[ARM入门] DEBUG时出现问题
1177|0
 楼主| xiachu 发表于 2013-10-8 20:13 | 显示全部楼层 |阅读模式
#include "inc/hw_types.h"
#include "inc/hw_memmap.h"
#include "inc/hw_ints.h"
#include "driverlib/sysctl.h"
#include "driverlib/gpio.h"
#include "driverlib/uart.h"
#include "driverlib/interrupt.h"
#include "driverlib/timer.h"
#include "driverlib/pwm.h"
void GPIOPinWrite(unsigned long ulPort, unsigned char ucPins, unsigned char ucVal)
void SysCtlPeripheralEnable(unsigned long ulPeripheral)
int main(void)
        SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOG);
        GPIOPinWrite(GPIO_PORTG_BASE,GPIO_PIN_4,0x1);
        return 0;
在CCSV5环境下  1.调用函数需要再声明吗?我怎么不声明就出错,看很多别人的代码都没有声明 2.这个程序是自己写的 每次debug时都出现CORTEX_M3_0: GEL Output:
Memory Map Initialization Complete
CORTEX_M3_0: GEL Output: Watchdog Timer Enabled
CORTEX_M3_0: GEL Output: UARTs Enabled
CORTEX_M3_0: Flash Programmer: Timed out while writing to Flash memory
CORTEX_M3_0: Trouble Writing Memory Block at 0x0 on Page 0 of Length 0x2f0
CORTEX_M3_0: GEL: File: F:\xuzhetao\CCS\LAB4\Debug\LAB4.out: Load failed.
用的是CCSV5 build的时候正常 debug时就出现这个问题,连接的是LM3S1138开发板,求指导
