library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity load_A is
PORT(
clk_50 :IN STD_LOGIC; --输入主频
pin_out :OUT STD_LOGIC --输出管脚
end load_A;
architecture Behavioral of load_A is
SIGNAL output_reg:STD_LOGIC:='1';
BEGIN
PROCESS
VARIABLE cnt: INTEGER RANGE 0 to 500;
BEGIN
WAIT UNTIL(RISING_EDGE(clk_50));
IF cnt=50 THEN
cnt:=0;
output_reg<='0';
ELSE
cnt:=cnt+1;
END IF;
END PROCESS;
pin_out<=output_reg;
end Behavioral;
