[ARM入门] 向LM3S615debug程序时需要将里边的原有程序擦除吗
1635|0
 楼主| xiachu 发表于 2013-10-9 14:09 | 显示全部楼层 |阅读模式
向LM3S615debug程序时需要将里边的原有程序擦除吗?debug上的程序出现cannot load from non-primitive location
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "gpio.h"
#include "sysctl.h"
#define PINS GPIO_PIN_5
void delay(int d)
        for(;d;--d);
//void SysCtlClockSet(unsigned long ulConfig)
//void   SysCtlPeripheralEnable (unsigned long ulPeripheral)
//void GPIODirModeSet(unsigned long ulPort,unsigned char ucPins,unsigned long ulPinIO)
//void GPIOPinWrite(unsigned long ulPort, unsigned char ucPins, unsigned char ucVal)
int main(void)
        unsigned int i;
          SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN|SYSCTL_XTAL_6MHZ);//直接使用外部晶振
          SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);//使能GPIO的PA模块
          GPIODirModeSet(GPIO_PORTA_BASE,PINS,GPIO_DIR_MODE_OUT);//设置PA5输出
          for(i=0;i<10;i++);
                  GPIOPinWrite(GPIO_PORTA_BASE,PINS,0x0);//置PA5低电平
                  delay(20000);
                  GPIOPinWrite(GPIO_PORTA_BASE,PINS,0x1);//置PA5高电平
                  delay(20000);
          SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_PLL|SYSCTL_OSC_MAIN|SYSCTL_XTAL_6MHZ);//使用PLL
          for(i=0;i<10;i++)
          {GPIOPinWrite(GPIO_PORTA_BASE,PINS,PINS);
          delay(20000);
          delay(20000);
          return 0;
ccs v5编译环境
