[Cortex-A] 【A10-OlinuXino-LIME试用】1. 首次开箱测评
866|1
 楼主| ICLYL 发表于 2018-2-23 20:48 | 显示全部楼层 |阅读模式
首先非常感谢21IC的支持,在过年前就拿到板卡了,但是轻松过大年就一直放置没有开箱,这次来个开箱贴
快递中附带一张STM32L4+的宣传A4纸张,拍摄如下:
正面照:可以看到,布局非常紧凑,且端口丰富
但美中不足之处是:
双排排插是1.27mm(50mil)不是常见的2.54mm(100mil)
反面照:
板卡差不多把电容电阻等器件放置在背面,后面显得密集
合照:
板卡的特点:
  • A10 1GHz Cortex-A8 ARMv7 CPU, VFPv3, NEON, Mali 400 GPU, CedarX VPU
  • 512MB DDR3 RAM memory
  • optional 4GB NAND FLASH memory
  • SATA connector with 5V SATA power jack
  • HDMI FullHD 1080p
  • 2x USB Low-Full-High-Speed hosts with power control and current limiter
  • USB-OTG with power control and current limiter
  • 100MBit native Ethernet
  • LiPo Battery connector with battery-charging capabilities
  • LCD connector compatible with with 4.3", 7.0", 10.1" LCD modules from Olimex
  • 160 GPIOs on three GPIO connectors
  • MicroSD card connector
  • DEBUG-UART connector for console debug with USB-SERIAL-CABLE-F
  • status LED
  • Battery charge status LED
  • Power LED
  • 2KB EEPROM for MAC address storage and more
  • 2 BUTTONS with ANDROID functionality + RESET button
  • 2 mount holes
  • 5V input power supply, noise immune design
  • PCB dimensions: 84 x 60 mm
附上几张功能图,详解一下板卡强大的功能
巧克力娃娃 发表于 2018-3-7 10:36 | 显示全部楼层
为了环保,我们都会把纸张双面使用~~~~嘿嘿
