- #include <sys/socket.h>
- #include <stdio.h>
- #include <stdlib.h>
- #include <arpa/inet.h>
- #include <string.h>
- #include <unistd.h>
- #include <netinet/in.h>
- #include <sys/types.h>
- #include <sys/stat.h>
- #include <fcntl.h>
- #include <signal.h>
- #define PORT 843
- int main (int argc, char **argv)
- int listen_fd;
- if ((listen_fd = socket (PF_INET, SOCK_STREAM, 0)) < 0) { printf ("socket() error\n"); exit (0); }
- struct sockaddr_in acceptAddr; bzero(&acceptAddr, sizeof(acceptAddr));
- acceptAddr.sin_family = PF_INET;
- acceptAddr.sin_addr.s_addr = htonl (INADDR_ANY);
- acceptAddr.sin_port = htons (PORT);
- if (bind(listen_fd, (struct sockaddr *)&acceptAddr, sizeof(acceptAddr)) != 0) { printf("bind() error\n"); exit(0); }
- if (listen (listen_fd, 1000) != 0) { printf("listen() error\n"); exit(0); }
- signal(SIGPIPE, SIG_IGN);
- for(;;) {
- struct sockaddr_in clientAddr; bzero(&clientAddr, sizeof(clientAddr));
- int clientSockfd, len;
- len = sizeof (clientAddr);
- clientSockfd = accept (listen_fd, (struct sockaddr *)&clientAddr, (socklen_t *)&len); /* accept() creates a new connected socket file descriptor. */
- char *data = "<?xml version="1.0"?><cross-domain-policy><site-control permitted-cross-domain-policies="all"/><allow-access-from domain="*" to-ports="*"/></cross-domain-policy>\x00";
- write (clientSockfd, data, (strlen(data)+1));
- shutdown(clientSockfd, SHUT_RDWR); close (clientSockfd); /* close file descriptor */
- return 0;
