本帖主要讲解ESP8266 WIFI功能关于UDP协议网络传输的应用,这里演示了ESP8266在STATION模式下UDP通信的示例:
1、硬件
零知ESP8266
2、软件
(1)代码如下:
- * 文件: esp8266-udp-clinet.ino by 零知实验室(www.lingzhilab.com)
- * -^^- 零知开源,让电子制作变得更简单! -^^-
- * 时间: 2019/06/17 11:01
- * 说明:
- #include <ESP8266WiFi.h>
- #include <WiFiUDP.h>
- #define SSID "xx"
- #define PSSWD "xx"
- unsigned int UDPPort = 8888; // local port to listen on
- char packetBuffer[255]; //buffer to hold incoming packet
- char replyBuffer[] = "send-back-ack"; // a string to send back
- WiFiUDP Udp;
- // 复位或上电后运行一次:
- void setup() {
- //在这里加入初始化相关代码,只运行一次:
- Serial.begin(115200);
- WiFi.mode(WIFI_STA);
- WiFi.begin(SSID, PSSWD);
- while (WiFi.status() != WL_CONNECTED) {
- Serial.print('.');
- delay(500);
- Serial.print("Connected! IP address: ");
- Serial.println(WiFi.localIP());
- Serial.printf("UDP server on port %d\n", UDPPort);
- Udp.begin(UDPPort);
- // Udp.beginPacket("192.168.4.1", UDPPort);//send ip to server
- // char ipBuffer[255];
- // WiFi.localIP().toString().toCharArray(ipBuffer, 255);
- // Udp.write(ipBuffer);
- // Udp.endPacket();
- // Serial.println("Sent ip adress to server");
- //一直循环执行:
- void loop() {
- // 在这里加入主要程序代码,重复执行:
- // if there's data available, read a packet
- int packetSize = Udp.parsePacket();
- if (packetSize) {
- Serial.print("Received packet of size ");
- Serial.println(packetSize);
- Serial.print("From ");
- IPAddress remoteIp = Udp.remoteIP();
- Serial.print(remoteIp);
- Serial.print(", port ");
- Serial.println(Udp.remotePort());
- // read the packet into packetBufffer
- int len = Udp.read(packetBuffer, 255);
- if (len > 0) {
- packetBuffer[len] = 0;
- Serial.println("Contents:");
- Serial.println(packetBuffer);
- // send a reply, to the IP address and port that sent us the packet we received
- Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
- Udp.write(replyBuffer);
- Udp.endPacket();
(2)将上面代码验证后并上传到零知ESP8266开发板中,然后打开串口调试窗口,可以看到如下信息:
上面显示了ESP8266的IP地址和端口号信息。
(3)现在打开零知工具箱(可以在“软件下载”页面下载),然后打开“网络调试”界面,选择UDP模式并选择UDP的IP和端口号,如下:
TIP:零知工具箱请在零知实验室官网下载哦
3、测试验证 在零知工具箱中,点击【连接】,然后就可以和零知ESP8266开始通信了,我们在发送窗口填写发送的信息,点击【发送】,可以看到如下信息,表明通信双方成功:
