- #include <rtthread.h>
- #include "stm32f10x.h"
- // 分辨率(H:0-479 V:0-271)
- unsigned int HDP=479;
- unsigned int VDP=271;
- unsigned int HT=531;
- unsigned int HPS=43;
- unsigned int LPS=8;
- unsigned char HPW=1;
- unsigned int VT=288;
- unsigned int VPS=12;
- unsigned int FPS=4;
- unsigned char VPW=10;
- #define Bank1_LCD_D ((uint32_t)0x60020000) //disp Data ram
- #define Bank1_LCD_C ((uint32_t)0x60000000) //disp Reg ram
- void Delay(__IO uint32_t nCount)
- for(; nCount != 0; nCount--);
- void LCD_WR_REG(u16 index)
- *(__IO uint16_t *) (Bank1_LCD_C)= index;
- u16 LCD_RD_DAT(void)
- u16 a=0;
- a=*(__IO uint16_t *) (Bank1_LCD_D);
- return(a);
- void LCD_WR_DAT(u16 val)
- *(__IO uint16_t *) (Bank1_LCD_D)= val;
- void _set_window(u16 x1, u16 y1, u16 x2, u16 y2)
- LCD_WR_REG(0x002A);
- LCD_WR_DAT(x1>>8);
- LCD_WR_DAT(x1&0x00ff);
- LCD_WR_DAT(x2>>8);
- LCD_WR_DAT(x2&0x00ff);
- LCD_WR_REG(0x002b);
- LCD_WR_DAT(y1>>8);
- LCD_WR_DAT(y1&0x00ff);
- LCD_WR_DAT(y2>>8);
- LCD_WR_DAT(y2&0x00ff);
- void _set_cursor(u16 x,u16 y)
- _set_window(x, y, HDP, VDP);
- void lcd_set_pixel(const char* pixel, int x, int y)
- _set_cursor(x, y);
- LCD_WR_REG(0x2c);
- LCD_WR_DAT(*(rt_uint16_t*)pixel);
- void lcd_get_pixel(char* pixel, int x, int y)
- LCD_WR_REG(0x2e);
- *(rt_uint16_t*)pixel = LCD_RD_DAT();
- void lcd_draw_hline(const char* pixel, int x1, int x2, int y)
- _set_cursor(x1, y);
- LCD_WR_REG(0x2c);
- while (x1 < x2)
- x1++;
- void lcd_draw_vline(const char* pixel, int x, int y1, int y2)
- _set_window(x, y1, x, y2);
- LCD_WR_REG(0x2c);
- while (y1 < y2)
- y1++;
- void lcd_blit_line(const char* pixels, int x, int y, rt_size_t size)
- rt_uint16_t *ptr;
- ptr = (rt_uint16_t*)pixels;
- LCD_WR_REG(0x2c);
- while (size)
- LCD_WR_DAT(*ptr ++);
- size --;
- void lcd_clear()
- int w = HDP + 1, h = VDP + 1;
- _set_cursor(0, 0);
- LCD_WR_REG(0x2c);
- while (w--)
- while(h--)
- LCD_WR_DAT(0xffff);
- h = VDP + 1;
- void LCD_INIT(void)
- GPIO_ResetBits(GPIOE, GPIO_Pin_1);
- Delay(0xAFFFF);
- GPIO_SetBits(GPIOE, GPIO_Pin_1 );
- Delay(0xAFFFF);
- LCD_WR_REG(0x00E2); // PLL=10*36/3=120M
- LCD_WR_DAT(0x0023); //N=0x36 for 6.5M, 0x23 for 10M crystal
- LCD_WR_DAT(0x0002);
- LCD_WR_DAT(0x0004);
- LCD_WR_REG(0x00E0);
- LCD_WR_DAT(0x0001);
- Delay(0xAFFF);
- LCD_WR_DAT(0x0003);
- Delay(0xAFFF);
- LCD_WR_REG(0x0001);
- Delay(0xAFFF);
- LCD_WR_REG(0x00E6); //PLL setting for PCLK, depends on resolution
- LCD_WR_DAT(0x0033);
- LCD_WR_DAT(0x0032);
- LCD_WR_REG(0x00B0); //module
- LCD_WR_DAT(0x0000);
- LCD_WR_DAT((HDP>>8)&0X00FF); //Set HDP
- LCD_WR_DAT(HDP&0X00FF);
- LCD_WR_DAT((VDP>>8)&0X00FF); //Set VDP
- LCD_WR_DAT(VDP&0X00FF);
- LCD_WR_REG(0x00B4); //HSYNC
- LCD_WR_DAT((HT>>8)&0X00FF); //Set HT
- LCD_WR_DAT(HT&0X00FF);
- LCD_WR_DAT((HPS>>8)&0X00FF); //Set HPS
- LCD_WR_DAT(HPS&0X00FF);
- LCD_WR_DAT(HPW); //Set HPW
- LCD_WR_DAT((LPS>>8)&0X00FF); //Set HPS
- LCD_WR_DAT(LPS&0X00FF);
- LCD_WR_REG(0x00B6); //VSYNC
- LCD_WR_DAT((VT>>8)&0X00FF); //Set VT
- LCD_WR_DAT(VT&0X00FF);
- LCD_WR_DAT((VPS>>8)&0X00FF); //Set VPS
- LCD_WR_DAT(VPS&0X00FF);
- LCD_WR_DAT(VPW); //Set VPW
- LCD_WR_DAT((FPS>>8)&0X00FF); //Set FPS
- LCD_WR_DAT(FPS&0X00FF);
- LCD_WR_REG(0x00BA);
- LCD_WR_DAT(0x000F); //GPIO[3:0] out 1
- LCD_WR_REG(0x00B8);
- LCD_WR_DAT(0x0007); //GPIO3=input, GPIO[2:0]=output
- LCD_WR_DAT(0x0001); //GPIO0 normal
- LCD_WR_REG(0x0036); //rotation
- LCD_WR_REG(0x00F0); //16位 565 color module
- Delay(0xAFFF);
- LCD_WR_REG(0x0029); //display on
- LCD_WR_REG(0x00BE); //set PWM for B/L
- LCD_WR_DAT(0x0006);
- LCD_WR_DAT(0x0080);
- LCD_WR_DAT(0x00f0);
- LCD_WR_REG(0x00d0);// backlight
- LCD_WR_DAT(0x000d);
- void GPIO_INIT(void)
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
- | RCC_APB2Periph_GPIOD| RCC_APB2Periph_GPIOE| RCC_APB2Periph_GPIOF , ENABLE);
- void FSMC_LCD_Init(void)
- FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
- FSMC_NORSRAMTimingInitTypeDef p;
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- GPIO_SetBits(GPIOD, GPIO_Pin_13);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
- GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_14 |
- GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
- GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
- GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 ;
- p.FSMC_AddressSetupTime = 0x02;
- p.FSMC_AddressHoldTime = 0x00;
- p.FSMC_DataSetupTime = 0x05;
- p.FSMC_BusTurnAroundDuration = 0x00;
- p.FSMC_CLKDivision = 0x00;
- p.FSMC_DataLatency = 0x00;
- p.FSMC_AccessMode = FSMC_AccessMode_B;
- FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
- FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
- FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR;
- FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
- FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
- FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
- FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
- FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
- FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
- FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
- FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
- FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
- FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
- FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
- FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
- FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
- FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
- struct rt_device_graphic_ops ssd1963_ops =
- lcd_set_pixel,
- lcd_get_pixel,
- lcd_draw_hline,
- lcd_draw_vline,
- lcd_blit_line
- struct rt_device _lcd_device;
- static rt_err_t lcd_init(rt_device_t dev)
- return RT_EOK;
- static rt_err_t lcd_open(rt_device_t dev, rt_uint16_t oflag)
- return RT_EOK;
- static rt_err_t lcd_close(rt_device_t dev)
- return RT_EOK;
- static rt_err_t lcd_control(rt_device_t dev, rt_uint8_t cmd, void *args)
- switch (cmd)
- case RTGRAPHIC_CTRL_GET_INFO:
- struct rt_device_graphic_info *info;
- info = (struct rt_device_graphic_info*) args;
- RT_ASSERT(info != RT_NULL);
- info->bits_per_pixel = 16;
- info->pixel_format = RTGRAPHIC_PIXEL_FORMAT_RGB565P;
- info->framebuffer = RT_NULL;
- info->width = HDP + 1;
- info->height = VDP + 1;
- break;
- case RTGRAPHIC_CTRL_RECT_UPDATE:
- /* nothong to be done */
- break;
- default:
- break;
- return RT_EOK;
- void rt_hw_lcd_init(void)
- /* register lcd device */
- _lcd_device.type = RT_Device_Class_Graphic;
- _lcd_device.init = lcd_init;
- _lcd_device.open = lcd_open;
- _lcd_device.close = lcd_close;
- _lcd_device.control = lcd_control;
- _lcd_device.read = RT_NULL;
- _lcd_device.write = RT_NULL;
- _lcd_device.user_data = &ssd1963_ops;
- GPIO_INIT();
- FSMC_LCD_Init();
- LCD_INIT();
- lcd_clear();
- /* register graphic device driver */
- rt_device_register(&_lcd_device, "lcd",
- RT_DEVICE_FLAG_RDWR | RT_DEVICE_FLAG_STANDALONE);
