- #include "common.h"
- #include "ics.h"
- #include "rtc.h"
- #include "uart.h"
- #include "kbi.h"
- #include "gpio.h"
- #include "sysinit.h"
- int main (void);
- void RTC_Task(void);
- void KBI0_Task(void);
- void KBI1_Task(void);
- int maiChongCiShu=0;//脉冲次数
- int waittime=0;//脉冲前等待时间
- int waittimeHOU=0;//脉冲后等待时间
- int dangWei=0;//挡位
- int dangWeix=0;//脉冲设置等待时间
- int main (void)
- uint8_t u8Ch,i;
- ICS_ConfigType sICSConfig;
- RTC_ConfigType sRTCConfig;
- RTC_ConfigType *pRTCConfig = &sRTCConfig;
- KBI_ConfigType sKBIConfig;
- /* Perform processor initialization */
- sysinit();
- printf("\nRunning the KBI_demo project.\n");
- LED0_Init(); //D2,Middle
- LED1_Init(); //D3,RIGHT
- LED2_Init(); //D4,LEFT
- LED1_Off();
- LED0_Off();
- LED2_Off();
- /* configure RTC to 1Hz interrupt frequency */
- pRTCConfig->u16ModuloValue = 9;
- pRTCConfig->bInterruptEn = RTC_INTERRUPT_ENABLE; /* enable interrupt */
- pRTCConfig->bClockSource = RTC_CLKSRC_BUS; /*clock source is 1khz*/
- pRTCConfig->bClockPresaler = RTC_CLK_PRESCALER_1024; /*prescaler is 100*/
- RTC_SetCallback(RTC_Task);
- RTC_Init(pRTCConfig);
- printf("\nin FEE mode now,");
- UART_WaitTxComplete(TERM_PORT);
- /* switch clock mode from FEI to FEE */
- sICSConfig.u32ClkFreq = 32;
- ICS_SwitchMode(FEE,FEI, &sICSConfig);
- // printf("switch to FEI mode.\n");
- OSC_Enable();
- /* Disable all the KBI pins */
- for (i = 0; i < KBI_MAX_PINS_PER_PORT; i++)
- sKBIConfig.sPin[i].bEn = 0;
- sKBIConfig.sBits.bMode = KBI_MODE_EDGE_ONLY;
- sKBIConfig.sPin[0].bEdge = KBI_FALLING_EDGE_LOW_LEVEL;
- sKBIConfig.sBits.bIntEn = 1;
- sKBIConfig.sPin[0].bEn = 1;
- KBI_Init(KBI0, &sKBIConfig);
- KBI_Init(KBI1, &sKBIConfig);
- KBI_SetCallback(KBI0, &KBI0_Task);
- KBI_SetCallback(KBI1, &KBI1_Task);
- /* echo chars received from terminal */
- GPIO_Init(GPIOA, GPIO_PTB2_MASK, GPIO_PinOutput);
- /* set PTB2 output 0 */
- GPIO_PinClear(GPIO_PTB2);
- if(dangWeix>0)
- dangWeix--;
- if(waittimeHOU>0)
- waittimeHOU--;
- if(waittime>0)
- waittime--;
- else if(maiChongCiShu>0){
- FGPIO_Toggle(FGPIOA, GPIO_PTB2_MASK);
- maiChongCiShu--;
- waittimeHOU=1000;
- }else
- FGPIO_Write(FGPIOA,0);
- // LED2_Toggle();
- if((waittime+maiChongCiShu+waittimeHOU)==0){
- maiChongCiShu=dangWei*2+5;
- waittime=256;
- //DangWei,0-7,show By Led
- //LED2,LED0,LED1=gao,zhong,di
- if(dangWeix==0){
- dangWei=(dangWei+1)%8;
- dangWeix=1120;
- if(dangWei&1)
- LED1_On();
- else
- LED1_Off();
- if(dangWei&2)
- LED0_On();
- else
- LED0_Off();
- if(dangWei&4)
- LED2_On();
- else
- LED2_Off();
点焊机程序写好了,本来很简单。不过按键没硬件消抖,搞了好几次延迟
