- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * $Revision: 2 $
- * $Date: 20/05/28 4:41p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Implement CRC in CRC-8 mode and get the CRC checksum result.
- * SPDX-License-Identifier: Apache-2.0
- * Copyright (C) 2020 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NuMicro.h"
- void SYS_Init(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Enable HIRC clock */
- CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
- /* Waiting for HIRC clock ready */
- CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
- /* Switch HCLK clock source to HIRC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Enable UART0 clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Switch UART0 clock source to HIRC */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
- /* Enable CRC clock */
- CLK_EnableModuleClock(CRC_MODULE);
- /* Update System Core Clock */
- SystemCoreClockUpdate();
- /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
- SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk))
- |(SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
- /* Lock protected registers */
- SYS_LockReg();
- /* MAIN function */
- int main(void)
- const uint8_t acCRCSrcPattern[] = {0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39};
- uint32_t i, u32TargetChecksum = 0x58, u32CalChecksum = 0;
- SYS_UnlockReg();
- /* Init System, peripheral clock and multi-function I/O */
- SYS_Init();
- SYS_LockReg();
- /* Init UART0 to 115200-8n1 for print message */
- UART_Open(UART0, 115200);
- printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
- printf("+-----------------------------------------+\n");
- printf("| CRC-8 Polynomial Mode Sample Code |\n");
- printf("+-----------------------------------------+\n\n");
- printf("# Calculate [0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39] CRC-8 checksum value.\n");
- printf(" - Seed value is 0x5A \n");
- printf(" - CPU write data length is 8-bit \n");
- printf(" - Checksum complement disable \n");
- printf(" - Checksum reverse disable \n");
- printf(" - Write data complement disable \n");
- printf(" - Write data reverse disable \n");
- printf(" - Checksum should be 0x%X \n\n", u32TargetChecksum);
- /* Configure CRC controller for CRC-8 CPU mode */
- CRC_Open(CRC_8, 0, 0x5A, CRC_WDATA_8);
- /* Start to execute CRC-8 CPU operation */
- for(i = 0; i < sizeof(acCRCSrcPattern); i++)
- CRC_WRITE_DATA(acCRCSrcPattern[i]);
- /* Get CRC-8 checksum value */
- u32CalChecksum = CRC_GetChecksum();
- printf("CRC checksum is 0x%X ... %s.\n", u32CalChecksum, (u32CalChecksum == u32TargetChecksum) ? "PASS" : "FAIL");
- /* Disable CRC function */
- CLK_DisableModuleClock(CRC_MODULE);
- while(1);
- /*** (C) COPYRIGHT 2020 Nuvoton Technology Corp. ***/
