proteL99SE中PCB进行DRC时出现如下错误信息怎么回事?
4103|0
aluesnow|  楼主 | 2009-3-8 02:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Protel Design System Design Rule Check
PCB File : DocumentsPCB1.PCB
Date     : 7-Mar-2009
Time     : 21:02:31
Processing Rule : Width Constraint (Min=10mil) (Max=10mil) (Prefered=10mil) (Disabled)(On the board )
Rule Violations :0
Processing Rule : Width Constraint (Min=10mil) (Max=20mil) (Prefered=20mil) (On the board )
Rule Violations :0
Processing Rule : Room Sheet1 (Region = (-260mil, 203.238mil, -259.989mil, 2328.188mil) (has footprint 0805 And Is part of Component class All Components And Is in component C1 )
   Violation between Component C1(49560mil,49700mil)  TopLayer and
Rule Violations :1
Processing Rule : Hole Size Constraint (Min=1mil) (Max=100mil) (On the board )
Rule Violations :0
Processing Rule : Clearance Constraint (Gap=10mil) (On the board ),(On the board )
Rule Violations :0
Processing Rule : Broken-Net Constraint ( (On the board ) )
Rule Violations :0
Processing Rule : Short-Circuit Constraint (Allowed=Not Allowed) (On the board ),(On the board )
Rule Violations :0
Violations Detected : 1
