[PIC®/AVR®/dsPIC®产品] 8位PIC芯片汇编环境搭建——pic-as汇编
1715|1
 楼主| JackTang1994 发表于 2022-1-22 10:05 | 显示全部楼层 |阅读模式
#申请原创# #技术资源#
参考资料
http://www.microchip.com.cn/newcommunity//Uploads/202008/5f44c72f4e170.pdf
http://www.microchip.com.cn/newcommunity/Uploads/202105/60a4bb701acd0.pdf
说明:PIC汇编器在安装PIC编译器时已经被安装了,在安装目录
添加汇编器
打开MPLAB X IDE
切换到Embedded面板点击Add按钮,打开编译添加窗口
选择pic-as汇编器路径
创建工程
按照普通工程创建一样创建汇编工程即可,只是在选择编译器时需要选择我们添加的pic-as汇编器
编写代码
向工程中新建*.s后缀的汇编文件
注:.s后缀是GUN风格的汇编文件
添加代码
  1.     #include <xc.inc>
  2. ; CONFIG1
  3.   CONFIG  FEXTOSC = OFF         ; External Oscillator Mode Selection bits (Oscillator not enabled)
  4.   CONFIG  RSTOSC = HFINTOSC_32MHZ; Power-up Default Value for COSC bits (HFINTOSC (32 MHz))
  5.   CONFIG  CLKOUTEN = OFF        ; Clock Out Enable bit (CLKOUT function is disabled; I/O function on RA4)
  6.   CONFIG  VDDAR = HI            ; VDD Range Analog Calibration Selection bit (Internal analog systems are calibrated for operation between VDD = 2.3V - 5.5V)
  7. ; CONFIG2
  8.   CONFIG  MCLRE = EXTMCLR       ; Master Clear Enable bit (If LVP = 0, MCLR pin is MCLR; If LVP = 1, RA3 pin function is MCLR)
  9.   CONFIG  PWRTS = PWRT_OFF      ; Power-up Timer Selection bits (PWRT is disabled)
  10.   CONFIG  WDTE = OFF            ; WDT Operating Mode bits (WDT disabled; SEN is ignored)
  11.   CONFIG  BOREN = ON            ; Brown-out Reset Enable bits (Brown-out Reset Enabled, SBOREN bit is ignored)
  12.   CONFIG  BORV = LO             ; Brown-out Reset Voltage Selection bit (Brown-out Reset Voltage (VBOR) set to 1.9V)
  13.   CONFIG  PPS1WAY = ON          ; PPSLOCKED One-Way Set Enable bit (The PPSLOCKED bit can be set once after an unlocking sequence is executed; once PPSLOCKED is set, all future changes to PPS registers are prevented)
  14.   CONFIG  STVREN = ON           ; Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will cause a reset)
  15. ; CONFIG3
  16. ; CONFIG4
  17.   CONFIG  BBSIZE = BB512        ; Boot Block Size Selection bits (512 words boot block size)
  18.   CONFIG  BBEN = OFF            ; Boot Block Enable bit (Boot Block is disabled)
  19.   CONFIG  SAFEN = OFF           ; SAF Enable bit (SAF is disabled)
  20.   CONFIG  WRTAPP = OFF          ; Application Block Write Protection bit (Application Block is not write-protected)
  21.   CONFIG  WRTB = OFF            ; Boot Block Write Protection bit (Boot Block is not write-protected)
  22.   CONFIG  WRTC = OFF            ; Configuration Registers Write Protection bit (Configuration Registers are not write-protected)
  23.   CONFIG  WRTSAF = OFF          ; Storage Area Flash (SAF) Write Protection bit (SAF is not write-protected)
  24.   CONFIG  LVP = ON              ; Low Voltage Programming Enable bit (Low Voltage programming enabled. MCLR/Vpp pin function is MCLR. MCLRE Configuration bit is ignored.)
  25. ; CONFIG5
  26.   CONFIG  CP = OFF              ; User Program Flash Memory Code Protection bit (User Program Flash Memory code protection is disabled)
  27. ;CONFIG WDTE=OFF // WDT Disabled; SWDTEN is ignored
  28. ;this must be linked to the reset vector
  29. PSECT resetVec,class=CODE,reloc=1
  30. resetVec:
  31.     GOTO main
  32.
  33. PSECT code
  34. main:
  35.     ; This code example illustrates initializing the PORTA register.
  36. ; The other ports are initialized in the same manner.
  37. BANKSEL PORTA ;
  38. CLRF PORTA ;Clear PORTA
  39. BANKSEL LATA ;
  40. CLRF LATA ;Clear Data Latch
  41. BANKSEL ANSELA ;
  42. CLRF ANSELA ;Enable digital drivers
  43. BANKSEL TRISA ;
  44. MOVLW 00111000B ;Set RA[5:3] as inputs
  45. MOVWF TRISA ;and set others as outputs
  46.     END
其中CONFIG配置字代码是IDE自动生成的,可以通过如下方法生成:
点击Window菜单 >> Target Memory Views >> Configuration Bits打开配置字UI界面
在配置字面板中,通过相关的下拉框来选择配置字需要设置的功能。此工程中配置为:关闭看门狗,使用内部32MHZ高速时钟
点击生成源代码按钮,并将生成的源代码复制到汇编文件开头即可。
设置链接器选项
  1. -presetVec=0h,-Map=led.map
编译代码
点击编译按钮
如下,表示编译成功。
调试器设置——使用调试器供电
选择调试器
打开Power设置面板
设置调试器给MCU的供电电压为:5V
pzsh 发表于 2022-2-25 19:42 | 显示全部楼层
配置PICKIT4供电电压原来在这里
