Range:0.9V to 5.2V●Ultra Low Quiescent Current
0.6μA Ultra Low la into VOUT Pin
0.05μA Ultra Low lqinto VIN Pin●1.2MHz Fixed Frequency Operation
●Adjustable Output Voltage from2.5V to 5.2V●Fixed Output Voltage Versions Available
●Power-Save Mode for Improved Efficiency at Low Output Power
●Regulated Output Voltage in Down Mode●True Disconnection During Shutdown
●Up to 75% Efficiency at 10μA Load with Fixed Output Voltage Version
●Up to 93% Efficiency from 10mA to 300mALoad●-40°℃ to +85°C Operating Temperature Range●Available in Green WLCSP-1.22x0.83-6B and
TDFN-2x2-6AL Packages
APPLICATIONS
Memory LCD Bias
Optical Heart Rate Monitor LED Bias Wearable Applications
Low Power Wireless Applications Portable Products
Battery Powered Systems
