[PIC®/AVR®/dsPIC®产品] 用atxmega128a1u AES,CBC压缩的数据,用网站上在线AES解压
921|7
 楼主| bluefancy 发表于 2022-6-9 09:56 来自手机 | 显示全部楼层 |阅读模式
用atxmega128a1u  AES,CBC压缩的数据,用第三方网站上在线AES解压算法解压后每次有两个字节与明文不同,请问可能是什么原因?
 楼主| bluefancy 发表于 2022-6-9 10:40 来自手机 | 显示全部楼层
key: 000102030405060708090A0B0C0D0E0F  lastkey: 13111D7FE3944A17F307A78B4D2B30C5  initvector: 02000047000A1606010D3A4803000000  plaintext: 00FFFFFFFFFFFFFFFFFFFFFFFF0080FFFFFFFF000080FFFFFFFFFF020000000000000000000000000000000000000002010000008064436443008000807A6443  ciphertext(atxmega128a1-AES-CBC): 602CE42063DFC0C57A3D452E93CB13665CB0A49BDB2C5A64E8033E793E23FCBAAB3A751B00B7890BB8FABF38351E0F2A76C207969763B4D79FC977CF2CD05298  decrypt((atxmega128a1-AES-CBC): 00FFFFFFFFFFFFFFFFFFFFFFFF0080FFFFFFFF000080FFFFFFFFFF020000000000000000000000000000000000000002010000008064436443008000807A6443  decrypt with online-aes-calculator(http://www.cryptogrium.com/aes-c...): 00ffffffffffffffffffffbac60080ffffffff000080ffffffffff020000000000000000000000000000000000000002010000008064436443008000807a6443  I encrypt the plaintext,then decrypt the ciphertext with the xmega AES engine,the decrypt result is same as plaintext. But when I use online AES calculator(http://www.cryptogrium.com/aes-c...) to decrypt the ciphertext(is encrypted by xmage engine), two bytes(12th,13th)of the result(64 bytes) is not same,why?
tpgf 发表于 2022-7-3 10:17 | 显示全部楼层
这个额资料多吗
qcliu 发表于 2022-7-3 11:09 | 显示全部楼层
解压缩算法是开源的吗
drer 发表于 2022-7-3 11:17 | 显示全部楼层
可以免费在线解压?
coshi 发表于 2022-7-3 11:29 | 显示全部楼层
必须用相同的软件解压缩吗
kxsi 发表于 2022-7-3 11:40 | 显示全部楼层
解压缩和压缩是不同的方式吗
wiba 发表于 2022-7-3 11:51 | 显示全部楼层
这个是**的秘钥吗
