状态机问题
2196|1
 楼主| 天涯落日 发表于 2007-11-14 14:06 | 显示全部楼层 |阅读模式
Warning:&nbsp;Verilog&nbsp;HDL&nbsp;Always&nbsp;Construct&nbsp;warning&nbsp;at&nbsp;maincontrol.v(91):&nbsp;variable&nbsp;&quot;NEXT_state&quot;&nbsp;may&nbsp;not&nbsp;be&nbsp;assigned&nbsp;a&nbsp;new&nbsp;value&nbsp;in&nbsp;every&nbsp;possible&nbsp;path&nbsp;through&nbsp;the&nbsp;Always&nbsp;Construct.&nbsp;&nbsp;Variable&nbsp;&quot;NEXT_state&quot;&nbsp;holds&nbsp;its&nbsp;previous&nbsp;value&nbsp;in&nbsp;every&nbsp;path&nbsp;with&nbsp;no&nbsp;new&nbsp;value&nbsp;assignment,&nbsp;which&nbsp;may&nbsp;create&nbsp;a&nbsp;combinational&nbsp;loop&nbsp;in&nbsp;the&nbsp;current&nbsp;design.<br /><br />请问各位大侠怎么会造成这个问题的?应该怎么解决~~小弟多谢了~~<br />我用的是Verilog&nbsp;HDL
gwbing 发表于 2007-11-18 18:07 | 显示全部楼层
把code贴上来
把code贴上来
