组合逻辑和时序逻辑的关系
1734|0
 楼主| damoyeren 发表于 2013-6-27 11:12 | 显示全部楼层 |阅读模式
1.下边程序是时序逻辑
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY div_6 IS
GENERIC( DWITH : INTEGER := 6);
PORT( clkin : IN STD_LOGIC;
     clkout: OUT STD_LOGIC
END ENTITY;
ARCHITECTURE arc_div_6 OF div_6 IS
SIGNAL temp : INTEGER RANGE DWITH-1 DOWNTO 0;
BEGIN
PROCESS(clkin)
BEGIN
   IF(clkin'EVENT AND clkin = '1')THEN
    IF( temp = 5 )THEN
     temp <= 0;
    ELSE
     temp <= temp + 1;
    END IF;
   END IF;
END PROCESS;
PROCESS(temp)
BEGIN
   IF temp < DWITH/2 THEN
    clkout <= '0';
   end if;
   if temp > DWITH/2 THEN
   clkout <= '1';
   END IF;
END PROCESS;
END ARCHITECTURE;
2.下边程序是组合逻辑
LIBRARY IEEE;
ENTITY div_6 IS
END ENTITY;
BEGIN
PROCESS(clkin)
BEGIN
    IF( temp = 5 )THEN
     temp <= 0;
    ELSE
     temp <= temp + 1;
    END IF;
   END IF;
END PROCESS;
PROCESS(temp)
BEGIN
    clkout <= '0';
  elsif;
   clkout <= '1';
   END IF;
END PROCESS;
END ARCHITECTURE;
上边的程序就一条语句的差别,怎么就能看出是组合逻辑还是时序逻辑?
