无碳纤车
1216|2
 楼主| 想做李白 发表于 2016-9-16 10:03 | 显示全部楼层 |阅读模式
AD, dc, ADC, FAST, ST
#include <iom16v.h>
#include <macros.h>
#define  uchar unsigned char
#define  uint  unsigned int
#include"duoji.c"
#include"AD.c"
#include"USART.c"
#pragma interrupt_handler miao:5
uint flog=0;
table[]={0x3f,0x06,0x5B,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar  disbit[6]  ={ 0x01, 0x02,0x04,0x08,0X10,0X20};
uchar num=0,timer0=0,timer1=0;
uint numdata0,numdata1,fastnum0,fastnum1;
int adc_data0,adc_data1,adc_data2,adc_data3,adc_data4;
uchar key;
void miao()
  if(flog>=110)                /********一秒是400***********/
     timer0--;
     num++;
         flog=0;
           if(num==60)
              num=0;
   flog++;
   TCNT2=0x01;
void delay(uint ms)
  uint i,j;
  for(i=0;i<ms;i++)
  for(j=0;j<1141;j++);
void lvbo(void)
        uchar num;
               numdata0=mega16_ad0();
                   numdata1=mega16_ad1();
                for(num=50;num>0;num--)
               adc_data0=mega16_ad0();
                   adc_data1=mega16_ad1();
                   adc_data2=mega16_ad2();
                   if((numdata0<adc_data0)||(numdata1<adc_data1))
                       numdata0=adc_data0;
                           numdata1=adc_data1;
                   delay(10);
                fastnum0=81;
                fastnum1=81;
                //fastnum0=(int)(numdata0/4);
                //fastnum1=(int)(numdata1/4);
                   timer0=2;
        while(timer0)
      PutNUM(numdata0);
          PutNUM(222);
         PutNUM(numdata1);
         PutNUM(333);
         PutNUM(adc_data2);
         PutNUM(111);
         PutNUM(fastnum1);
         PutNUM(444);
         PutNUM(fastnum0);
         PutNUM(666);
void show(uchar i,uchar j)
    //for(j=0;j<6;j++)
          PORTC|=table[i];
      PORTB|=disbit[j];
         delay(10);
         PORTB=0X00;
         PORTC=0X00;
void main()
         uchar sign=0;
         DDRC=0XFF;
     DDRB=0XFF;
     PORTB=0xFF;
    TCCR2=0X04;
    TCNT2=0x04;
        TIMSK|=BIT(6);
        //TIMSK&=~BIT(6);
    SREG|=BIT(7);
        Uart_Init();
    duoji();
   lvbo();
        while(1)
     /*PutNUM(adc_data0);
          PutNUM(222);
         PutNUM(adc_data1);
         PutNUM(333);
         PutNUM(adc_data2);
         PutNUM(444);*/
                  show(num%10,0);
        show(num/10,1);
                OCR1A=44;
                /*if(adc_data2<850)   //12440     //6
                                OCR1A=44;
       if(adc_data2>850)
                if((numdata0+fastnum0*3)>adc_data0)
                 {OCR1A=47;}
                if((numdata0+fastnum0*2)>adc_data0&&((numdata0+fastnum0*3)<adc_data0))
                 {OCR1A=46;}
             if((numdata0+fastnum0*1)>adc_data0&&((numdata0+fastnum0)<adc_data0))
                 {OCR1A=45;}
             if(((numdata0+fastnum0)>adc_data0))
                 {OCR1A=44;}
                if((numdata1+fastnum1*3)>adc_data1)
                 {OCR1A=40;}
                if((numdata1+fastnum1*2)>adc_data1&&((numdata0+fastnum1*3)<adc_data1))
                 {OCR1A=42;}
             if((numdata1+fastnum1*1)>adc_data1&&((numdata1+fastnum1)<adc_data1))
                 {OCR1A=43;}
             if(((numdata1+fastnum1)>adc_data1))
                 {OCR1A=44;}
               while(adc_data0>500)
                                      if((numdata0+fastnum0*10)<adc_data0)
                                    {OCR1A=60;}
                                        if((numdata0+fastnum0*10)>adc_data0&&((numdata0+fastnum0*9)<adc_data0))
                                   {OCR1A=60;}
                                         if(((numdata0+(fastnum0*9))>adc_data0)&&(numdata0+(fastnum0*8)<adc_data0))
                                   {OCR1A=55;}
                                             if(((numdata0+(fastnum0*8))>adc_data0)&&(numdata0+(fastnum0*7)<adc_data0))
                                   {OCR1A=50;}
                                         if(((numdata0+(fastnum0*6))>adc_data0)&&(numdata0+(fastnum0*5)<adc_data0))
                                   {OCR1A=48;}
                                                         sign=1;
                                 while(adc_data1>450)
                                  if((numdata1+fastnum1*(8.8))<adc_data1)
                          {OCR1A=25;}
                                      if(((numdata1+fastnum1*7)>adc_data1)&&((numdata1+fastnum1*8)<adc_data1))
                          {OCR1A=30;}
                          if(((numdata1+fastnum1*7)>adc_data1)&&(numdata1+fastnum1*6<adc_data1))
                          {OCR1A=35;}
                           if(((numdata1+fastnum1*6)>adc_data1)&&(numdata1+fastnum1*5<adc_data1))
                           {OCR1A=40;}
                            if(((numdata1+fastnum1*5)>adc_data1)&&(numdata1+fastnum1*4<adc_data1))
                            {OCR1A=42;}
                                                         sign=2;
      if(sign==1)
                 for(OCR1A;OCR1A>45;OCR1A=OCR1A-3)
                                        timer0=1;
                                                while(timer0)
                                  PutNUM(num);
                                                      PutNUM(505);
                                                timer0=0;
                                 for(OCR1A;OCR1A>30;OCR1A--)
                                                 timer0=1;
                                                while(timer0)
                                                  PutNUM(num);
                                                  PutNUM(505);
                                                 timer0=0;
             //OCR1A=44;
                 sign=0;
         /*if(sign==2)
                  for(OCR1A;OCR1A<45;OCR1A=OCR1A+3)
                                                 timer0=1;
                                                while(timer0)
                                                  PutNUM(num);
                                                  PutNUM(505);
                                                 timer0=0;
                                            timer0=2;
                                     while(timer0);
                for(OCR1A;OCR1A<55;OCR1A++)
                                                 timer0=1;
                                                while(timer0)
                                                  PutNUM(num);
                                                  PutNUM(505);
                                                 timer0=0;
                 //OCR1A=44;
                 sign=0;
          //if(sign==1)
dirtwillfly 发表于 2016-9-18 08:46 | 显示全部楼层
感谢分享。
gaoyang9992006 发表于 2016-9-21 16:56 | 显示全部楼层
一堆代码什么鬼。
