在AT32F407的A/D转换器中配置了内部的温度检测通道,利用它与OLED屏相配合,可以轻松地实现一个片内温度检测器,其显示效果如图所示。 片内温度检测器 实现该显示功能的主程序为: - int main(void)
- int num;
- RCC_Configuration();
- Delay_init();
- DMA_Reset(DMA1_Channel1);
- DMA_DefaultInitParaConfig(&DMA_InitStructure);
- DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
- DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&ADCConvertedValue;
- DMA_InitStructure.DMA_Direction = DMA_DIR_PERIPHERALSRC;
- DMA_InitStructure.DMA_BufferSize = 1;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PERIPHERALINC_DISABLE;
- DMA_InitStructure.DMA_MemoryInc = DMA_MEMORYINC_DISABLE;
- DMA_InitStructure.DMA_PeripheralDataWidth = DMA_PERIPHERALDATAWIDTH_HALFWORD;
- DMA_InitStructure.DMA_MemoryDataWidth = DMA_MEMORYDATAWIDTH_HALFWORD;
- DMA_InitStructure.DMA_Mode = DMA_MODE_CIRCULAR;
- DMA_InitStructure.DMA_Priority = DMA_PRIORITY_HIGH;
- DMA_InitStructure.DMA_MTOM = DMA_MEMTOMEM_DISABLE;
- DMA_Init(DMA1_Channel1, &DMA_InitStructure);
- DMA_ChannelEnable(DMA1_Channel1, ENABLE);
- ADC_StructInit(&ADC_InitStructure);
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
- ADC_InitStructure.ADC_ScanMode = DISABLE;
- ADC_InitStructure.ADC_ContinuousMode = ENABLE;
- ADC_InitStructure.ADC_ExternalTrig = ADC_ExternalTrig_None;
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- ADC_InitStructure.ADC_NumOfChannel = 1;
- ADC_Init(ADC1, &ADC_InitStructure);
- ADC_RegularChannelConfig(ADC1, ADC_Channel_TempSensor, 1, ADC_SampleTime_239_5);
- ADC_DMACtrl(ADC1, ENABLE);
- ADC_TempSensorVrefintCtrl(ENABLE);
- ADC_Ctrl(ADC1, ENABLE);
- ADC_RstCalibration(ADC1);
- while(ADC_GetResetCalibrationStatus(ADC1));
- ADC_StartCalibration(ADC1);
- while(ADC_GetCalibrationStatus(ADC1));
- ADC_SoftwareStartConvCtrl(ADC1, ENABLE);
- AT32_OLED_Init();
- OLED_Init();
- OLED_Clear();
- OLED_ShowString(0,0,"AT-START-F407",16);
- OLED_ShowString(0,2,"OLED & ADC ",16);
- Delay_ms(1000u);
- OLED_Clear();
- OLED_ShowString(0,2,"Temp: deg C",16);
- while (1)
- num=(ADC_TEMP_BASE-(double)ADCConvertedValue*ADC_VREF/4096)/ADC_TEMP_SLOPE+25;
- OLED_ShowNum(40,2,num,3,16);
- Delay_sec(1);
