- * 描述: *
- * 12864标准字库液晶演示 数据p0,控制p3 *
- #include "stc8.h"
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- /************* 12864LCD引脚定义 *************/
- #define LCD_data P0 //数据口
- sbit LCD_RS = P3^5; //寄存器选择输入
- sbit LCD_RW = P3^6; //液晶读/写控制
- sbit LCD_EN = P3^7; //液晶使能控制
- sbit LCD_PSB = P4^6; //串/并方式控制
- sbit LCD_RST = P4^7; //液晶复位端口
- #define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
- uchar code DIS1[] = {" 启光电子 "};
- uchar code DIS2[] = {" STC15 "};
- uchar code DIS3[] = {" zq281598585 "};
- uchar code DIS4[] = {" 12864test "};
- /* 延时函数 */
- void delay(int ms)
- while(ms--)
- uchar i;
- for(i=0;i<150;i++)
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- /* 延时函数 */
- void delay1(int ms)
- while(ms--)
- uchar y;
- for(y=0;y<100;y++) ;
- /*检查LCD忙状态 */
- /*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。 */
- bit lcd_busy()
- bit result;
- LCD_RS = 0;
- LCD_RW = 1;
- LCD_EN = 1;
- delayNOP();
- result = (bit)(P0&0x80);
- LCD_EN = 0;
- return(result);
- /*写指令数据到LCD */
- /*RS=L,RW=L,E=高脉冲,D0-D7=指令码。 */
- void lcd_wcmd(uchar cmd)
- while(lcd_busy());
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_EN = 0;
- _nop_();
- _nop_();
- P0 = cmd;
- delayNOP();
- LCD_EN = 1;
- delayNOP();
- LCD_EN = 0;
- /*写显示数据到LCD */
- /*RS=H,RW=L,E=高脉冲,D0-D7=数据。 */
- void lcd_wdat(uchar dat)
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_EN = 0;
- P0 = dat;
- delayNOP();
- LCD_EN = 1;
- delayNOP();
- LCD_EN = 0;
- /* LCD初始化设定 */
- void lcd_init()
- LCD_PSB = 1; //并口方式
- LCD_RST = 0; //液晶复位
- delay(3);
- LCD_RST = 1;
- delay(3);
- lcd_wcmd(0x34); //扩充指令操作
- delay(5);
- lcd_wcmd(0x30); //基本指令操作
- delay(5);
- lcd_wcmd(0x0C); //显示开,关光标
- delay(5);
- lcd_wcmd(0x01); //清除LCD的显示内容
- delay(5);
- /* 设定显示位置 */
- void lcd_pos(uchar X,uchar Y)
- uchar pos;
- if (X==1)
- {X=0x80;}
- else if (X==2)
- {X=0x90;}
- else if (X==3)
- {X=0x88;}
- else if (X==4)
- {X=0x98;}
- pos = X+Y ;
- lcd_wcmd(pos); //显示地址
- * 闪烁函数 *
- void lcdflag()
- lcd_wcmd(0x08);
- delay(400);
- lcd_wcmd(0x0c);
- delay(400);
- lcd_wcmd(0x08);
- delay(400);
- lcd_wcmd(0x0c);
- delay(400);
- lcd_wcmd(0x08);
- delay(200);
- lcd_wcmd(0x0c);
- delay(5);
- lcd_wcmd(0x01);
- delay(5);
- * 图形显示 *
- void photodisplay(uchar *bmp)
- uchar i,j;
- lcd_wcmd(0x34); //写数据时,关闭图形显示
- for(i=0;i<32;i++)
- lcd_wcmd(0x80+i); //先写入水平坐标值
- lcd_wcmd(0x80); //写入垂直坐标值
- for(j=0;j<16;j++) //再写入两个8位元的数据
- lcd_wdat(*bmp++);
- delay1(1);
- for(i=0;i<32;i++)
- lcd_wcmd(0x80+i);
- lcd_wcmd(0x88);
- for(j=0;j<16;j++)
- lcd_wdat(*bmp++);
- delay1(1);
- lcd_wcmd(0x36); //写完数据,开图形显示
- * 清屏函数 *
- void clr_screen()
- delay(5);
- delay(5);
- lcd_wcmd(0x01); //清屏
- delay(5);
- ; 显示字符表代码
- void bytecode()
- uchar s;
- clr_screen(); //清屏
- lcd_wcmd(0x80); //设置显示位置为第一行
- for(s=0;s<16;s++)
- lcd_wdat(0x30+s);
- lcd_wcmd(0x90); //设置显示位置为第二行
- for(s=0;s<16;s++)
- lcd_wdat(0x40+s);
- lcd_wcmd(0x88); //设置显示位置为第三行
- for(s=0;s<16;s++)
- lcd_wdat(0x50+s);
- lcd_wcmd(0x98); //设置显示位置为第四行
- for(s=0;s<16;s++)
- lcd_wdat(0x60+s);
- * 主函数 *
- void main()
- uchar i;
- delay(100); //上电,等待稳定
- lcd_init(); //初始化LCD
- lcd_pos(1,0); //设置显示位置为第一行
- for(i=0;i<16;i++)
- lcd_wdat(DIS1[i]);
- delay(30);
- lcd_pos(2,0); //设置显示位置为第二行
- for(i=0;i<16;i++)
- lcd_wdat(DIS2[i]);
- delay(30);
- lcd_pos(3,0); //设置显示位置为第三行
- for(i=0;i<16;i++)
- lcd_wdat(DIS3[i]);
- delay(30);
- lcd_pos(4,0); //设置显示位置为第四行
- for(i=0;i<16;i++)
- lcd_wdat(DIS4[i]);
- delay(30);
- while(1);
不知道适不适合你
