请教:max plus II 仿真错误:can't find design file
4166|0
 楼主| rb1549 发表于 2010-5-20 21:59 | 显示全部楼层 |阅读模式
用VHDL编写的16—4优先编码器(8-3优先编码器级联)编译时提示错误!代码如下:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY encoder IS
     PORT(d:IN STD_LOGIC_VECTOR(15 DOWNTO 0);
          e1:IN STD_LOGIC;
          q:OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
          gs:OUT STD_LOGIC;
          e0:OUT STD_LOGIC);
END encoder;
ARCHITECTURE struc OF encoder IS
COMPONENT encoder8     --对要调用元件encoder8界面端口进行定义
    PORT(d:IN STD_LOGIC_VECTOR(7 DOWNTO 0);
          e1:IN STD_LOGIC;
          dq:OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
          gs:OUT STD_LOGIC;
          e0:OUT STD_LOGIC);
END COMPONENT;
    SIGNAL sink :STD_LOGIC_VECTOR(3 DOWNTO 0);
    SIGNAL aa,bb  :STD_LOGIC_VECTOR(2 DOWNTO 0);
    SIGNAL carry_out,temp: STD_LOGIC;
BEGIN
    U1: encoder8
    PORT MAP(e1=>e1,d=>d(15 DOWNTO 8),dq=>aa(2 DOWNTO 0),e0=>CARRY_OUT,gs=>temp);
    U2: encoder8
    PORT MAP(e1=>carry_out,d=>d(7 DOWNTO 0),e0=>e0,gs=>gs,dq=>bb(2 DOWNTO 0));
    sink(3)<=NOT temp;
    sink(2)<=aa(2) NAND bb(2);
    sink(1)<=aa(1) NAND bb(1);
    sink(0)<=aa(0) NAND bb(0);
    q<=sink(3)&sink(2)&sink(1)&sink(0);
set project ro current file 了!我的max是学生使用版的?要是那位大侠有更好的程序也可……
