请问定时器update中断是什么意思??
718|0
 楼主| 白闻不如怡见 发表于 2019-11-14 13:14 | 显示全部楼层 |阅读模式
今天学呼吸灯,发现里面用的是TIM3的update中断,就不明白它是什么意思了,          @arg TIM_IT_Update: TIM update Interrupt source  *     @arg TIM_IT_CC1: TIM Capture Compare 1 Interrupt source
  *     @arg TIM_IT_CC2: TIM Capture Compare 2 Interrupt source
  *     @arg TIM_IT_CC3: TIM Capture Compare 3 Interrupt source
  *     @arg TIM_IT_CC4: TIM Capture Compare 4 Interrupt source
  *     @arg TIM_IT_COM: TIM Commutation Interrupt source
  *     @arg TIM_IT_Trigger: TIM Trigger Interrupt source
  *     @arg TIM_IT_Break: TIM Break Interrupt source
这几个有什么区别呢?
