[其他] 【MM32F5270开发板试用】+ TFTLCD IO口方式驱动
 楼主| wowu 发表于 2023-1-29 12:14 | 显示全部楼层 |阅读模式
测试下使用开发板IO口方式驱动16位总线TFTLCD。
一、电路图
开发板上LCD接口部分电路图
转接板
硬件接口设计中间转接板,将开发板的接口定义转换成显示屏模块的接口。!
二、代码
st7789.c
#include "board_init.h"
#include "hal_gpio.h"
#include "hal_rcc.h"
#include "st7789s.h"
#include "delay.h"
#include "font.h"
uint16_t POINT_COLOR=0x0000;    //»­±ÊÑÕÉ«
uint16_t BACK_COLOR=0xFFFF;  //±³¾°É«
_lcd_dev lcddev;
static void ST7789_Reset(void)
    LCD_SetRst();
    delay_ms(1);
    LCD_ClrRst();
    delay_ms(10); // Delayms 10ms               // This delay time is necessary
    LCD_SetRst();
    delay_ms(120); // Delayms 120 ms
void ST7789_Gpio_Writedat(uint16_t dat)
    uint16_t temp_rpd, rpd;
    uint16_t temp_rpe, rpe;
    temp_rpd=GPIO_ReadOutData(GPIOD);
    rpd=((dat>>5)&0x700) | ((dat<<14)&0xc000) | ((dat>>2)&0x03);
    temp_rpd= (temp_rpd&(~0xc703))|rpd;
    GPIO_WriteBits(GPIOD,temp_rpd);
    //printf("rpd=%04x\r\n",rpd);
    temp_rpe=temp_rpd=GPIO_ReadOutData(GPIOE);
    rpe=(dat<<3)&0xff80; //1111 1111 1000 0000
    temp_rpe=(temp_rpe&(~0xff80))|rpe;
    GPIO_WriteBits(GPIOE,temp_rpe);
    //printf("rpe=%04x\r\n",rpe);
/*    temp_rpd=GPIO_ReadOutData(GPIOD)&0xc703;//1100 0111 0000 0011
    printf("dat =%04x  ,   ",dat);
    printf("temp_rpd=%04x  ,   ",temp_rpd);
    temp_rpe=GPIO_ReadOutData(GPIOE)&0xff80; //1111 1111 1000 0000
    printf("temp_rpe=%04x\r\n",temp_rpe);*/
void ST7789_WriteCommand(uint16_t cmd)
    LCD_ClrCs();  //cs=0
  LCD_ClrRs();  //rs=0
    LCD_SetRd();  //rd=1
  LCD_ClrWr();  //wr=0
    //GPIO_Write(GPIOE, cmd);
    ST7789_Gpio_Writedat(cmd);
  LCD_SetWr();   //wr=1
  LCD_SetCs();   //cs=1
    LCD_SetRs();   //rs=1
void ST7789_WriteData(uint16_t dat)
    LCD_SetRs();  //rs=1
  LCD_ClrCs();  //cs=0
  LCD_SetRd();  //rd=1
    LCD_ClrWr();  //wr=0
    ST7789_Gpio_Writedat(dat);
    LCD_SetWr();   //wr=1
  LCD_SetCs();   //cs=1
//ÉèÖÃLCDÏÔʾ·½Ïò
//dir:0,ÊúÆÁ£»1,ºáÆÁ
void LCD_Display_Dir(uint8_t dir)
    if(dir==0)            //ÊúÆÁ
        lcddev.dir=0;    //ÊúÆÁ
        lcddev.width=240;
        lcddev.height=320;
    }else                 //ºáÆÁ
        lcddev.dir=1;    //ºáÆÁ
        lcddev.width=320;
        lcddev.height=240;
    //LCD_Scan_Dir(DFT_SCAN_DIR);    //ĬÈÏɨÃè·½Ïò
void init_st7789s(void)
        GPIO_Init_Type gpio_init;
    /* GPIOD. */
    RCC_EnableAHB1Periphs(RCC_AHB1_PERIPH_GPIOD, true);
    RCC_ResetAHB1Periphs(RCC_AHB1_PERIPH_GPIOD);
    /* GPIOE. */
    RCC_EnableAHB1Periphs(RCC_AHB1_PERIPH_GPIOE, true);
    RCC_ResetAHB1Periphs(RCC_AHB1_PERIPH_GPIOE);
        /* GPIOG. */
    RCC_EnableAHB1Periphs(RCC_AHB1_PERIPH_GPIOG, true);
    RCC_ResetAHB1Periphs(RCC_AHB1_PERIPH_GPIOG);
    gpio_init.Pins  = GPIO_PIN_15|GPIO_PIN_14|GPIO_PIN_10|GPIO_PIN_9|GPIO_PIN_8|GPIO_PIN_5|GPIO_PIN_4|GPIO_PIN_1|GPIO_PIN_0;
    gpio_init.PinMode  = GPIO_PinMode_Out_PushPull;
    gpio_init.Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOD, &gpio_init);
    gpio_init.Pins  = GPIO_PIN_15|GPIO_PIN_14|GPIO_PIN_13|GPIO_PIN_12|GPIO_PIN_11|GPIO_PIN_10|GPIO_PIN_9|GPIO_PIN_8|GPIO_PIN_7|GPIO_PIN_3|GPIO_PIN_2;
    GPIO_Init(GPIOE, &gpio_init);
        gpio_init.Pins  = GPIO_PIN_11|GPIO_PIN_12;
    GPIO_Init(GPIOG, &gpio_init);
        ST7789_Reset();
        ST7789_WriteCommand(0x0011);        //exit SLEEP mode
        delay_ms(120);
        ST7789_WriteCommand(0x0036);
        ST7789_WriteData(0x0060);            //MADCTL: memory data access control
        ST7789_WriteCommand(0x003A);
        ST7789_WriteData(0x0005);            //COLMOD: Interface Pixel format *** I use 262K-colors in 18bit/pixel format when using 8-bit interface to allow 3-bytes per pixel
    //    ST7789_WriteCommand(0x003A);ST7789_WriteData(0x0055);//COLMOD: Interface Pixel format  *** I use 65K-colors in 16bit/pixel (5-6-5) format when using 16-bit interface to allow 1-byte per pixel
        ST7789_WriteCommand(0x00B2);
        ST7789_WriteData(0x000C);
        ST7789_WriteData(0x0000);
        ST7789_WriteData(0x0033);
        ST7789_WriteData(0x0033);            //PORCTRK: Porch setting
        ST7789_WriteCommand(0x00B7);
        ST7789_WriteData(0x0035);            //GCTRL: Gate Control
        ST7789_WriteCommand(0x00BB);
        ST7789_WriteData(0x001c);            //VCOMS: VCOM setting
        ST7789_WriteCommand(0x00C0);
        ST7789_WriteData(0x002C);            //LCMCTRL: LCM Control
        ST7789_WriteCommand(0x00C2);
        ST7789_WriteData(0x0001);
        ST7789_WriteData(0x00FF);            //VDVVRHEN: VDV and VRH Command Enable
        ST7789_WriteCommand(0x00C3);
        ST7789_WriteData(0x000B);            //VRHS: VRH Set
        ST7789_WriteCommand(0x00C4);
        ST7789_WriteData(0x0020);            //VDVS: VDV Set
        ST7789_WriteCommand(0x00C6);
        ST7789_WriteData(0x000F);            //FRCTRL2: Frame Rate control in normal mode
        ST7789_WriteCommand(0x00D0);
        ST7789_WriteData(0x00A4);
        ST7789_WriteData(0x00A1);            //PWCTRL1: Power Control 1
        ST7789_WriteCommand(0x00E0);
        ST7789_WriteData(0x00D0);
        ST7789_WriteData(0x0003);
        ST7789_WriteData(0x0009);
        ST7789_WriteData(0x0013);
        ST7789_WriteData(0x003a);
        ST7789_WriteData(0x0048);
        ST7789_WriteData(0x0018);
        ST7789_WriteData(0x0012);
        ST7789_WriteData(0x000e);
        ST7789_WriteData(0x0019);
        ST7789_WriteData(0x001e);            //PVGAMCTRL: Positive Voltage Gamma control
        ST7789_WriteCommand(0x00E1);
        ST7789_WriteData(0x0025);
        ST7789_WriteData(0x0050);
        ST7789_WriteData(0x003d);
        ST7789_WriteData(0x001d);
        ST7789_WriteCommand(0x0029);                //display ON
        ST7789_WriteCommand(0x002c);
        printf("\n\r st7789 init ok! \r  ");
        LCD_Display_Dir(1);
        LCD_BLA_ON();
void Lcd_SetBox(uint16_t xStart, uint16_t yStart, uint16_t xlong, uint16_t ylong)
    uint16_t xEnd=0, yEnd=0;
    xEnd=xStart+xlong-1;
    yEnd=yStart+ylong-1;
    ST7789_WriteCommand(0x2a);
    ST7789_WriteData(xStart>>8);
    ST7789_WriteData(xStart);
    ST7789_WriteData(xEnd>>8);
    ST7789_WriteData(xEnd);
    ST7789_WriteCommand(0x2b);
    ST7789_WriteData(yStart>>8);
    ST7789_WriteData(yStart);
    ST7789_WriteData(yEnd>>8);
    ST7789_WriteData(yEnd);
    ST7789_WriteCommand(0x2c);
void Lcd_SetBox1(uint16_t xStart, uint16_t xEnd, uint16_t yStart, uint16_t yEnd)
void LCD_WriteOneDot(uint16_t color)
    ST7789_WriteData(color);
void LCD_Clear(uint16_t Color)
   uint32_t i;
   Lcd_SetBox(0,0,320,240);
   for(i=0;i<78900;i++){
       LCD_WriteOneDot(Color);
void ST7789_SetPoint(uint16_t x, uint16_t y, uint16_t color)
    Lcd_SetBox1(x,x+1,y,y+1);
    LCD_WriteOneDot(color);
//ÔÚÖ¸¶¨Î»ÖÃÏÔʾһ¸ö×Ö·û
//x,y:ÆðÊ¼×ø±ê
//num:ÒªÏÔʾµÄ×Ö·û:" "--->"~"
//size:×ÖÌå´óС 12/16/24
//mode:µþ¼Ó·½Ê½(1)»¹ÊǷǵþ¼Ó·½Ê½(0)
void LCD_ShowChar(uint16_t x, uint16_t y, uint8_t num, uint8_t size, uint8_t mode)
    uint8_t temp,t1,t;
    uint8_t y0=y;
    uint8_t csize=(size/8+((size%8)?1:0))*(size/2);        //µÃµ½×ÖÌåÒ»¸ö×Ö·û¶ÔÓ¦µãÕó¼¯ËùÕ¼µÄ×Ö½ÚÊý
     num=num-' ';//µÃµ½Æ«ÒƺóµÄÖµ£¨ASCII×Ö¿âÊÇ´Ó¿Õ¸ñ¿ªÊ¼È¡Ä££¬ËùÒÔ-' '¾ÍÊǶÔÓ¦×Ö·ûµÄ×ֿ⣩
    for(t=0;t<csize;t++)
        if(size==12)temp=asc2_1206[num][t];          //µ÷ÓÃ1206×ÖÌå
        else if(size==16)temp=asc2_1608[num][t];    //µ÷ÓÃ1608×ÖÌå
        else if(size==24)temp=asc2_2412[num][t];    //µ÷ÓÃ2412×ÖÌå
        else return;                                //ûÓеÄ×Ö¿â
        for(t1=0;t1<8;t1++)
            if(temp&0x80)ST7789_SetPoint(x,y,POINT_COLOR);
            else if(mode==0)ST7789_SetPoint(x,y,BACK_COLOR);
            temp<<=1;
            y++;
            if(y>=lcddev.height)return;        //³¬ÇøÓòÁË
            if((y-y0)==size)
                y=y0;
                x++;
                if(x>=lcddev.width)return;    //³¬ÇøÓòÁË
                break;
//ÏÔʾ×Ö·û´®
//x,y:Æðµã×ø±ê
//width,height:ÇøÓò´óС
//size:×ÖÌå´óС
//*p:×Ö·û´®ÆðʼµØÖ·
void LCD_ShowString(uint16_t x, uint16_t y, uint16_t width, uint16_t height, uint8_t size, uint8_t *p)
    uint8_t x0=x;
    width+=x;
    height+=y;
    while((*p<='~')&&(*p>=' '))//ÅжÏÊDz»ÊÇ·Ç·¨×Ö·û!
        if(x>=width){x=x0;y+=size;}
        if(y>=height)break;//Í˳ö
        LCD_ShowChar(x,y,*p,size,0);
        x+=size/2;
        p++;
st7789.h
#ifndef __ST7789S_H__
#define __ST7789S_H__
typedef struct
    uint16_t width;
    uint16_t height;
    uint16_t id;
    uint8_t  dir;
    uint16_t    wramcmd;
    uint16_t  setxcmd;
    uint16_t  setycmd;
}_lcd_dev;
extern _lcd_dev lcddev;
extern uint16_t  POINT_COLOR;
extern uint16_t  BACK_COLOR;
#define    BLACK    0x0000
#define    BLUE    0x001F
#define    RED     0xF800
#define    GREEN     0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW    0xFFE0
#define WHITE    0xFFFF
#define BACKCOLOR 0xFFFF
#define    WORDCOLOR 0x0000
/* Ƭѡ */
#define LCD_SetCs()     {GPIO_WriteBit(GPIOG, GPIO_PIN_12, 1u);}
#define LCD_ClrCs()     {GPIO_WriteBit(GPIOG, GPIO_PIN_12, 0u);}
/* ¸´Î» */
#define LCD_SetRst()     {GPIO_WriteBit(GPIOG, GPIO_PIN_11, 1);}
#define LCD_ClrRst()     {GPIO_WriteBit(GPIOG, GPIO_PIN_11, 0);}
/* /RD */
#define LCD_SetRd()     {GPIO_WriteBit(GPIOD, GPIO_PIN_4, 1);}
#define LCD_ClrRd()        {GPIO_WriteBit(GPIOD, GPIO_PIN_4, 0);}
/* /WR */
#define LCD_SetWr()     {GPIO_WriteBit(GPIOD, GPIO_PIN_5, 1);}
#define LCD_ClrWr()     {GPIO_WriteBit(GPIOD, GPIO_PIN_5, 0);}
/* BLA */
#define LCD_BLA_ON()         {GPIO_WriteBit(GPIOE, GPIO_PIN_3, 1);}
#define LCD_BLA_OFF()     {GPIO_WriteBit(GPIOE, GPIO_PIN_3, 0);}
/* RS */
#define LCD_SetRs()     {GPIO_WriteBit(GPIOE, GPIO_PIN_2, 1);}
#define LCD_ClrRs()     {GPIO_WriteBit(GPIOE, GPIO_PIN_2, 0);}
void init_st7789s(void);
void LCD_Clear(uint16_t Color);
void LCD_ShowString(uint16_t x, uint16_t y, uint16_t width, uint16_t height, uint8_t size, uint8_t *p);
#endif
main.c
* Copyright 2021 MindMotion Microelectronics Co., Ltd.
* All rights reserved.
* SPDX-License-Identifier: BSD-3-Clause
#include "hal_flexcan.h"
#include "led.h"
#include "key.h"
#include "delay.h"
#include "flexcan.h"
int main(void)
        BOARD_Init();
        delay_init();
        init_led();
        //init_key();
        //init_flexcan1();
        init_st7789s();
        POINT_COLOR=RED;
        LCD_Clear(WHITE);
        printf("\r\nmm32f5270 test.\r\n");
        LCD_ShowString(30,40,210,24,24,"MM32F5270");
        LCD_ShowString(30,70,200,16,16,"TFTLCD TEST");
        LCD_ShowString(30,90,200,16,16,"ST7789");
        LCD_ShowString(30,110,200,16,16,"2022/09/01");
        LCD_ShowString(30,150,210,24,24,"https://aijishu.com");
        while(1)
                GPIO_WriteBit(BOARD_LED0_GPIO_PORT, BOARD_LED0_GPIO_PIN, 1u);
                delay_ms(100);
                GPIO_WriteBit(BOARD_LED0_GPIO_PORT, BOARD_LED0_GPIO_PIN, 0u);
                delay_ms(100);
三、程序运行
版权声明:本文为CSDN博主「极术社区」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/weixin_47569031/article/details/127427099
单片小菜 发表于 2023-1-29 16:52 | 显示全部楼层
这个板子布置的不错,很规整。
eefas 发表于 2023-4-15 19:40 | 显示全部楼层
单片机怎么驱动TFT液晶屏
jackcat 发表于 2023-4-16 21:55 | 显示全部楼层
刷屏帧数是多少呢
mickit 发表于 2023-4-16 22:41 | 显示全部楼层
这个是使用的oled接口吗?
1988020566 发表于 2023-4-16 22:47 | 显示全部楼层
如何驱动控制TFT屏的显示?
maudlu 发表于 2023-4-16 23:00 | 显示全部楼层
tft模块液晶屏,具体怎么写程序
hilahope 发表于 2023-4-18 13:44 | 显示全部楼层
是否可用接彩色TFT 液晶屏?
trucyw 发表于 2024-5-3 21:17 | 显示全部楼层
这个怎么和前面的PCB不一样呢,重新做板了吗
caigang13 发表于 2024-5-4 08:35 来自手机 | 显示全部楼层
这个还是传统的8位并行驱动接口
zeshoufx 发表于 2024-12-20 09:20 | 显示全部楼层
怎么看着是用IO模拟时序的呢
suncat0504 发表于 2024-12-23 12:12 | 显示全部楼层
并行驱动接口,占用的口线多,但传输速度比SPI的快。
