[应用相关] STM32F3做FFT算出频率和实际有偏差
 楼主| mm7989680 发表于 2016-11-2 11:39 | 显示全部楼层 |阅读模式
STM32F303的ADC采样后做FFT算频率,ADC时钟72M,采样间隔74个ADC cycles,采样频率约972.972K,大于那奎斯特采样要求,采样数量1024个点,信号源信号频率200K,3.00Vpp,offset1.65Vdc,实际算出来频率190033.593750,为什么FFT结果差了约10K,而且采样频率越低,算出来的准确度还高些,高了反而差距大?
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_DAC1_Init();
  MX_TIM2_Init();
  MX_ADC1_Init();
  MX_TIM3_Init();
  MX_USART2_UART_Init();
  /* USER CODE BEGIN 2 */
        HAL_TIM_Base_Start(&htim2);
        HAL_TIM_Base_Start(&htim3);
////        HAL_DAC_SetValue(&hdac1, DAC_CHANNEL_1, DAC_ALIGN_12B_R, 0);
////        HAL_DAC_Start_DMA(&hdac1, DAC_CHANNEL_1,(uint32_t*) Sine, 32, DAC_ALIGN_12B_R);
        HAL_ADCEx_Calibration_Start(&hadc1,ADC_SINGLE_ENDED);
        HAL_ADC_Start_DMA(&hadc1, (uint32_t*) ReadData, Num);
////        HAL_ADC_Stop_DMA(&hadc1);
//        HAL_DAC_Start_DMA(&hdac1, DAC_CHANNEL_2, (uint32_t*) ReadData, Num, DAC_ALIGN_8B_R);
//        HAL_UART_Transmit_DMA(&huart2, (uint8_t*) ReadData, Num);
//        HAL_UART_Transmit(&huart2, 0x11, 1, 0xFFFF);
//        printf("\r\nADC was Down!\r\n");
        for(int i=0;i<Num;i++)
                ADC_ConvertedValue[2*i]=(float)(ReadData&0xFF)*3.3/256;                                        //将ADC取到的值转化为0-3.3的电压值,为实部
                ADC_ConvertedValue[2*i+1]=0;        //虚部为0
//        for(int i=0;i<Num;i++)
//                ADC_ConvertedValue[2*i]=(float)(ReadData&0xFF);                                        //将ADC取到的值转化为0-3.3的电压值,为实部
//                ADC_ConvertedValue[2*i+1]=0;        //虚部为0
        arm_cfft_f32(&arm_cfft_sR_f32_len1024, ADC_ConvertedValue, ifftFlag, doBitReverse);
        arm_cmplx_mag_f32(ADC_ConvertedValue, testOutput, Num);
        for(uint32_t i=0;i<Num;i++)
                printf("fft_outputbuf[%d]:%f\r\n",i,testOutput);
        testOutput[0]=0;
  /* Calculates maxValue and returns corresponding BIN value */
  arm_max_f32(testOutput, Num/2, &maxValue, &testIndex);
        Frequence = (((float32_t)testIndex+1)/(float32_t)Num)*(72000000/74);
        printf("maxValue is %f\r,corresponding BIN value is %d\r,frequence is %f\r\n",maxValue,testIndex,Frequence);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
 楼主| mm7989680 发表于 2016-11-3 16:42 | 显示全部楼层
ADC   8bit改到12bit准确度一下子提高了  现在基本只差2K了,信号源幅度降到100mV也很准,什么原因?按理位数变化影响不会这么大
nstel 发表于 2016-11-3 17:12 | 显示全部楼层
ADC的采样电路有没有问题呢?
icecut 发表于 2016-11-3 18:26 | 显示全部楼层
你先看看你踩到的值是不是对的.或者说看看直流分量是不是正常.
 楼主| mm7989680 发表于 2016-11-3 19:57 | 显示全部楼层
ADC的采样电路有没有问题呢?
ADC用的是STAM32内置的
wangguanfu 发表于 2016-11-4 08:28 来自手机 | 显示全部楼层
能整工程打包
能整个工程打包上来?
shalixli 发表于 2016-11-4 08:47 | 显示全部楼层
FFT 如何计算频率 ?  好像 FFT不是用来计算频率的吧, FFT是把频域 转 时域的。
因此  楼主 的  基本原理 都没有弄清楚!  大错特错!
 楼主| mm7989680 发表于 2016-11-7 18:48 | 显示全部楼层
因此  楼主 的  基本原理 ...
呵呵
xxzouzhichao 发表于 2016-11-8 08:31 来自手机 | 显示全部楼层
采样率得是被测频率的4/8/16/32……倍才能计算精确,否则会有频谱泄露,如果能满足整数倍,那就用dft
小曾1220 发表于 2016-11-8 13:44 | 显示全部楼层
sl_168 发表于 2016-11-8 16:50 | 显示全部楼层
时钟及采样点的误差引起的。
shalixli 发表于 2016-11-8 17:48 | 显示全部楼层
楼主真是很傻很天真。
FFT的结果   就是频域的 模。 就是你的采样率 FS 扯蛋的关系。 这个是理论的扯蛋关系, 实际的中断,ADC保持,转换时间。。。。。够你TMD从扯蛋的。
因此,用FFT方法计算频率的人,都是很傻很天真的 小学生。
你的公式 死定的就是   2/1024 *  FS
这里 你 测量出真正的FS频率。就不会有什么误差。 这个靠测量,而你的参数是72MHZ  74个ADC 设置,按理想计算的就是 那个FS,
因此 计算出来就是 190K,
呵呵。 真实的FS是多少? 你可以反推算出来的, 因为你知道你的信号是200KHZ,
但是如果你不知道,不确定你的信号是多少情况下呢?我问你,如何计算?
fxmxh_ 发表于 2016-11-9 08:43 | 显示全部楼层
楼猪,现在弄啥成了?
