[技术问答] 请教MINI51ZAN这个片子是新唐哪个系列的 ?
 楼主| holts 发表于 2018-1-25 16:19 | 显示全部楼层 |阅读模式
gaoyang9992006 发表于 2018-1-25 18:22 | 显示全部楼层
The Nuvoton MINI51ZAN is a Core - ARM Cortex-M0 core runs up to 24 MHz - One 24-bit system timer - Supports low power Idle Mode - A single-cycle 32-bit hardware multiplier - NVIC for the 32 interrupt inputs, each with 4-levels of priority - Supports Serial Wire Debug (SWD) with 2 watchpoints/4 breakpoints Built-in LDO for Wide Operating Voltage Range: 2.5 V to 5.5 V Memory - 4KB/8KB/16KB Flash memory for program memory (APROM) - Configurable Flash memory for data memory (Data Flash) - 2KB Flash memory for loader (LDROM) - 2KB SRAM for internal scratch-pad RAM (SRAM) In-System Programming (ISP) & In-Circuit Programming (ICP) Clock Control - Programmable system clock source - 4 to 24 MHz crystal oscillator (HXT) - 32.768K crystal oscillator (LXT) for idle wake-up and system operation clock - 22.1184 MHz internal oscillator (HIRC) (1% accuracy at 250C, 5V) - 10 KHz internal low-power oscillator (LIRC) for watchdog and idle wakeup I/O Port - Up to 30 General Purpose I/O (GPIO) pins Timer - Two 24-bit Timers with 8-bit pre-scaler Watchdog Timer - Programmable clock source and timeout period PWM - Built-in up to three 16-bit PWM generators UART - One UART device - Support IrDA (SIR) function - Programmable baud-rate generator up to 1/16 system clock - Support RS-485 function SPI - One SPI device - Master up to 24 MHz, and Slave up to 4 MHz - Support SPI master/slave mode - Full duplex synchronous serial data transfer - MSB or LSB first data transfer I2C - Master/Slave mode up to 1 Mbit/s (Fast-mode Plus) - Bi-directional data transfer between masters and slaves - Multi-master bus (no central master) - Support multiple address recognition (four slave address with mask option) ADC - 10-bit SAR ADC with 150K SPS Analog Comparator - Two analog comparators - Build-in comparator reference voltage (CRV) BOD Reset - Programmable 3 threshold levels: 3.8V/2.7V/2.0V 96-bit unique ID.
gaoyang9992006 发表于 2018-1-25 18:23 | 显示全部楼层
gaoyang9992006 发表于 2018-1-25 18:24 | 显示全部楼层
这个是12年的产品,现在已经不生产了,请参考官方网站提供的新的后缀型号。如果使用,请使用头文件
http://www.keil.com/dd/docs/arm/nuvoton/mini51/mini51.h
 楼主| holts 发表于 2018-1-25 22:34 | 显示全部楼层
http:// ...
谢谢,关键是找不到技术手册。
heisexingqisi 发表于 2018-1-26 10:44 | 显示全部楼层
http://www.keil.com/dd/docs/data ... tex_m0_r0p0_trm.pdf
版主给你发的链接下面有资料啊。那个keil网址的链接里。
heisexingqisi 发表于 2018-1-26 10:46 | 显示全部楼层
 楼主| holts 发表于 2018-1-26 13:17 | 显示全部楼层
晕,还可以这样玩,哪是keil啊
xyz549040622 发表于 2018-1-28 11:10 | 显示全部楼层
http:// ...
mini51系列居然没有了?
xyz549040622 发表于 2018-1-28 11:11 | 显示全部楼层
谢谢,关键是找不到技术手册。
技术手册,某些论坛或者网站应该还有上传的,到处找找看看。
QQ1099811789 发表于 2019-6-14 14:25 | 显示全部楼层
yingtexin 发表于 2019-6-14 22:05 | 显示全部楼层
这个版本号变更了,有替代的型号,如果准备继续用可以联系我。
yiyigirl2014 发表于 2019-6-14 23:45 | 显示全部楼层
老型号。
huangcunxiake 发表于 2019-6-17 09:48 | 显示全部楼层
mini51的开发板还没有用过。
643757107 发表于 2019-6-18 23:07 | 显示全部楼层
这个系列性价比很高。
jasontu 发表于 2019-6-19 08:06 | 显示全部楼层
MINI51ZAN => MINI51ZDN (PIN TO PIN and function compatible)
个人签名:QQ854887889  出几块TFT屏(2.2寸,有资料,送转接板),现在15RMB到付
45
