请问6455的Jtag Emulator问题
2380|0
gongfutea|  楼主 | 2007-2-5 12:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
dsp进不了Enulator 请问以下是什么原因造成的,请高人指点
(测到:sysClk正常,tck tdi正常,无tdo,而且clkout不稳定)
Error connecting to the target:
Error 0x80000240/-291
Fatal Error during: Initialization, OCS,
This error was generated by TI's USCIF driver.
SC_ERR_TST_MEASURE <-291>
The built-in scan-path length measurement has failed. This indicates
that the JTAG controller cannot reliably communicate with
the target DSP's and micro-controllers at that frequency.
Try specifying the scan-path lengths in the board configuration
file because the built-in scan-path reliability tests cannot be
performed without knowledge of the scan-path length.
Sequence ID: 0
Error Code: -291
Error Class: 0x80000240
Board Name: C6455 XDS560 Emulator
Cpu Name: C6400PLUS_0
Abort:  Close Code Composer Studio.
Retry:  Try to connect to the target again.
Cancel:  Remain disconnected from the target
Diagnostic: Run diagnostic utility.
