测评目地:利用上位机显示ADC采集,ADC是模数转换,获取通道1 18的电压值。配置流程:GPIO--通道传输--ADC设定--通道--获取VREF值,
1、资料
功能介绍 :
框架:
寄存器:
2、代码
adc_common_config_type adc_common_struct;
adc_base_config_type adc_base_struct;
crm_periph_clock_enable(CRM_ADC1_PERIPH_CLOCK, TRUE);
nvic_irq_enable(ADC1_2_3_IRQn, 0, 0);
adc_common_default_para_init(&adc_common_struct);
adc_common_struct.combine_mode = ADC_INDEPENDENT_MODE;
adc_common_struct.div = ADC_HCLK_DIV_4;
adc_common_struct.common_dma_mode = ADC_COMMON_DMAMODE_DISABLE;
adc_common_struct.common_dma_request_repeat_state = FALSE;
adc_common_struct.sampling_interval = ADC_SAMPLING_INTERVAL_5CYCLES;
adc_common_struct.tempervintrv_state = FALSE;
adc_common_struct.vbat_state = TRUE;
adc_common_config(&adc_common_struct);
adc_base_default_para_init(&adc_base_struct);
adc_base_struct.sequence_mode = FALSE;
adc_base_struct.repeat_mode = FALSE;
adc_base_struct.data_align = ADC_RIGHT_ALIGNMENT;
adc_base_struct.ordinary_channel_length = 1;
adc_base_config(ADC1, &adc_base_struct);
adc_resolution_set(ADC1, ADC_RESOLUTION_12B);
/* config ordinary channel */
adc_ordinary_channel_set(ADC1, ADC_CHANNEL_18, 1, ADC_SAMPLETIME_47_5);
adc_ordinary_conversion_trigger_set(ADC1, ADC_ORDINARY_TRIG_TMR1CH1, ADC_ORDINARY_TRIG_EDGE_NONE);
adc_dma_mode_enable(ADC1, TRUE);
adc_dma_request_repeat_enable(ADC1, TRUE);
/* enable adc overflow interrupt */
adc_interrupt_enable(ADC1, ADC_OCCO_INT, TRUE);
/* adc enable */
adc_enable(ADC1, TRUE);
while(adc_flag_get(ADC1, ADC_RDY_FLAG) == RESET);
/* adc calibration */
adc_calibration_init(ADC1);
while(adc_calibration_init_status_get(ADC1));
adc_calibration_start(ADC1);
while(adc_calibration_status_get(ADC1));
adc_ordinary_software_trigger_enable(ADC1, TRUE);
printf("vbat_value = %f V\r\n", ((double)3.3 * 4 * adc1_ordinary_value) / 4095);
3、打印的结果
