[Quartus] Quartus II安装程序为什么会要求安装已存在的32位库文件?
1385|0
 楼主| gaochy1126 发表于 2015-7-21 10:27 | 显示全部楼层 |阅读模式
Description
由于Quartus® II 12.0安装脚本中的一个问题,在RedHat 5或者CentOS 5操作系统中,安装程序无**确检测到某些已经安装的32位库文件。由此,Quartus II安装脚本会提示用户安装丢失的32位库文件,即使这些文件已经被安装在系统中。
Workaround / Fix
To work around this problem, perform one of the following two steps:
  • If you know that the 32-bit libraries are already installed, enter [size=1em]y to ignore the warning and proceed with the installation. To see a list of installed libraries, run
    [size=1em]yum list glibc libXext libX11 libXau libXdmcp freetype fontconfig expat
  • Alternatively, download this setup file and replace the one in the unpackaged directories. If you are using the standalone installer or the ISO, run [size=1em]./setup to continue with the installation. If you are using the altera_installer.external.sh, perform the following steps:
    • Replace the setup script in the [size=1em]./bin directory
    • change directory to the ./bin directory
    • Run [size=1em]export PATH=./:$PATH for sh-style shells or [size=1em]setenv PATH=./:$PATH for csh-style shells
    • Run [size=1em]./setup
This error is fixed beginning with the Quartus II software version 12.0 SP1.
Related Solutions
  • You must install the 32-bit version of the following libraries for the Altera Installer to operate properly
个人签名:这个社会混好的两种人:一是有权有势,二是没脸没皮的。
1205
