直流滤波电容PULOM
2249|0
 楼主| ybh12388 发表于 2013-3-13 13:19 | 显示全部楼层 |阅读模式
PULOM CAP 普隆电子
PCL (PLDCL)系列 平滑滤波电容 直流支撑电容 DC-LNIK电容 铝壳直流滤波电容 (干式)
电压:600-2000Vdc
电容量:50-1000μF        螺母引出,底部有安装支架。单只可以做到1000μF
广泛应用于:风能发电设备,水力发电设备机组,光伏太阳能逆变系统,高压机电设备,电力设备,高压SVG无功补偿装置,高压SVC去谐装置,APF电力补偿装置,电力有源滤波器,发电设备,输电设备,变流器,电工仪表,测试实验器材,感应加热设备,高频设备,高压设备,精密电源,逆变电源,电流发生器,医用电源,船泊工业,新能源汽车工业,电力机车,电力叉车,机车牵引,地铁轻轨机车等新能源产业。
PCL-400-10  PCL-400-15  PCL-400-20  PCL-400-30  PCL-400-40  PCL-400-50  PCL-400-60  PCL-500-10  PCL-500-15  PCL-500-20  PCL-500-30  PCL-500-40  PCL-500-50  PCL-500-60  PCL-700-10  PCL-700-20  PCL-700-25  PCL-700-30  PCL-700-40  PCL-700-50  PCL-700-60  PCL-800-10  PCL-800-20  PCL-800-30  PCL-800-40  PCL-800-50  PCL-800-60  PCL-800-100  PCL-800-150  PCL-800-200  PCL-800-220  PCL-800-270  PCL-800-330  PCL-800-470  PCL-800-550  PCL-800-600  PCL-800-690  PCL-800-780  PCL-800-800  PCL-800-1000 PCL-900-1000  PCL-900-100  PCL-900-150  PCL-900-220  PCL-900-390  PCL-900-470  PCL-1000-100  PCL-1000-150  PCL-1000-220  PCL-1000-330  PCL-1000-470  PCL-1000-500  PCL-1000-600  PCL-1000-800  PCL-1000-900  PCL-1000-1000  PCL-1100-100  PCL-1100-200  PCL-1100-280  PCL-1100-350  PCL-1100-420  PCL-1100-470  PCL-1100-500  PCL-1100-700  PCL-1100-800  PCL-1100-900  PCL-1100-1000  PCL-1200-100  PCL-1200-200  PCL-1200-300  PCL-1200-400  PCL-1200-420  PCL-1200-550  PCL-1200-500  PCL-1200-650  PCL-1200-700  PCL-1200-800  PCL-1200-900  PCL-1200-1000普隆电子:特殊规格尺寸请来电洽询。可为客户订制。
