[STM32F1] FOC2.0库的问题
 楼主| yaojinwei111111 发表于 2021-1-1 08:48 | 显示全部楼层 |阅读模式
void HALL_Init_Electrical_Angle(void)
#if (HALL_SENSORS_PLACEMENT == DEGREES_120)
switch(ReadHallState())
  case STATE_5:
    hElectrical_Angle = (s16)(S16_PHASE_SHIFT+S16_60_PHASE_SHIFT/2);
    break;
  case STATE_1:
    hElectrical_Angle =(s16)(S16_PHASE_SHIFT+S16_60_PHASE_SHIFT+
    break;
  case STATE_3:
    hElectrical_Angle =(s16)(S16_PHASE_SHIFT+S16_120_PHASE_SHIFT+
    break;
  case STATE_2:
    hElectrical_Angle =(s16)(S16_PHASE_SHIFT-S16_120_PHASE_SHIFT-
    break;
  case STATE_6:
    hElectrical_Angle =(s16)(S16_PHASE_SHIFT-S16_60_PHASE_SHIFT-
    break;
  case STATE_4:
    hElectrical_Angle =(s16)(S16_PHASE_SHIFT-S16_60_PHASE_SHIFT/2);
    break;
  default:
    break;
#elif (HALL_SENSORS_PLACEMENT == DEGREES_60)
  case STATE_1:
    hElectrical_Angle =(s16)(S16_PHASE_SHIFT+S16_60_PHASE_SHIFT/2);
    break;
  case STATE_3:
    break;
  case STATE_7:
    break;
  case STATE_6:
    break;
  case STATE_4:
    break;
  case STATE_0:
    break;
  default:
    break;
#endif
霍尔电角度上电初始化时,各个状态的电角度已经规定好了的,怎么在霍尔中断处理程序里的值表现不一样呢?
    switch(bHallState)
      case STATE_5:
        if (bPrevHallState == STATE_5)
  //a speed reversal occured
         if(bSpeed<0)
           bSpeed = POSITIVE_SWAP;
         else
           bSpeed = NEGATIVE_SWAP;
        else
          if (bPrevHallState == STATE_6)
           bSpeed = POSITIVE;
          else
            if (bPrevHallState == STATE_3)
              bSpeed = NEGATIVE;
  // Update angle
        if(bSpeed<0)
          hElectrical_Angle = (s16)(S16_PHASE_SHIFT+S16_60_PHASE_SHIFT);
        else if(bSpeed!= ERROR)
          hElectrical_Angle = S16_PHASE_SHIFT;
        break;
如上图,上一个状态bPrevHallState是5,这次 bHallState还是5,应该霍尔出错啊,
电角度初始化时case STATE_5:
    break;
到中断时// Update angle
        if(bSpeed<0)
怎么不一样了呢?各位大侠不吝赐教
mmuuss586 发表于 2021-1-3 12:40 | 显示全部楼层
