estimate_test_coverage报错,麻烦有经验的能给个方向。
2356|0
 楼主| jason.zou 发表于 2009-2-11 13:27 | 显示全部楼层 |阅读模式
用<br />estimate_test_coverage<br />结果<br />Loading&nbsp;target&nbsp;library&nbsp;'slow'<br />&nbsp;&nbsp;&nbsp;&nbsp;Loading&nbsp;design&nbsp;...<br />&nbsp;&nbsp;Using&nbsp;test&nbsp;protocol&nbsp;in&nbsp;memory.<br />&nbsp;&nbsp;&nbsp;&nbsp;Starting&nbsp;test&nbsp;coverage&nbsp;estimation&nbsp;...<br />Error:&nbsp;Can&nbsp;not&nbsp;get&nbsp;fault&nbsp;coverage&nbsp;for&nbsp;design&nbsp;PPM_TOP&nbsp;due&nbsp;to&nbsp;design&nbsp;rule&nbsp;checking&nbsp;error.<br />然后check_dft<br />**************************************************<br />&nbsp;&nbsp;Test&nbsp;Design&nbsp;Rule&nbsp;Violation&nbsp;Summary<br /><br />&nbsp;&nbsp;Total&nbsp;violations:&nbsp;69<br />**************************************************<br /><br />PROTOCOL&nbsp;VIOLATIONS<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;35&nbsp;Asynchronous&nbsp;pins&nbsp;uncontrollable&nbsp;violations&nbsp;(TEST-116)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;15&nbsp;Asynchronous&nbsp;signal&nbsp;active&nbsp;during&nbsp;scan&nbsp;violations&nbsp;(TEST-280)<br />SCAN&nbsp;IN&nbsp;VIOLATIONS<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;15&nbsp;Cell&nbsp;constant&nbsp;during&nbsp;scan&nbsp;violations&nbsp;(TEST-142)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;Cell&nbsp;is&nbsp;uncontrollable&nbsp;during&nbsp;scan&nbsp;violation&nbsp;(TEST-302)<br />CAPTURE&nbsp;VIOLATIONS<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;Unreliable&nbsp;capture&nbsp;(async&nbsp;pin)&nbsp;violations&nbsp;(TEST-471)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;Cell&nbsp;does&nbsp;not&nbsp;capture&nbsp;violation&nbsp;(TEST-310)<br /><br /><br />**************************************************<br />&nbsp;&nbsp;Sequential&nbsp;Cell&nbsp;Summary<br /><br />&nbsp;&nbsp;43&nbsp;out&nbsp;of&nbsp;1179&nbsp;sequential&nbsp;cells&nbsp;have&nbsp;violations<br />**************************************************<br /><br />简单描述下设计,异步复位,一个全局时钟,内部有复位逻辑,是同步的。<br />我列举几个DRC违例,想请问下如何解决,DFT我是第一次作。每类问题我列一个出来问,请教下如何解决,详细的DRC警告见附件:<br />1.Warning:&nbsp;Cell&nbsp;uart_top1/tx232/m1_state_reg_1_0&nbsp;(SDFFNRX1)&nbsp;is&nbsp;always&nbsp;asynchronously&nbsp;set/cleared.&nbsp;(TEST-280)<br />2.Warning:&nbsp;Asynchronous&nbsp;pins&nbsp;of&nbsp;cell&nbsp;uart_top1/tx232/data_in_waiting_reg_0_0&nbsp;(SDFFNSRX2)&nbsp;are&nbsp;uncontrollable.&nbsp;(TEST-116)<br />3.Warning:&nbsp;Sequential&nbsp;cell&nbsp;uart_top1/tx232/q_reg_1_0&nbsp;(SDFFNSX1)&nbsp;has&nbsp;constant&nbsp;logic&nbsp;1/0&nbsp;state.&nbsp;(TEST-142)<br />4.Warning:&nbsp;Cell&nbsp;gen_sclk1/Phase_cnt_reg_0_0&nbsp;(SDFFNSRX4)&nbsp;is&nbsp;not&nbsp;scan&nbsp;controllable.&nbsp;(TEST-302)<br />5.Warning:Asynchronous&nbsp;control&nbsp;pin&nbsp;SN&nbsp;of&nbsp;cellgen_sclk1/Phase_cnt_reg_0_0(SDFFNSRX4)&nbsp;can&nbsp;change&nbsp;in&nbsp;the&nbsp;capture&nbsp;cycle.This&nbsp;can&nbsp;cause&nbsp;the&nbsp;cell&nbsp;tocapture&nbsp;unreliably.&nbsp;(TEST-471)<br />6.Warning:&nbsp;Data&nbsp;can&nbsp;not&nbsp;be&nbsp;captured&nbsp;into&nbsp;cell&nbsp;gen_sclk1/Phase_cnt_reg_0_0&nbsp;(SDFFNSRX4).&nbsp;(TEST-310)<br />&nbsp;&nbsp;...binding&nbsp;scan-out&nbsp;state...
