- // 创建监套接字
- int createSocket()
- int fd = socket(AF_INET, SOCK_STREAM, 0);
- if(fd == -1)
- perror("socket");
- return -1;
- printf("套接字创建成功, fd=%d\n", fd);
- return fd;
- // 绑定本地的IP和端口
- int bindSocket(int lfd, unsigned short port)
- struct sockaddr_in saddr;
- saddr.sin_family = AF_INET;
- saddr.sin_port = htons(port);
- saddr.sin_addr.s_addr = INADDR_ANY; // 0 = 0.0.0.0
- int ret = bind(lfd, (struct sockaddr*)&saddr, sizeof(saddr));
- if(ret == -1)
- perror("bind");
- return -1;
- printf("套接字绑定成功, ip: %s, port: %d\n",
- inet_ntoa(saddr.sin_addr), port);
- return ret;
- // 设置监听
- int setListen(int lfd)
- int ret = listen(lfd, 128);
- if(ret == -1)
- perror("listen");
- return -1;
- printf("设置监听成功...\n");
- return ret;
- // 阻塞并等待客户端的连接
- int acceptConn(int lfd, struct sockaddr_in *addr)
- int cfd = -1;
- if(addr == NULL)
- cfd = accept(lfd, NULL, NULL);
- else
- int addrlen = sizeof(struct sockaddr_in);
- cfd = accept(lfd, (struct sockaddr*)addr, &addrlen);
- if(cfd == -1)
- perror("accept");
- return -1;
- printf("成功和客户端建立连接...\n");
- return cfd;
- // 接收数据
- int recvMsg(int cfd, char** msg)
- if(msg == NULL || cfd <= 0)
- return -1;
- // 接收数据
- // 1. 读数据头
- int len = 0;
- readn(cfd, (char*)&len, 4);
- len = ntohl(len);
- printf("数据块大小: %d\n", len);
- // 根据读出的长度分配内存
- char *buf = (char*)malloc(len+1);
- int ret = readn(cfd, buf, len);
- if(ret != len)
- return -1;
- buf[len] = '\0';
- *msg = buf;
- return ret;
- // 发送数据
- int sendMsg(int cfd, char* msg, int len)
- if(msg == NULL || len <= 0)
- return -1;
- // 申请内存空间: 数据长度 + 包头4字节(存储数据长度)
- char* data = (char*)malloc(len+4);
- int bigLen = htonl(len);
- memcpy(data, &bigLen, 4);
- memcpy(data+4, msg, len);
- // 发送数据
- int ret = writen(cfd, data, len+4);
- return ret;
- // 连接服务器
- int connectToHost(int fd, const char* ip, unsigned short port)
- // 2. 连接服务器IP port
- inet_pton(AF_INET, ip, &saddr.sin_addr.s_addr);
- int ret = connect(fd, (struct sockaddr*)&saddr, sizeof(saddr));
- if(ret == -1)
- perror("connect");
- return -1;
- printf("成功和服务器建立连接...\n");
- return ret;
- // 关闭套接字
- int closeSocket(int fd)
- int ret = close(fd);
- if(ret == -1)
- perror("close");
- return ret;
- // 接收指定的字节数
- // 函数调用成功返回 size
- int readn(int fd, char* buf, int size)
- int nread = 0;
- int left = size;
- char* p = buf;
- while(left > 0)
- if((nread = read(fd, p, left)) > 0)
- p += nread;
- left -= nread;
- else if(nread == -1)
- return -1;
- return size;
- // 发送指定的字节数
- // 函数调用成功返回 size
- int writen(int fd, const char* msg, int size)
- int left = size;
- int nwrite = 0;
- const char* p = msg;
- while(left > 0)
- if((nwrite = write(fd, msg, left)) > 0)
- p += nwrite;
- left -= nwrite;
- else if(nwrite == -1)
- return -1;
- return size;
