GD32的TIMER0_CH0可以当作普通的PWM输出吗
2365|18
 楼主| duo点 发表于 2025-3-28 12:00 | 显示全部楼层 |阅读模式
GD32的TIMER0为高级定时器,他有互补输出,现在只想使用为普通的非互补输出,那么它的TIMER0_CH0可以当作普通的PWM输出吗?不开启互补输出它的TIMER0_CH0_ON可以用作普通的GPIO吗?
tpgf 发表于 2025-4-9 15:34 | 显示全部楼层
GD32的TIMER0_CH0可以当作普通的PWM输出,但需要正确配置相关参数
yangjiyou1969 发表于 2025-4-9 16:18 | 显示全部楼层
在定时器配置里配置一下就可以了
        /* CH0 configuration in OC TOGGLE mode */
        if (LED_CCXN) {
                timer_ocintpara.outputstate  = TIMER_CCX_DISABLE;                                //ͨµÀÊä³ö״̬
                timer_ocintpara.outputnstate = TIMER_CCXN_ENABLE;                                //»¥²¹Í¨µÀÊä³ö״̬
                timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;        //»¥²¹Í¨µÀÊä³ö¼«ÐÔ
                timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;//¿ÕÏÐ״̬Ï»¥²¹Í¨µÀÊä³ö¼«ÐÔ
        }else{
                timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;                                //ͨµÀÊä³ö״̬
                timer_ocintpara.outputnstate = TIMER_CCXN_DISABLE;                        //»¥²¹Í¨µÀÊä³ö״̬
                timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;        //ͨµÀÊä³ö¼«ÐÔ
                timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_LOW;        //¿ÕÏÐ״̬ÏÂͨµÀÊä³ö
        timer_channel_output_config(ThisTIMER, TimerCh, &timer_ocintpara);
//1=        TIMER_OC_MODE_TOGGLE
//        timer_channel_output_mode_config(ThisTIMER, TimerCh, TIMER_OC_MODE_TOGGLE);
//        timer_channel_output_shadow_config(ThisTIMER, TimerCh, TIMER_OC_SHADOW_ENABLE);
// or
//2=        TIMER_OC_MODE_PWM0
        timer_channel_output_mode_config(ThisTIMER, TimerCh, TIMER_OC_MODE_PWM0);
        timer_channel_output_pulse_value_config(ThisTIMER,TimerCh,2500-1);
        /* auto-reload preload enable */
yangjiyou1969 发表于 2025-4-9 16:23 | 显示全部楼层
在定时器配置里配置一下就可以了
        if (LED_CCXN) {
                timer_ocintpara.outputstate  = TIMER_CCX_DISABLE;                                //通道输出状态
                timer_ocintpara.outputnstate = TIMER_CCXN_ENABLE;                                //互补通道输出状态
                timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;        //互补通道输出极性
                timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;//空闲状态下互补通道输出极性
        }else{
                timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;                                //通道输出状态
                timer_ocintpara.outputnstate = TIMER_CCXN_DISABLE;                        //互补通道输出状态
                timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;        //通道输出极性
                timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_LOW;        //空闲状态下通道输出
// or
xiaoqizi 发表于 2025-4-13 20:45 | 显示全部楼层
选择合适的计数模式,如向上计数模式或中央对齐计数模式等
木木guainv 发表于 2025-4-14 08:04 | 显示全部楼层
配置自动重装载寄存器的值,该值决定了PWM的周期。例如,如果系统时钟频率为72MHz,想要得到一个周期为10ms的PWM信号,那么自动重装载寄存器的值应设置为72000-1
Jiangxiaopi 发表于 2025-4-14 11:07 | 显示全部楼层
比较输出使能位用于控制是否输出PWM信号,输出极性位则决定了PWM信号的高低电平状态
荣陶陶 发表于 2025-4-14 14:08 | 显示全部楼层
根据实际需求设置预分频器的值,以调整定时器的计数频率
Zhiniaocun 发表于 2025-4-14 17:12 | 显示全部楼层
liu96jp 发表于 2025-4-18 14:03 | 显示全部楼层
在GD32系列单片机中,TIMER0作为高级定时器,确实支持互补输出功能,但您也可以将其配置为普通的非互补PWM输出模式。
ex7s4 发表于 2025-4-18 15:13 | 显示全部楼层
可以将TIMER0_CH0配置为普通PWM输出,而无需启用互补输出。
zhizia4f 发表于 2025-4-18 16:22 | 显示全部楼层
在 timer_channel_output_config() 中设置 outputnstate = TIMER_CCXN_DISABLE,这样互补通道(CH0_ON)就不会被占用。
y1n9an 发表于 2025-4-18 17:35 | 显示全部楼层
确保 outputstate = TIMER_CCX_ENABLE,使CH0正常输出PWM
w2nme1ai7 发表于 2025-4-18 19:30 | 显示全部楼层
不调用 timer_primary_output_config()(或设为 DISABLE),以避免强制启用互补输出
su1yirg 发表于 2025-4-18 21:15 | 显示全部楼层
可以将TIMER0_CH0_ON用作普通GPIO
l1uyn9b 发表于 2025-4-19 08:22 | 显示全部楼层
互补通道未被使能,确保 outputnstate = TIMER_CCXN_DISABLE,否则该引脚会被定时器占用。
lamanius 发表于 2025-4-19 10:18 | 显示全部楼层
在禁用互补输出后,需将该引脚(如PA7或PB1,具体取决于型号)重新初始化为普通GPIO模式
t1ngus4 发表于 2025-4-19 13:44 | 显示全部楼层
检查复用功能,确保该引脚未绑定到其他外设(如UART、SPI等)
g0d5xs 发表于 2025-4-19 15:21 | 显示全部楼层
即使不启用互补输出,某些高级定时器(如TIMER0)的寄存器可能仍会强制检查相关配置,需确保 timer_break_config() 中的死区时间设为0,避免意外影响
