新手求助,sparc的IU的端口?
2826|2
 楼主| ttxs 发表于 2009-1-2 19:37 | 显示全部楼层 |阅读模式
我是本科生,第一次上这个论坛,高手们一定要帮帮我啊:)<br />老师给我一些sparc的资料。用现成的IU扩展出个最小系统。<br />资料封皮:Data&nbsp;Sheet&nbsp;for&nbsp;the&nbsp;SPARC811&nbsp;Chip<br />其中有一些memory&nbsp;subsystem&nbsp;interface&nbsp;signals:<br />A[31:0]&nbsp;ASI[7:0]&nbsp;D[31:0]......<br />WRT(output&nbsp;write&nbsp;tag)&nbsp;<br />I_NULL(output&nbsp;Null&nbsp;Cycle)<br />尤其是这个i_null总是在store指令的后几个流水cycle被置位。书上还说:<br />This&nbsp;signal&nbsp;indicates&nbsp;the&nbsp;current&nbsp;memory&nbsp;access&nbsp;is&nbsp;nullified&nbsp;by&nbsp;the&nbsp;processr.I_Null&nbsp;is&nbsp;used&nbsp;to&nbsp;disable&nbsp;cache&nbsp;miss&nbsp;and&nbsp;memory&nbsp;exception&nbsp;for&nbsp;the&nbsp;current&nbsp;memory&nbsp;access.<br />Under&nbsp;some&nbsp;conditions,&nbsp;the&nbsp;processor&nbsp;is&nbsp;unable&nbsp;to&nbsp;fetch&nbsp;an&nbsp;instruction,&nbsp;usually&nbsp;because&nbsp;a&nbsp;prior&nbsp;multicycle&nbsp;instruction&nbsp;needs&nbsp;to&nbsp;use&nbsp;the&nbsp;bus.When&nbsp;this&nbsp;occurs,&nbsp;the&nbsp;processor&nbsp;asserts&nbsp;I_null&nbsp;to&nbsp;indicate&nbsp;that&nbsp;the&nbsp;current&nbsp;fetch&nbsp;cycle&nbsp;should&nbsp;be&nbsp;nullified.<br />有人熟悉这个吗?I_null信号到底是干什么的?谢谢。<br />
fineamy 发表于 2009-1-3 11:19 | 显示全部楼层
不是说的很清楚吗
I_null你可以用来CS&nbsp;MEMORY,可以省电。可以不用,看你需要。
 楼主| ttxs 发表于 2009-1-4 16:05 | 显示全部楼层
谢谢fineamy
谢谢fineamy
