[NUC120] 新手求指教,nuc120单片机作为I2C 从机的中断接收处理怎么编程
 楼主| www425531304 发表于 2015-7-27 18:17 | 显示全部楼层 |阅读模式
现有2个新塘120,利用I2C通信模式,实现两个MCU 主从通信,主机已完成,从机调试不通,中断处理进不去,请高手指教
/* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved.                                         */
#include <stdio.h>
#include "DrvGPIO.h"
#include "DrvI2C.h"
#include "DrvSYS.h"
#include "DrvUART.h"
/* Global variables        */
uint8_t Device_Addr0;
uint8_t Tx_Data0[3];
uint8_t Rx_Data0;
uint8_t DataLen0;
volatile uint8_t EndFlag0 = 0;
uint8_t  Addr1[3] = {0};
uint8_t  DataLen1;
uint8_t  Slave_Buff1[32] = {0};
uint16_t Slave_Buff_Addr1;
/*  I2C1 (Slave) Callback Function        */
void I2C1_Callback_Slave(uint32_t status)
        printf("   NUC120_HOT_I2C1_Interrupt is running : Status 0x%x \n", status);
    if ((status == 0x60) || (status == 0x68))       /* SLA+W has been received and ACK has been returned */
        DataLen1 = 0;
        DrvI2C_Ctrl(I2C_PORT1, 0, 0, 1, 1);
    else if (status == 0x80)                        /* DATA has been received and ACK has been returned */
        Addr1[DataLen1++] = DrvI2C_ReadData(I2C_PORT1);
        if (DataLen1 == 2)
            Slave_Buff_Addr1 = (Addr1[0] << 8) + Addr1[1];
        if ((DataLen1 == 3) && (Slave_Buff_Addr1 < 32))
            Slave_Buff1[Slave_Buff_Addr1] = Addr1[2];
            DataLen1 = 0;
    else if ((status == 0xB0) || (status == 0xA8))  /* SLA+R has been received and ACK has been returned */
        DrvI2C_WriteData(I2C_PORT1, Slave_Buff1[Slave_Buff_Addr1++]);
        if (Slave_Buff_Addr1 >= 32)
            Slave_Buff_Addr1 = 0;
    else if (status == 0xC0)                        /* DATA has been transmitted and NACK has been received */
    else if (status == 0xA0)                        /* STOP or Repeat START has been received */
        DataLen1 = 0;
    else
        printf("Status 0x%x is NOT processed\n", status);
/*  Main Function        */
int32_t main (void)
    uint32_t u32data, i;
    STR_UART_T sParam;
    UNLOCKREG();
    SYSCLK->PWRCON.XTL12M_EN = 1;
    /* Waiting for 12M Xtal stalble */
    DrvSYS_Delay(5000);
    /* Set UART I/O */
    DrvGPIO_InitFunction(E_FUNC_UART0);
    /* Select UART Clock Source From 12MHz */
    DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC, 0);
    /* UART Setting */
    sParam.u32BaudRate      = 115200;
    sParam.u8cDataBits      = DRVUART_DATABITS_8;
    sParam.u8cStopBits      = DRVUART_STOPBITS_1;
    sParam.u8cParity        = DRVUART_PARITY_NONE;
    sParam.u8cRxTriggerLevel= DRVUART_FIFO_1BYTES;
    /* Set UART Configuration */
    DrvUART_Open(UART_PORT0, &sParam);
    printf("+--------------------------------------------------------+\n");
    printf("|                 I2C Slave  Driver Sample Code          |\n");
    printf("   I/O Configuration:    \n");
    printf("   I2C1 SCL <-->PIN 4    \n");
    printf("   I2C1 SDA <-->PIN 5    \n");
        printf("   I2C1 VCC <-->I2C0 VCC \n");
        printf("   I2C1 GND <-->I2C0 GND \n");
    printf("\n");
    /* Set I2C I/O */
    DrvGPIO_InitFunction(E_FUNC_I2C1);
    /* Open I2C1, and set clock = 100Kbps */
    DrvI2C_Open(I2C_PORT1, 100000);
    /* Set I2C0 slave addresses */
//    DrvI2C_SetAddress(I2C_PORT0, 0, 0x15, 0);
//    DrvI2C_SetAddress(I2C_PORT0, 1, 0x35, 0);
//    DrvI2C_SetAddress(I2C_PORT0, 2, 0x55, 0);
//    DrvI2C_SetAddress(I2C_PORT0, 3, 0x75, 0);
    /* Set I2C1 slave addresses */
    DrvI2C_SetAddress(I2C_PORT1, 0, 0x16, 0);
    DrvI2C_SetAddress(I2C_PORT1, 1, 0x36, 0);
    DrvI2C_SetAddress(I2C_PORT1, 2, 0x56, 0);
    DrvI2C_SetAddress(I2C_PORT1, 3, 0x76, 0);
    for (i = 0; i < 32; i++)
        Slave_Buff1[i] = 0;
    /* Set AA bit, I2C1 as slave (To simulate a 24LXX EEPROM) */
    DrvI2C_Ctrl(I2C_PORT1, 0, 0, 0, 1);
    /* Enable I2C1 interrupt and set corresponding NVIC bit */
    DrvI2C_EnableInt(I2C_PORT1);
    /* Install I2C1 call back function for slave */
    DrvI2C_InstallCallback(I2C_PORT1, I2CFUNC, I2C1_Callback_Slave);
    printf("\n");
    printf("I2C Slave Mode is Running.\n");
     while(1);
 楼主| www425531304 发表于 2015-7-27 19:58 | 显示全部楼层
I2C   从机处理代码
