[STM32] 立创商城ATK_ESP8266模块atk_8266_test函数讲解
 楼主| 小乐Tzz 发表于 2018-8-16 09:36 | 显示全部楼层 |阅读模式
atk_8266_test函数
作用:ATK-ESP8266模块测试主函数
//ATK-ESP8266模块测试主函数
void atk_8266_test(void)
  u8 key;
  u8 timex;
  POINT_COLOR=RED;
  Show_Str_Mid(0,30,"ATK-ESP8266 WIFI模块测试",16,240);
  while(atk_8266_send_cmd("AT","OK",20))//检查 WIFI模块是否在线
    atk_8266_quit_trans();//退出透传
    atk_8266_send_cmd("AT+CIPMODE=0","OK",200);  //关闭透传模式
    Show_Str(40,55,200,16,"未检测到模块!!!",16,0);
    delay_ms(800);
    LCD_Fill(40,55,200,55+16,WHITE);
    Show_Str(40,55,200,16,"尝试连接模块...",16,0);
    while(atk_8266_send_cmd("ATE0","OK",20));//关闭回显
    atk_8266_mtest_ui(32,30);
  while(1)
    delay_ms(10);
    atk_8266_at_response(1);
//检查ATK-ESP8266 模块发送过来的数据,及时上传给电脑
    key=KEY_Scan(0);
    if(key)
      LCD_Clear(WHITE);
      POINT_COLOR=RED;
      switch(key)
        case 1:  //KEY0
          Show_Str_Mid(0,30,"ATK-ESP WIFI-AP+STA 测试",16,240);
Show_Str_Mid(0,50,"正在配置ATK-ESP8266模块,请稍
等...",12,240);
          atk_8266_apsta_test();    //AP+STA 测试
          break;
        case 2:  //KEY1
          Show_Str_Mid(0,30,"ATK-ESP WIFI-STA  测试",16,240);
            等...",12,240);           atk_8266_wifista_test();   //WIFI STA 测试
          break;
        case 4:  //WK_UP
          atk_8266_wifiap_test();    //WIFI AP 测试
          break;
      timex=0;
    if((timex%20)==0)LED0=!LED0;//200ms 闪烁
    timex++;
该函数是ATK-ESP8266模块测试的主程序,先检查模块是否存在,在检测模块正常后,然后初始化模块为AP 模式,接着进入模式选择界面,最后通过按键选择进入对应的子功能进行测试,通过三个子功能测试函数:atk_8266_apsta_test、atk_8266_wifista_test 和atk_8266_wifiap_test进行测试
【立创商城】ESP8266EX 编带  https://item.szlcsc.com/79101.html
