[应用相关] 看门狗的使用
 楼主| zhouhuanの 发表于 2016-10-23 17:36 | 显示全部楼层 |阅读模式
假设我们有个软件有时候会内存出错,或者陷入死循环,那么我们就可以通过独立看门狗来使得该器件复位。
废话少说:
代码示例:伸手党快来!
void IWDG_Init()
//Enable write access to IWDG_PR and IWDG_RLR registers
IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
//Configure the IWDG prescaler
IWDG_SetPrescaler(IWDG_Prescaler_16); //10k
//Configure the IWDG counter value
IWDG_SetReload(2500); // Bits11:0 RL[11:0]: Watchdog counterreload value ~ Only 12bit ~max value = 4096
IWDG_ReloadCounter();
IWDG_Enable();
What?这代码是怎么写出来的,Don't worry,Let me tell you !
由于我们使用的是st官方的库,因此有很多文档说明!看看注释就知道啦!如下:
1、首先,打开官方库的任一template:使用keil MDK 打开如下目录
stsw-stm32062.zip\STM32F2xx_StdPeriph_Lib_V1.1.0\Project\STM32F2xx_StdPeriph_Template\MDK-ARM
这样你就会在左手边看到一个如下图一样的文件。简要查看下,我们所要使用的是IWDG这个功能。因此肯定是stm32f2xx_iwdg.c这个文件啦!(f2xx系列的库才有注释,10x的没有。。不过差不多,可能10x的教程相对较多。
打开后就有相关的详细介绍了!
* How to use this driver
* 1. Enable write access to IWDG_PR and IWDG_RLR registersusing
* IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable) function
* 2. Configure the IWDG prescaler using IWDG_SetPrescaler()function
* 3. Configure the IWDG counter value using IWDG_SetReload()function.
* This value will be loaded in the IWDG counter each time thecounter
* is reloaded, then the IWDG will start counting down from thisvalue.
* 4. Start the IWDG using IWDG_Enable() function, when the IWDGis used
* in software mode (no need to enable the LSI, it will beenabled
* by hardware)
* 5. Then the application program must reload the IWDG counterat regular
* intervals during normal operation to prevent an MCU reset,using
* IWDG_ReloadCounter() function.
别说看不懂哈!
如下验证整个看门狗的过程:
IWDG_Init();
printf("SysInit\r\n");
while(1)
Delay_us(1000);
printf("1000 \r\n");
Delay_us(10000);
printf("10000 \r\n");
Delay_us(100000);
printf("100000 \r\n");
Delay_us(200000);
printf("200000 \r\n");
Delay_us(300000);
Delay_us(400000);
printf("400000 \r\n");
Delay_us(500000);
printf("500000 \r\n");
Delay_us(600000);
printf("600000 \r\n");
Delay_us(700000);
printf("700000 \r\n");
Delay_us(800000);
printf("800000 \r\n");
Delay_us(900000);
printf("900000 \r\n");
Delay_us(1000000);
printf("1000000 \r\n");
Delay_us(2000000);
printf("2000000\r\n");
这样,设置的看门狗必须为每1s喂狗一次,因此,到最后的延时2s的打印函数是不会被打印出来的,直接又一次复位了.
另外,需要注意的是:
1.独立看门狗的ReloadCounter寄存器只有12位~!意思就是,最大值为2的12次方 =4096,千万不能超出!
bbapple 发表于 2016-10-23 17:36 | 显示全部楼层
有某个寄存器按照时钟源不断的递减(有只狗,不断的消耗能量),当该寄存器为0时则会触发系统复位(狗会叫),为了不使得寄存器为0,我们就要按时的重新设置寄存器的值(喂狗),这样当软件正常工作时(正常喂狗,狗就不会叫)不断的重设寄存器就不会导致复位。当万一软件陷入死循环,不再重设寄存器(没有喂狗,狗就会叫)。这样就会产生复位了。
handleMessage 发表于 2016-10-23 17:42 | 显示全部楼层
独立看门狗:有独立时钟(内部低速时钟LSI),所以不受系统硬件影响的系统故障探测器。
bbapple 发表于 2016-10-23 17:47 | 显示全部楼层
独立看门狗:有独立时钟(内部低速时钟LSI),所以不受系统硬件影响的系统故障探测器。 ...
独立看门狗主要用于监视硬件错误。精确度要求比较低。
xia00 发表于 2016-10-23 17:56 | 显示全部楼层
独立看门狗的时钟源为LSI,尽管主时钟出错,它还是能保持激活状态。
hfdy01 发表于 2016-10-23 17:56 | 显示全部楼层
窗口看门狗的时钟源为APB1时钟,并且可以修改分频值吧。
CallReceiver 发表于 2016-10-23 18:04 | 显示全部楼层
stm32f10x系列有两个看门狗,看门狗主要用于检测由于软件出错的问题,并触发系统自动复位。
boy1990 发表于 2016-10-23 18:05 | 显示全部楼层
stm32f10x系列有两个看门狗,看门狗主要用于检测由于软件出错的问题,并触发系统自动复位。 ...
窗口看门狗还可以触发一个中断
sourceInsight 发表于 2016-10-23 18:08 | 显示全部楼层
独立看门狗:可参看RM(reference Manual)的Independent watchdog (IWDG)
feiqi1 发表于 2016-10-23 18:10 | 显示全部楼层
今天学习到了看门狗还分独立看门狗和窗口看门狗
androidbus 发表于 2016-10-23 18:13 | 显示全部楼层
使用看门狗目的是当程序走入死循环或者硬件异常时,可以自动复位。
litengg 发表于 2016-10-23 18:14 | 显示全部楼层
看门狗用的很多,原来功能也很强大呀
Bjorn 发表于 2016-10-23 20:22 | 显示全部楼层
独立看门狗使用的是独立时钟源,不受系统时钟影响
robter 发表于 2016-10-24 07:59 | 显示全部楼层
很好很好,学习了
309030106 发表于 2016-10-26 22:00 | 显示全部楼层
窗口看门狗的时钟源为APB1时钟
