gnuradio-runtime.dir/prefs.cc.o错误的解决
 楼主| gaochy1126 发表于 2019-9-15 18:32 | 显示全部楼层 |阅读模式
[  4%] Building CXX object gnuradio-runtime/lib/CMakeFiles/gnuradio-runtime.dir/prefs.cc.o
/home/ubuntu/gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc: In member function ‘virtual void gr::prefs::_read_files(const std::vector<std::__cxx11::basic_string<char> >&)’:
/home/ubuntu/gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc:117:16: error: ‘cerr’ is not a member of ‘std’
           std::cerr << "WARNING: Config file '" << fname << "' failed to parse:" << std::endl;
/home/ubuntu/gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc:117:16: note: suggested alternative: ‘ceil’
                ceil
/home/ubuntu/gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc:118:16: error: ‘cerr’ is not a member of ‘std’
           std::cerr << e.what() << std::endl;
/home/ubuntu/gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc:118:16: note: suggested alternative: ‘ceil’
                ceil
/home/ubuntu/gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc:119:16: error: ‘cerr’ is not a member of ‘std’
           std::cerr << "Skipping it" << std::endl;
/home/ubuntu/gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc:119:16: note: suggested alternative: ‘ceil’
                ceil
/home/ubuntu/gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc:122:14: error: ‘cerr’ is not a member of ‘std’
         std::cerr << "WARNING: Config file '" << fname << "' could not be opened for reading." << std::endl;
/home/ubuntu/gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc:122:14: note: suggested alternative: ‘ceil’
              ceil
gnuradio-runtime/lib/CMakeFiles/gnuradio-runtime.dir/build.make:950: recipe for target 'gnuradio-runtime/lib/CMakeFiles/gnuradio-runtime.dir/prefs.cc.o' failed
make[2]: *** [gnuradio-runtime/lib/CMakeFiles/gnuradio-runtime.dir/prefs.cc.o] Error 1
CMakeFiles/Makefile2:791: recipe for target 'gnuradio-runtime/lib/CMakeFiles/gnuradio-runtime.dir/all' failed
make[1]: *** [gnuradio-runtime/lib/CMakeFiles/gnuradio-runtime.dir/all] Error 2
Makefile:162: recipe for target 'all' failed
make: *** [all] Error 2
https://bbs.21ic.com/icview-2819104-1-2.html
 楼主| gaochy1126 发表于 2019-9-15 20:36 | 显示全部楼层
在头文件里文件添加#include <iostream>
gnuradio-3.7.10/gnuradio-runtime/lib/prefs.cc            这个文件中
个人签名:这个社会混好的两种人:一是有权有势,二是没脸没皮的。
1148
