[PIC®/AVR®/dsPIC®产品] PIC24F16KA102 硬件PWM出不来了。
 楼主| meiyouusername 发表于 2020-6-2 15:32 | 显示全部楼层 |阅读模式
void TMR2_Initialize (void)
    //TMR2 0;
    TMR2 = 0x00;
    //Period = 0.000256 s; Frequency = 2000000 Hz; PR2 511;
    PR2 = 0x1FF;
    //TCKPS 1:1; T32 16 Bit; TON enabled; TSIDL disabled; TCS FOSC/2; TGATE disabled;
    T2CON = 0x8000;
void TMR3_Initialize (void)
    //TMR3 0;
    TMR3 = 0x00;
    //Period = 0.000256 s; Frequency = 2000000 Hz; PR3 511;
    PR3 = 0x1FF;
    //TCKPS 1:1; TON enabled; TSIDL disabled; TCS FOSC/2; TGATE disabled;
    T3CON = 0x8000;
void OC1_Initialize (void)
    // OC1RS 222;
    OC1RS = 60;
    // OC1R 100;
    OC1R = 10;
    // OCSIDL disabled; OCM Single Compare Single-Shot mode: high to low; OCTSEL TMR2;
    OC1CON = 0x0E;
void pwmInit(void)   ///??1  ??????pwm ?? ?T3????T2 +OC1 ??PWM?
    PMD1 = 0x00FF;
    TRISAbits.TRISA6 =0;
    LATAbits.LATA6 =0;
    OC1_Initialize ();
   TMR2_Initialize();
    TMR3_Initialize();
 楼主| meiyouusername 发表于 2020-6-2 15:40 | 显示全部楼层
哪位大神用这个单片机产生过PWM 的?出不来波形了。求助。。。谢谢。。
